468 combo help - Chevelle Tech
post #1 of 9 (permalink) Old Sep 8th, 12, 11:57 PM Thread Starter
468 combo help
Just picked up a 87 monte SS with a 468. I was out playing today and the motor lost oil pressure and I shut it right off. Put 4 qts of oil in it to overfill it and oil pressure is back. So the pick came off.
So since I need to pull the motor. I fiqure I should change the cam. Car runs ok but I feel it needs a little more power. What would you change?
468 with about 200 miles on it.
781 heads
10.1 compression
forged pistons
Comp cam FT 280H 280/280 520/520
1.7 roller rockers
850 holley
2.5 exhaust
headers look to be 2 inch a little big
2500 convertor in a 700r4
373 moser 12 bolt
64 Chevelle 496
StevenS is offline
post #2 of 9 (permalink) Old Sep 9th, 12, 12:33 AM
Re: 468 combo help
Have the heads pocket ported and big valves installed if not already. If you are good with staying flat tappet on the cam then upgrade to a lunati 60204.
1978 Malibu
406 w/AFR 195's, 9.9;1, Lunati 60103
TH400, 10" converter, 3.73's.
1.65 60', 7.55 @ 91.37 mph.
http://i1270.photobucket.com/albums/...u/DSCN0151.jpg
http://i1270.photobucket.com/albums/...DSCN0155-1.jpg
http://www.youtube.com/watch?v=RZOxc9ywxbI
RATtyCamino is offline
post #3 of 9 (permalink) Old Sep 10th, 12, 7:52 AM Thread Starter
Re: 468 combo help
That is the cam I was looking at. Heads had some port work done but it does retain the stock valve size.
64 Chevelle 496
StevenS is offline
post #4 of 9 (permalink) Old Sep 10th, 12, 8:32 AM
Re: 468 combo help
Or if you really want to wake it up, stick a Comp xr288hr in it or a Lunati 20110712 (previously the 60212) or even a comparable Howards cam & lifter package @ a little over $500. Makes it not worth using an FT cam.
TC#3095
dreis454 is offline
post #5 of 9 (permalink) Old Sep 10th, 12, 9:12 AM
Re: 468 combo help
Even Better!
1978 Malibu
post #6 of 9 (permalink) Old Sep 10th, 12, 9:37 AM
Todd
Re: 468 combo help
Go roller! I'm glad I did, combo in my sig.
Dan, what's with the Lunati part # change?
505, brodix bb2, 12.5-1, e85, t ram, Solid roller 270/280 .715 .710, 5000 9.5 Freakshow, 3.70s
Best ET 9.96
Best MPH 136
Best 60 1.45
Best 1/8 6.39
69 Malibu is offline
post #7 of 9 (permalink) Old Sep 10th, 12, 9:47 AM
Re: 468 combo help
IDK,Look on Lunatipower.com and it seems they changed all the Voodoo HRs maybe more,I didn't look.
TC#3095
dreis454 is offline
post #8 of 9 (permalink) Old Sep 10th, 12, 10:34 AM
Jon
Re: 468 combo help
Consensus is to change the camsaft.
72BBMonte is offline
post #9 of 9 (permalink) Old Sep 10th, 12, 11:13 AM
Re: 468 combo help
Leave the cam alone and put in the bigger valves you will probably pick up around 30 hp. I picked up from 13.45 to a 12.95 with that change with 049's and a 272 .515 lift camshaft several years ago. If you have a good flat tappet I would just run it. If you change it I would not chance another flat tappet. I would go with a roller more than likely. It all depends on what you want. I mean you can grab more power and go with a bigger cam, valves and maybe go with some 1 7/8" headers. That 280 cam probably sounds really good in there right now.
Original 138 car from Freemont. 67 SS Bench seat 4-speed car with 396, Original M-20 with factory 3.73 12 Bolt Posi.
"You can never go fast enough" James Taylor Two-Lane Blacktop
Member #3635
Tri-State Chevelle Member #F-10
Larry Grigsby
plain 69 is offline
