FYI for a centerforce DF 12" clutch. - Chevelle Tech
 2Likes
post #1 of 29 (permalink) Old Apr 26th, 17, 10:59 PM Thread Starter
Geoff Swanson
Today I went out to my favorite test area, heated up the slicks and did a test launch. It slipped in first through second.
The engine is 650+ HP with torque somewhere in the same range. I'm being conservative as I have not had the car on the dyno yet with the new top end. The old top end made 529 RWHP which equates to 625 ish HP at the crank. This new set up pulls much harder and MPH is up 4-5MPH in the 1/4" even while smoking the clutch through 1st and 2nd and not getting into 4th until the 1000" + mark. With the old set up I was in 4th by the 800" mark.
The clutch has maybe 1000 miles with a hydraulic throw out bearing clearance of .100",was installed on a fresh cut flywheel and was broken in gently over a couple hundred mile. I looked for a possible oil leak getting in the BH but that was not happening either.
I had a pic from the drag stip 2 weeks ago which showed the clutch smoking bad at launch. Before posting I wanted to make sure everything was set correctly and verify what I saw in the pic. I would have posted the pic but I had posted it in another thread and evidently you can't post it twice.
I'm not here bashing CF as they say not to drag race with this clutch. I'm here just posting some info for anyone who is thinking of purchasing this clutch and you have similar power. I
When I was not drag racing the clutch held just fine with street tires and I really liked it as a street car only set-up.
I just ordered the Mcleod RXT Twin Disc after much researching.
MarkP likes this.
tucson67ss is offline
post #2 of 29 (permalink) Old Apr 26th, 17, 11:35 PM
RXT for drag racing with bias slicks ? Let us know how that works out that clutch hits very hard with slicks
CDN SS is offline
post #3 of 29 (permalink) Old Apr 26th, 17, 11:43 PM
Re: FYI for a centerforce DF 12" clutch.
Not a clutch expert. I think that rxt will be a good choice.
78 Malibu, 402, th350, 2400, holley sniper EFI, 9" 3:70, Hoosier 27X10.50-15 Quicktime pro DOT
69 VW baja 1600cc on road off road toy. For Sale
98 s10 4.3L, auto, short bed, 3 door.
For Sale: Brodix RR-o 270cc heads, 127cc chamber. Heads they are assembled at this time. I can sell them assembled or not, PM for price. These are new and still in the original boxes. I purchased these bare and had them assembled.
http://i1044.photobucket.com/albums/...psbbffi1mn.jpg
Jebchevelle is offline
post #4 of 29 (permalink) Old Apr 27th, 17, 12:08 AM Thread Starter
Geoff Swanson
Will do, I will be back at the strip on the 19th of May.
post #5 of 29 (permalink) Old Apr 27th, 17, 1:41 AM
Did CF have instructions to street drive 500 miles prior to track hits?
Mike Lewis street 572
http://www.lewisracingengines.com/
Holley HP EFI
Marcella Manifolds
Heads by Darin Morgan
Wires from Rick@Firecore
www.firecore50.com/
Cam by UDHarold
.456 X 1.8/1.7
Menscer Motorsports
http://menscerms.com/
R2C Filters
www.r2cperformance.com
Ultra Carbon
www.ultra-carbon.com/
GF-5R,
http://trzmotorsports.com/wp2/
TRZ FAB 9" 4.56 REM, Cryo Treated
4000 lb street car
My Showroom
aukai is offline
post #6 of 29 (permalink) Old Apr 27th, 17, 8:30 AM
Vinny Vince
This. 500 MINIMUM miles and more if the car is mostly highway. Couple hundred is really not enough to knock the machining marks off the flywheel.
My 11" CF DF has survived 100+ runs in my 4000lb ~600+hp car w/o even so much as making a smell. 12" should be able to handle more tq.
*11 C6, 6.2, 6spd
69-CHVL is offline
post #7 of 29 (permalink) Old Apr 27th, 17, 10:06 AM
Cam
Cameron Milne
Are there special setup procedures for dialing in a twin clutch system? I had heard that they were fiddly to initially set up, but then you are golden.
Opportunity is missed by most people because it is dressed in overalls and looks like work.
~Thomas Edison~
My Showroom
TC Gold #120
My completely stock 67 Malibu Sport Coupe 6 cyl
Cam is offline
post #8 of 29 (permalink) Old Apr 27th, 17, 10:13 AM
Perfect be interested to hear what you think
I'm shopping for new clutch similar power have a couple friends who tried that clutch with slicks they found it a parts breaker really hit hard at launch no slip but good on street so be good to get another opinion
Was 439ci Straub Solid Roller Brodix RR,
SOLD
,Tremec by Liberty
10.97/ 124.31 1.41 60ft
New Foxwell 475ci Power ready to go back in
Crusin / Track video http://www.youtube.com/watch?v=fhvDGOO4JAI
Engine
CDN SS is offline
post #9 of 29 (permalink) Old Apr 27th, 17, 10:15 AM Thread Starter
Geoff Swanson
Yes, and it worked fine with my last set-up as well. It is not a break in issue. Why would you want to wear the machine marks down as they help to grab the clutch plate? If it where best to be dead smooth you would wet grind it to a 10 RA or less finish and be done with it. No break in needed!
I pussy footed the clutch for the first couple hundred miles, but did not run it at the strip for 6 months after I installed it.
Like I said "I'm not bashing the clutch" and did say they don't recommend drag racing with the clutch. I will be able to tell more when I pull the clutch.
post #10 of 29 (permalink) Old Apr 27th, 17, 10:22 AM Thread Starter
Geoff Swanson
I don't recall if they put a number on it.
post #11 of 29 (permalink) Old Apr 27th, 17, 10:24 AM
Mark
Have you tried the Ram Powergrip HD? Its worked well for me on the strip.
gotago is offline
post #12 of 29 (permalink) Old Apr 27th, 17, 10:29 AM Thread Starter
Geoff Swanson
I guess its good that I have a 9" with 31 spline axles, 1350 U joints and a bullet proof Tremec first gear. I can always take some of the hit out with shock adjustments, or more air pressure in the slicks or a combination of both.
I've never had an issue with too hard of a hit, it is usually the very opposite in that it is hard to get it to hook. That is why I switched to DA shocks.
post #13 of 29 (permalink) Old Apr 27th, 17, 10:31 AM Thread Starter
Geoff Swanson
I was going to go that route, but figured I would just spend the extra $$$ and go for a drag race recommended clutch.
post #14 of 29 (permalink) Old Apr 27th, 17, 10:33 AM Thread Starter
Geoff Swanson
Form the research I've done it does appear to be that way. I will know for sure when the clutch arrives tomorrow.
post #15 of 29 (permalink) Old Apr 27th, 17, 10:49 AM
Vinny Vince
B/c the machine marks are reducing the pressure plate to flywheel contact surface something like 50% until they are mated. Very similar to honing a cylinder...honing leaves small ridges until the surfaces are mated. Machining the flywheel is more about getting the thing squared up properly in terms of knocking high and low spots down and leaving a finish on the surface that will facilitate proper mating of all parts. After proper mating eventually the flywheel WILL have a dead smooth finish.
FWIW I smoke a DF early on b/c I didnt break it in. I got lucky by having the flywheel re-machined, went through a 500 mile break-in and the SOB held!!!!! Saved me ~250.00 thankfully. Clutch lasted for years afterwards till I sold that trans and changed everything to the T56.
Interesting read:
Burned up clutch..need another set of eyes on this:
*11 C6, 6.2, 6spd
69-CHVL is offline
