Removing Bellhousing Dowels - Chevelle Tech
  • 1 Post By aukai
post #1 of 13 (permalink) Old Apr 26th, 17, 8:56 PM Thread Starter
Devin
What is the best method? Engine is in the car. We need to get them out to install offset ones for a Lakewood bellhousing.
Thanks,
Devin
64SS427 is offline
post #2 of 13 (permalink) Old Apr 26th, 17, 9:04 PM
Re: Removing Bellhousing Dowels
Best way I have seen is to press them out from the back. can you get a small brass hammer and punch in there? may have to remove the headers to get the room gonna be tight I have a long cheap extension I use cut off the socket end and ground it down to make a punch.
78 Malibu, 402, th350, 2400, holley sniper EFI, 9" 3:70, Hoosier 27X10.50-15 Quicktime pro DOT
69 VW baja 1600cc on road off road toy. For Sale
98 s10 4.3L, auto, short bed, 3 door.
For Sale: Brodix RR-o 270cc heads, 127cc chamber. Heads they are assembled at this time. I can sell them assembled or not, PM for price. These are new and still in the original boxes. I purchased these bare and had them assembled.
http://i1044.photobucket.com/albums/...psbbffi1mn.jpg
Jebchevelle is offline
post #3 of 13 (permalink) Old Apr 26th, 17, 10:04 PM
Ron
I had luck drilling into them and taping them 1/4-20 then make a slide hammer out of 1/4-20 all thread. Worked for me. I also had to install dowels for a Lakewood bell housing.
RLM66SS is offline
post #4 of 13 (permalink) Old Apr 26th, 17, 10:30 PM
Geoff Swanson
I did not have to do this as I changed mine with the engine out, but I almost assure you this is the best method. You have to give them a pretty good whack with a punch and hammer to get them out. You may be able to get the pass side out with a punch and hammer, but the driver side has a small window to get into and it would be near impossible with the engine in the car. I believe it was part of the oil filter casting that made it awkward. I had to use a very small diameter drift punch made of tool steel to get at it. A brass punch that would get in there would not stand a chance.
tucson67ss is offline
post #5 of 13 (permalink) Old Apr 26th, 17, 10:51 PM Thread Starter
Devin
Got 'em out. Long drift on the passenger side and made a long drift with a kink at the end for the drivers side out of 3/8" rod.
Thanks,
Devin
64SS427 is offline
post #6 of 13 (permalink) Old Apr 26th, 17, 11:04 PM
Thanks,
Devin
Sweet glad to see. Some come out easier then others. It is like anything else in this game.
post #7 of 13 (permalink) Old Apr 26th, 17, 11:09 PM
Geoff Swanson
Thanks,
Devin
Good for you and I stand corrected ! Your block must have a different casting in order to get that 3/8" in there. I used a 3/16" and it was tight.
My block is a 92 454" block.
post #8 of 13 (permalink) Old Apr 27th, 17, 1:46 AM
Thanks for posting back Devin, it will help on someones search I'm sure.
Jebchevelle likes this.
Mike Lewis street 572
http://www.lewisracingengines.com/
Holley HP EFI
Marcella Manifolds
Heads by Darin Morgan
Wires from Rick@Firecore
www.firecore50.com/
Cam by UDHarold
.456 X 1.8/1.7
Menscer Motorsports
http://menscerms.com/
R2C Filters
www.r2cperformance.com
Ultra Carbon
www.ultra-carbon.com/
GF-5R,
http://trzmotorsports.com/wp2/
TRZ FAB 9" 4.56 REM, Cryo Treated
4000 lb street car
My Showroom
aukai is offline
post #9 of 13 (permalink) Old Apr 27th, 17, 4:18 PM
Thanks,
Devin
Thats what I had to do,lol.Sucked.
'67 Malibu,468 w/powerglide
Project-
http://www.chevelles.com/forums/142-...esto-67-a.html
72LS3Z27 is offline
post #10 of 13 (permalink) Old Apr 27th, 17, 8:42 PM Thread Starter
Devin
Just for the next guy looking, this was in my son's 65 with 010 block 350. Starter was out, but clutch linkage and oil filter were still in place. We had to get at it from the front sway bar area.
Devin
64SS427 is offline
post #11 of 13 (permalink) Old Apr 28th, 17, 6:52 AM
Mark
Mine came out with a pair of pliers and some WD40. I was lucky!!
gotago is offline
post #12 of 13 (permalink) Old Apr 28th, 17, 6:54 PM
Geoff Swanson
Devin
I'm actually heading out to the shop to pull my trans and clutch. I will report back about the exact issue I had with the 454" block. I will see if long drift would work. This could be a whole new issue though as it is a BBC.
post #13 of 13 (permalink) Old Apr 28th, 17, 7:37 PM
no 2 are the same lol core shift and the fact we are looking at a bbc vs a sbc.
