Summit 1103 - Chevelle Tech
post #1 of 4 (permalink) Old Dec 15th, 13, 4:33 PM Thread Starter
Summit 1103
Just pulled out the cam in a 30 over 283. Had a Summit 1103 in it. Anyone know if this was a good combo with 601 305 heads and a uncut deck with 4 valve relief flat top pistons?
Aaron is offline
post #2 of 4 (permalink) Old Dec 15th, 13, 4:52 PM
"Wild Bill"
Re: Summit 1103
That cam is very close in spec to the one GM uses in it's 350 HO/330hp crate motor which uses Vortec heads.
Might be a little large for a 283...depending on application (gears & trans).
Team Chevelle #613
ACES #3920
CAMI (Ireland) #14
CanAm Chevelles #136
Carolina Chevelles #185
Heart Of Dixie #231
Long Island Chevelles #113
BillsCamino is offline
post #3 of 4 (permalink) Old Dec 15th, 13, 4:58 PM Thread Starter
Re: Summit 1103
M22 rockcrusher and 3.73 gears with 26 inch tall tires. In a 92 s10.
I looked at the summit site and it says its like 288/298 and around 214 @ 050 on a 112.
I think the Voodoo 262 would be a better choice.
Aaron is offline
post #4 of 4 (permalink) Old Dec 15th, 13, 5:52 PM
Re: Summit 1103
Yeah it's a pretty weenie 40-yr-old design...
As a species, we've advanced ourselves somewhat since back then. You can do MUCH better than that old generically copied copy of a generic copy of a generic copied copy of a generic cam-shaped object. Whatever you "save" by re-using it, will QUICKLY be ate up in buying other parts to "throw" at it to overcome the shortcomings of the cam, the poor gas mileage, the buy-backs in rounds you lose, etc. etc. etc. Life is too short to spend it that way.
RB69SS396Conv is offline
This Thread is more than 1288 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
