402 bbc 500 hp? - Chevelle Tech
post #1 of 42 (permalink) Old Apr 17th, 13, 7:19 PM Thread Starter
Win
402 bbc 500 hp?
I have a 1970 402 bbc. Checked my casting numbers and it makes 325/335hp. I've heard its hard to make huge hp from a 402. Hopefully can tell me the range I'm in. Here is what the motor has:
10.5:1 CR
Lunati 60204 cam and lifter kit .554/.572
Aluminum oval port heads 2.25 int/1.85 exh
Edelbrock Air Gap Intake
Holley 750 Double Pumper
2800 stall with 3:73 gears out back.
RoyaltyRides is offline
post #2 of 42 (permalink) Old Apr 17th, 13, 7:25 PM
Re: 402 bbc 500 hp?
I'd say around 450 horse.
kev574 is offline
post #3 of 42 (permalink) Old Apr 17th, 13, 8:38 PM
George
Re: 402 bbc 500 hp?
could you be VERY SPECIFIC on the heads?
George Kettler
http://public.fotki.com/kettbo/gearhead/
o 68 Camaro Vert 327 project, painted, assembly stage http://www.camaros.net/forums/showth...183654&page=55
kettbo is offline
post #4 of 42 (permalink) Old Apr 17th, 13, 10:04 PM Thread Starter
Win
Re: 402 bbc 500 hp?
Prostar heads machined to match my cam specs
300cc intake runners
115cc combustion chambers
valve springs are .600
7/16 rocker studs
post #5 of 42 (permalink) Old Apr 17th, 13, 10:09 PM
Paul
Re: 402 bbc 500 hp?
Wtf are prostars
72 chevelle
496ci bbc
Rpm air-gap
Trick Flow 280 power ovals
850 dp
Straub hyd roller 238/246 .643-.620 107
10.7 cr
Th350
9" 3:73
pauls72 is offline
post #6 of 42 (permalink) Old Apr 17th, 13, 10:30 PM Thread Starter
Win
Re: 402 bbc 500 hp?
typo I was tryna multi-task.. they are pro comp heads
post #7 of 42 (permalink) Old Apr 18th, 13, 12:12 AM
MARK
Re: 402 bbc 500 hp?
Mike Lewis' 408 made I believe 540 HP.
VORTECPRO is online now
post #8 of 42 (permalink) Old Apr 18th, 13, 9:05 AM
Re: 402 bbc 500 hp?
I made 501 with 781 casting steel heads, and a Lunati 40209 solid flat tappet cam. 10.5.1 compression, airgap intake and 800 holley.
Ray
http://s30.photobucket.com/albums/c3...t=DSC01615.jpg
Best pass so far 9.034 at 148.10, 1.242 60'
bracketchev1221 is offline
post #9 of 42 (permalink) Old Apr 18th, 13, 10:46 AM
mike
Re: 402 bbc 500 hp?
I made 490hp, 450tq with 10.5-1, oe 215 heads with some port work and a comp 294 mech cam.
68 camaro
496ci 644tq 730hp and a lot of the street
shake down pass, 10.76 @128.52
fun>>
putput is offline
post #10 of 42 (permalink) Old Apr 18th, 13, 3:42 PM Thread Starter
Win
Re: 402 bbc 500 hp?
If I'm in the 450-500 range I'm totally okay with that. I know the only true way is to dyno. I just wanted to make sure I was on the right track. This is my first big block build
post #11 of 42 (permalink) Old Apr 18th, 13, 3:51 PM
Re: 402 bbc 500 hp?
I'd say your in that range, have you drove it yet?
kev574 is offline
post #12 of 42 (permalink) Old Apr 18th, 13, 5:41 PM Thread Starter
Win
Re: 402 bbc 500 hp?
Drove it before with the cast iron heads and a 650, but swapping the aluminum heads on with the 750 this weekend. It has hooker comp headers and super 44 flow masters
post #13 of 42 (permalink) Old Apr 18th, 13, 5:44 PM
jimmyradford
Re: 402 bbc 500 hp?
I personally wouldn't use the Procomps or heads with a 2.25" valve in that bore due to shrouding. A decent set of factory closed chamber ovals will do wonders for the 396/402 based engines.
TC Member # 4431
'04 Ram Quad-That thing has a Hemi in it!
'68 El Camino-SB 350/TH400/???
'67 Hell Camino-BB 496/TH400/???
'55 BelAir 2 door post-427/TH-400/4.10
"Good people sleep peacefully in their beds at night only because rough men stand ready to do violence on their behalf."-Orsen Wells
badrad is offline
post #14 of 42 (permalink) Old Apr 18th, 13, 6:09 PM
Paul
Re: 402 bbc 500 hp?
Ya I don't like those heads either
72 chevelle
496ci bbc
Rpm air-gap
850 dp
10.7 cr
Th350
9" 3:73
pauls72 is offline
post #15 of 42 (permalink) Old Apr 18th, 13, 6:24 PM Thread Starter
Win
Re: 402 bbc 500 hp?
It came with the the factory ovals. I'm not a fan of cast iron heads. All the extra weight but can you give me a little more explanation about the shrouding with 2.25s
