1970 Chevelle Pro Street - Chevelle Tech
post #1 of 9 (permalink) Old Jan 2nd, 12, 11:11 PM Thread Starter
Big Mook
Arrow 1970 Chevelle Pro Street
Will I be ok to run stock disk brakes up front and then run a disk brake set up in the rear from whom ever has the best deal for my early big 9 inch ford that is in the rear ( Wilwood,Baer or possibly Cpp) with using manual brakes and a proportioning valve???
I really dont want a big booster sticking out of the fire wall for power brakes and yes this is a street car for cruise ins not a drag car however Im also being told that based on what size cam I go with vacuum could be a issue due to cam size with power brakes any ways...
let me know what you guys are all out there using and what your thoughts are? Who has the best deal on purchasing brakes and coil overs I need both Thank you
blonby1970 is offline
post #2 of 9 (permalink) Old Jan 2nd, 12, 11:21 PM
Re: 1970 Chevelle Pro Street
I would think the stock ones would be ok. I used mine for a super long time on teh setup your talking about. for crusing.. yes.
I Dont need You to Like Me. Remember That
bosshog is offline
post #3 of 9 (permalink) Old Jan 3rd, 12, 12:19 AM
Send a message via AIM to mc71454
I can stop my Monte from 129 mph with factory manual brakes front disc / rear drum no problem.
Tom B
'71 540 Street/Strip Monte Carlo 10.310, @ 129.86, Pump Gas, Full Exhaust
'70 Chevelle, 462, 3.42's, 12.35, 1.66 60', 107.0 4020 lbs. Full exhaust Pump Gas
'87 Regal Limited Turbo T, Chip & Dual exhaust - 13.08, 1.78 60'
'75 Chevelle S3, 454, Auto (Son's Car)
2015 Tundra TRD Pro Supercharged 5.7
mc71454 is offline
post #4 of 9 (permalink) Old Jan 3rd, 12, 1:23 AM
Levon
I pulled my Camaro down from over 130MPH with stock discs and the big Ford drums. Get the proportioning right and you should be OK. Getting 4 wheel discs "balanced" is an art but they work great when set up well.
Levon Hovagimian
Team Chevelle #279
70 Chevelle SS 454 LS5 4 speed.
1966 427 Corvette SOLD
Priddis, Ab. Canada
My Showroom
LevonH is offline
post #5 of 9 (permalink) Old Jan 3rd, 12, 3:03 AM
This might get more replies in the brake section?
GREENHELL
377 sb, 5 speed, 4:11's
Line Loc Works!!
HeLLcamino,357 sb, 700R4 with lock up, 3:73's
The Bad Weather Beater
CHELKAMINO is offline
post #6 of 9 (permalink) Old Jan 3rd, 12, 4:55 PM
bear
i'm running stock front disc with cpp rear discs. they work fine . really don't notice much difference from front disc w/ rear drum.
TBotnen is offline
post #7 of 9 (permalink) Old Jan 3rd, 12, 7:14 PM
Nick
Are you running power steering? If so and you want power brakes, go hydro boost brake assist.
70SS540 is offline
post #8 of 9 (permalink) Old Jan 3rd, 12, 10:43 PM
Mark
Agree 100% especially if you are concerned about making vacuum. My hydro boost works amazingly great with front disc rear drum. I use Hawk pads. Stops quick everytime. Make sure your power steering pump has a standard size reservoir not a small one.
Mark
68 RS SS L78 Camaro #'s match mostly original
70 SS (clone) 540 Finally done
http://s109.photobucket.com/albums/n66/Mstehle/
Mstehle is offline
post #9 of 9 (permalink) Old Jan 3rd, 12, 11:09 PM
Royce
If you want to save some money, take a look at Speedway Motors for your rear disc brake kit. They have about the best deal out there.
Royce (NO XQSSS) Bradley
www.facebook.com/driveyourjunk
Short Video w/sound Blown SBC 1961 Skylark, Borla mufflers and 3 1/2" exhaust.
http://www.youtube.com/watch?v=DSLsGgDjFXE
camaroman7d is offline
