A Good Outing - Chevelle Tech
post #1 of 17 (permalink) Old May 4th, 12, 1:31 PM Thread Starter
A Good Outing
While being down without a track for so many weeks I thought I would do some required (ignored) maintenance on the old wreck and found a couple things that needed immediate attention. Rubber motor mount on the driver side was in two pieces being held in place by the safety interlock but still allowing too much engine movement. That was fixed with new solid mounts. Also had to do some differential maintenance stuff (still a 12 bolt posi) so I decided I've been pushing my luck with the 7/16th wheel studs so they were changed to 1/2". I also serviced the Trans while down, ran the valves and did some carb tuning and made a few timing adjustments. So anyway I had to attend the new opening night at Irwindale and although it was as crowded as the winternations I got a couple passes in. The first was a timid shake down as the ring and pinion had been out so I soft footed it, ran a 6.52@106 then an hour later went back in the lanes and surprised myself with a new best of 1.41 60', a 4.088 330' and an 1/8th of 6.363@107.51. The most amuzing part of this is that this is still an old ISKY solid flat tappet cam that has been in this old turd for 6 years. It was a fun night.
Stokerboats is offline
post #2 of 17 (permalink) Old May 4th, 12, 2:10 PM
Andy
Re: A Good Outing
Sounds like a good outing and a low 10 sec, high 9 sec 1/4 mile. That 1.41 60 is awesome!
Andy's Auto Repair is offline
post #3 of 17 (permalink) Old May 4th, 12, 2:51 PM
mark
Re: A Good Outing
I always use solid motor mounts and a poly trans mount. That was a good find. With a 1.41 60', it could have gotten real ugly.
1969 Chevelle
412 small block
M-20 4spd
4:11 12 bolt
1957 Thundarbird Gasser
Aluminum Shafiroff 582
Richmond 5spd
4:33 59 Olds rear
marks412 is offline
post #4 of 17 (permalink) Old May 4th, 12, 3:46 PM
mike
Re: A Good Outing
Geez Dan,
Now I need to look for another 1/10 out of the old small block!
Here's one from your first pass--the plate always causes problems with the camera.
ratmtr likes this.
Mike Morgan Racing Photography
652 W. Bennett Ave.
Glendora, Ca. 91741
(626) 335-9025
(626) 221-4935 cell
http://bowtie0069.fotki.com
http://thefunnycarfarm.com
bowtie0069 is offline
post #5 of 17 (permalink) Old May 4th, 12, 4:43 PM
Tim
Re: A Good Outing
good looking 66 you have. what size tires ya got out back ? mini tubbed ?
grovey is offline
post #6 of 17 (permalink) Old May 4th, 12, 6:54 PM Thread Starter
Re: A Good Outing
Originally Posted by bowtie0069 View Post
Geez Dan,
Thanks Mike, that was a flat 1.49 60'. Nice to be running again although we lost a couple friends over the downtime. Dan
post #7 of 17 (permalink) Old May 4th, 12, 6:57 PM Thread Starter
Re: A Good Outing
Tim, thanks for the kind words. The Tires are 28x10.5wx15 Mickey ET Drags. They are on a Weld 15X8 wheel 4.5 bs and no the car is not tubbed.
post #8 of 17 (permalink) Old May 4th, 12, 6:58 PM Thread Starter
Re: A Good Outing
Was fun, I can't remember that many spectators and cars at Irwindale. The track seemed pretty good to me.
post #9 of 17 (permalink) Old May 5th, 12, 12:46 AM
Davey
Re: A Good Outing
hey congrats Dan!!..that's a nice gain...awesome!!
Chevelle
http://www.firstgenmc.com/photopost/...um/david_4.jpg
SloMo...
https://www.youtube.com/watch?v=Fa13syTsA0E
'67 Chevelle 516 hyd roller
4.11's
9.06 best mph 147.75
5.73 best mph 119.98
3520 lbs to 3570 depending on fuel
1.26 60 ft
Straub/Foxwell
Motor by Mark Jones
E-Store at
crazydaveyracing.com
Davey..
TC Gold Level Know it All
crazydavey is offline
post #10 of 17 (permalink) Old May 5th, 12, 1:04 AM Thread Starter
Re: A Good Outing
Thanks Davey, how's it going up there?
post #11 of 17 (permalink) Old May 5th, 12, 4:09 AM
Enrique
Send a message via AIM to Slowpoke70 Send a message via Yahoo to Slowpoke70
Re: A Good Outing
Nice car Dan. Don't think I've ever seen that particular '66 in person at Irwindale, guess I was never there on the same night you were or I just didn't see it for one reason or another.
Last time I was out at Irwindale I didn't see too many of the cars that were regulars during the 2002(?)-2007 era when I used to hang out there every Thursday night.
1970 Malibu
355/TH350/3.36
Isky z25/Sportsman2/300-36/Summit Headers
Slowpoke70 is offline
post #12 of 17 (permalink) Old May 5th, 12, 6:39 AM
Jimmi
Re: A Good Outing
Very nice 66 and congrats on your new best.
Under constuction....
1970 Chevelle
Shafiroff 582" pump gas 752hp 734tq
Mild hydraulic roller 248/254 @0,50 Lift 647/647 Lsa 114
Coan Th400 with T-brake , Coan 9,5" converter
M9 moser with 35 splines and 3,89 gear ratio.
Still missing driveshaft and complet suspension.
1966 chevelle 502 is offline
post #13 of 17 (permalink) Old May 5th, 12, 7:08 AM Thread Starter
Re: A Good Outing
Enrique, I only bring the car periodically but I watch nearly every thursday, both are enjoyable at my old age I look forward to saying hello at a track nite soon. Dan
Jimmi thanks for the encouragement. Once in a while we find something that helps. Solid Motor Mounts appear to have helped the car stiffen up some plus I had a cool can up front which I removed that freed up a little excessive weight right on the core support which I also suspect was impairing fuel flow. Dan
post #14 of 17 (permalink) Old May 5th, 12, 4:18 PM
Re: A Good Outing
Congrats Dan. Keep tuning on 'er and see how quick you can go. Weather is going to get bad pretty soon as far as setting quick et's.
Thanks Nitrous Supply 714 373 1986
I don't have a Chevelle, but I wish I did!!
69 Corvette Stingray
454, 6 speed, 11.87 @ 124 mph (full street trim) all motor, only trip to the track
63 Corvette A-gas / Top Sportsman
Pettis Performance 565 with two stages of Nitrous Supply nitrous systems.
Bests:
1.082
4.61 / 155
7.170 at 192.6
69 Ratt Vette is offline
post #15 of 17 (permalink) Old May 5th, 12, 4:55 PM Thread Starter
Re: A Good Outing
I can still drive this flat tappet old wreck wherever I want with a simple tire change and a boat load of gas money. I am pretty ok with where I am. Thanks for the words John.
This Thread is more than 1849 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
