shorty spark plugs - Chevelle Tech
post #1 of 23 (permalink) Old Apr 27th, 12, 2:27 AM Thread Starter
Banned
Anthony
shorty spark plugs
My buddy is running some Accel shorty plugs and they foul pretty easy. Is there something better he can use? Must be the same length as the Accel shorty plugs.
sschevellefan is offline
post #2 of 23 (permalink) Old Apr 27th, 12, 7:41 AM
Dave 383 now
Re: shorty spark plugs
I find that my NGK's burn really well, and they are almost as short as an Accel shorty plug , plus alot cheaper.
Dave427 is offline
post #3 of 23 (permalink) Old Apr 27th, 12, 8:14 AM
the problem is prob the tune, not the plugs unless the plugs are way to cold of a heat range
when your credit cards are maxed, have the limits raised
forcd ind is offline
post #4 of 23 (permalink) Old Apr 27th, 12, 8:20 AM
Andy
I know Delco has a shorty version of the R43T for you #4,6,3 small block guys.
Andy's Auto Repair is offline
post #5 of 23 (permalink) Old Apr 27th, 12, 8:28 AM
"Wild Bill"
Autolite AR series plugs are pretty short too.
Team Chevelle #613
ACES #3920
CAMI (Ireland) #14
CanAm Chevelles #136
Carolina Chevelles #185
Heart Of Dixie #231
Long Island Chevelles #113
BillsCamino is offline
post #6 of 23 (permalink) Old Apr 27th, 12, 11:22 AM Thread Starter
Banned
Anthony
Anyone got part numbers? I know alot of people have problems with the accells fouling. It might be the tune, it is a fresh engine. I think its set up fairly well but not sure of the carb settings.
post #7 of 23 (permalink) Old Apr 27th, 12, 11:27 AM
Jon N.
Champion uses numbers like CJ6, CJ7, CJ8 and DJ6, DJ7, DJ8 for shorty plugs for lawnmowers. The C plugs have gasket seats, the D plugs are for tapered seats.
Jon N.
dyno jonn is offline
post #8 of 23 (permalink) Old Apr 27th, 12, 12:32 PM
/\/\ikey
Send a message via MSN to Mikeys69
The shorty plug isn't that much shorter than a standard plug.
If it's just a access problem I made one of these.
2012 GMC Terrain
2011 Chev Silverado
2004 Chev Silverado
1969 Chevelle Malibu 406 SB
http://www.chevelles.com/forums/142-projects-builds/386745-mikeys69-chevelle.html
Some day I will own a 1967 Chevelle, again.
Mikeys69 is offline
post #9 of 23 (permalink) Old Apr 27th, 12, 1:10 PM
Dave 383 now
What engine what heads?
Dave427 is offline
post #10 of 23 (permalink) Old Apr 27th, 12, 1:32 PM
Oil or fuel fouled?
Assuming fuel fouled are the plugs too cold of a heat range as that can cause them to foul easy & in that case try hotter heat range plugs if your 100% sure timing & carb tuning is where it belongs.
Esp base timing when running non GM aftermarket cam that generally requires 2x-3x more base timing then stock gm cam does & when base timing is retartded it upsets the vacuum signal/low vacuum to carb causing running rich issues.
But if plug heat range is correct for application & plugs foule fairly quick then you likely have timing/carb tuning issues that need to be addressed that are causing plugs of proper heat range to foul.
I am also assuming plug wires,coil,cap & rotor,air filter (not clogged/dirty causing rich mixture) are all in good cond here too and if they are not in good cond they can be part of issues causing plug fouling too.
SCOTT
SWHEATON is offline
post #11 of 23 (permalink) Old Apr 28th, 12, 2:12 AM Thread Starter
Banned
Anthony
383, 9.7:1 60104 voodoo, Dart dual plane intake, old dart 200cc aluminum heads.
Originally Posted by SWHEATON View Post
Oil or fuel fouled?
Might be a little of both. Its fresh but burning more oil than I would be comfortable with but also feels like something is beng held back when he opens it up. All the parts are in good condition or new. Base timing is 16-17 degrees initial with 37 total.
The problem is the heads are angle plug and the headers are not ment for angle plugs. He dimpled tubes and re positions one of them to clear. They CAN NOT be any longer than the Accell shorty plugs.
post #12 of 23 (permalink) Old Apr 28th, 12, 2:15 AM Thread Starter
Banned
Anthony
His shorty plugs are a different part number than your showing and they are quite a bit shorter than a regular plug. There is no room for any longer plugs. They will hit the header tubes.
post #13 of 23 (permalink) Old Apr 28th, 12, 4:08 AM
Accel also makes silver tip plugs that can be had in the shorty version. Just add another "S" to the part#....for instance, the 416S plug would be 416SS for the shorty silver tip. I don't know if the silver tipped ones would actually be less prone to fouling or not though.
BillyGman is offline
post #14 of 23 (permalink) Old Apr 28th, 12, 9:03 AM
Dave 383 now
Ok for your aluminum Darts, use a NGK FR4
Dave427 is offline
post #15 of 23 (permalink) Old Apr 28th, 12, 11:19 AM
/\/\ikey
I could use a shorter plug. Whats his part number?
2012 GMC Terrain
2011 Chev Silverado
2004 Chev Silverado
http://www.chevelles.com/forums/showthread.php?t=386745
Mikeys69 is offline
