More progress - Chevelle Tech
 36Likes
post #1 of 58 (permalink) Old Feb 28th, 17, 12:58 AM Thread Starter
More progress
I'm going to mount a vacuum pump, and I needed 1/4" more space for the belt drive. So I am attempting to put in a front motor plate.I'm glad I had enough cardboard for templates. One side bolted right on, the other was a challenge to fit. As of now I will rest the plate on the frame, and put the bracket/tab behind. Later if it is a wear item I will plate the frame. Any other suggestions welcome. Here is my grass shack machinist blueing(Sharpie) also. I still have to tend to contouring, and fitting the vacuum pump, but it fits the frame.
bigmachd and Thor454 like this.
Mike Lewis street 572
http://www.lewisracingengines.com/
Holley HP EFI
Marcella Manifolds
Heads by Darin Morgan
Wires from Rick@Firecore
www.firecore50.com/
Cam by UDHarold
.456 X 1.8/1.7
Menscer Motorsports
http://menscerms.com/
R2C Filters
www.r2cperformance.com
Ultra Carbon
www.ultra-carbon.com/
GF-5R,
http://trzmotorsports.com/wp2/
TRZ FAB 9" 4.56 REM, Cryo Treated
4000 lb street car
My Showroom
aukai is offline
post #2 of 58 (permalink) Old Feb 28th, 17, 3:07 AM Thread Starter
Re: More progress
I also had a fitment problem with the engine diaper. The 21049 pan cleared everything, except when you add the diaper, and absorbent pad. So I did some work on the center link for more clearance.
Wolfplace likes this.
Holley HP EFI
Marcella Manifolds
www.firecore50.com/
Cam by UDHarold
.456 X 1.8/1.7
Menscer Motorsports
R2C Filters
Ultra Carbon
GF-5R,
4000 lb street car
My Showroom
aukai is offline
post #3 of 58 (permalink) Old Feb 28th, 17, 3:23 AM
Smile Re: More progress
Respectfully, Mike - why don't you just add to your previous thread, instead of starting a new one?
David
http://www.cardomain.com/ride/307290...rolet-chevelle
davewho1 is offline
post #4 of 58 (permalink) Old Feb 28th, 17, 3:54 AM Thread Starter
Re: More progress
I didn't think to keep adding to the same one, so far in between. If it's wanted I will next time.
davewho1 likes this.
Holley HP EFI
Marcella Manifolds
www.firecore50.com/
Cam by UDHarold
.456 X 1.8/1.7
Menscer Motorsports
R2C Filters
Ultra Carbon
GF-5R,
4000 lb street car
My Showroom
aukai is offline
post #5 of 58 (permalink) Old Feb 28th, 17, 4:41 AM
Re: More progress
Originally Posted by aukai View Post
I didn't think to keep adding to the same one, so for in between. If it's wanted I will next time.
It gives your build thread continuity, Mike, for those who are following along.
And it's easier to find, instead of people spending time looking for several different-named threads about the same car.
David
davewho1 is offline
post #6 of 58 (permalink) Old Feb 28th, 17, 7:07 AM
Cam
Cameron Milne
Re: More progress
Yes Mike, you do have a few followers here on the site.
Slowly but surely it is coming along. Lots of ground has been covered with your build and it is progressing nicely. One thing though, I didn't think there is a posted speed limit above 50 mph on your island. Time for digger gears and a G-suit for the day you unleash that beast!
Opportunity is missed by most people because it is dressed in overalls and looks like work.
~Thomas Edison~
My Showroom
TC Gold #120
My completely stock 67 Malibu Sport Coupe 6 cyl
Cam is offline
post #7 of 58 (permalink) Old Feb 28th, 17, 12:44 PM
Re: More progress
How heavy is that metal plate?
1971 Chevelle SS454 4 speed, 3.31 Posi
-SS454- is offline
post #8 of 58 (permalink) Old Feb 28th, 17, 1:24 PM Thread Starter
Re: More progress
Thank you gentlemen, I was not thinking of this as a build thread, just me putsing along in the garage. I'm not sure this can be rectified for earlier, but I'll dig this up when new installments come up.
Chris the motor plate is .250 thick, and I'm going to add a 3/16 tab/bracket welded to the frame, 2 bolts each side. I may add a mid plate at a later date, for now I'll still have solid side mounts.
If you wanted the actual weight it's 7.7 lbs as is.
Holley HP EFI
Marcella Manifolds
www.firecore50.com/
Cam by UDHarold
.456 X 1.8/1.7
Menscer Motorsports
R2C Filters
Ultra Carbon
GF-5R,
4000 lb street car
My Showroom
aukai is offline
post #9 of 58 (permalink) Old Feb 28th, 17, 2:29 PM
Re: More progress
Thanks Mike. The pictures made it look a lot thicker to me, which made me think it was upwards of 30 lbs. 8 lbs is not too bad. Keep up the good work.
-SS454- is offline
post #10 of 58 (permalink) Old Feb 28th, 17, 8:48 PM
Re: More progress
The work just never ends
rlr33 is offline
post #11 of 58 (permalink) Old Feb 28th, 17, 10:30 PM
Mac
Re: More progress
Nice , Cardboard and sharpies are your friend
1970 Chevelle SS full weight street car (4030lbs)
498-11.5:1 (Mac built) 91 pump gas+
Strauby sissy roller -
brodix-rr rec 294
weiand stelth- Pro Systems 1000
turbo 400 10" 3200 Coan 4.10 12 bolt
Best Passes on28-10.5-15 slicks and 110
1.56-6.97-99.83
1.6194-11.1666-120.94
If it wasn't dangerous, it wouldn't be fun!
http://www.chevelles.com/showroom/data/507/IMG_2519.JPG
http://www.chevelles.com/showroom/da.../IMG_24851.JPG
bigmachd is offline
post #12 of 58 (permalink) Old Mar 1st, 17, 12:37 AM Thread Starter
Re: More progress
Got my pump, now to get spacers.
CDN SS, Wolfplace and Thor454 like this.
Holley HP EFI
Marcella Manifolds
www.firecore50.com/
Cam by UDHarold
.456 X 1.8/1.7
Menscer Motorsports
R2C Filters
Ultra Carbon
GF-5R,
4000 lb street car
My Showroom
aukai is offline
post #13 of 58 (permalink) Old Mar 3rd, 17, 9:08 AM
Re: More progress
I read all your posts and I`m liking the build and the progress
68 BISCAYNE 4060lb
468-9.4:1
1.76 60FT Drag Radials
11.69 ET@ 116.30 MPH
BigRed-L72 is offline
post #14 of 58 (permalink) Old Mar 3rd, 17, 9:51 AM
Jarad
Re: More progress
Looks good!
Sent from my LGMS428 using Tapatalk
72 Slovelle
555 Pump Gas BBC
Freakshow Glide
Moser 9" 4.30 Gears
Straub/Foxwell
6.20 @111, 9.85 @133+
JBoggs is online now
post #15 of 58 (permalink) Old Mar 3rd, 17, 1:38 PM Thread Starter
Re: More progress
I talked to Steve at Star, and found out the pump gear can be flipped around which helped a bunch. The pump needs to come out only .820 now to line up. I have a Vintage air front runner system to put on to set where the pump will go. Now I have to find the mounting frame that I haven't seen in 4 years. I did find all of the bolts, spacers, small brackets, etc.
Holley HP EFI
Marcella Manifolds
www.firecore50.com/
Cam by UDHarold
.456 X 1.8/1.7
Menscer Motorsports
R2C Filters
Ultra Carbon
GF-5R,
4000 lb street car
My Showroom
aukai is offline
