Mild "budget" 350 cam ... suggestions - Chevelle Tech
post #1 of 32 (permalink) Old Oct 23rd, 11, 4:54 PM Thread Starter
I'm putting together a mild .060 over 350, that's going into a '70 El Camino, that will be sold. 8.5-9 to 1 (probably closer to 8.5), 882 heads, headers, Performer manifold, 1850 Holly. Vehicle will have a 3.36 rear end, and a stock converter. The CC 260 ,12-206 cam, ( 260/260, 212/212, .440/.440, 110, 1200-5200, .... and lifters have met their life expectancy, judging by the very noticable concave surfaces of the lifters.
As noted, this a budget, and also unplanned, rebuild. I'm hoping to find a cost effective cam with similar characteristics, from a source other than the highly promoted cam companies. Any suggestions? Thanks
Work in progress:
1970 Chevelle
- 540 /325 AFR's / HR cam
- 4L80E
- 9" 3.89's/ Detroit Locker w/35 spline axles
http://www.marklevinshow.com/sectional.asp?id=32930 RECOMMENDED LISTENING - Audio Rewind past show
brimac is offline
post #2 of 32 (permalink) Old Oct 23rd, 11, 6:29 PM
Tim
Re: Mild "budget" 350 cam ... suggestions
how about the isky 264 mega cam ? i think it would work well with what you have.
grovey is offline
post #3 of 32 (permalink) Old Oct 23rd, 11, 7:12 PM
Banned
Anthony
you can get the Elgin copy of the crane 274HO6 from several places for about $100 for cam and lifters. with the 106LSA it will have a nice choppy idle. might help the sale if it sounds hotter than it really is.
sschevellefan is offline
post #4 of 32 (permalink) Old Oct 23rd, 11, 8:56 PM
Hollis
http://www.summitracing.com/parts/SUM-K1102/
Cheap, tons of low end, and not from a major cam company....
hferris is offline
post #5 of 32 (permalink) Old Oct 23rd, 11, 9:20 PM
Phil
Good advice right there. Elgin cam/lifter kit, part # E1785PM. It's $113.95 at Competition Products. Also sold under Summit Racing part # SUM-K00172 for a little more.
71 Chevelle SS
zz502 (Straub Cam, RPM Airgap, ProSystems Carb, MSD, etc.)
Rossler TH400
Built 12 bolt 4:11
Pics
Video
Slick71ss is offline
post #6 of 32 (permalink) Old Oct 23rd, 11, 9:42 PM
Banned
Anthony
northern has it for $99 cam/lifters but with shipping to me at least ends up being about $115. The summit cam hferris linked to would be good also.
post #7 of 32 (permalink) Old Oct 23rd, 11, 11:33 PM
George
are the heads off?
if so, get a GMPP shim head gasket in there, build a tad more compression.
Then cams should have a little advance ground into them. Consider advancing the cam a tad more for more low end power
George Kettler
http://public.fotki.com/kettbo/gearhead/
o 68 Camaro Vert 327 project, painted, assembly stage http://www.camaros.net/forums/showth...183654&page=55
kettbo is offline
post #8 of 32 (permalink) Old Oct 24th, 11, 12:34 AM Thread Starter
Originally Posted by kettbo View Post
are the heads off?
Yeah, I've thought of that and I like the idea. It's evident that the block has been decked, at some point, but that was before I acquired it, 25 + years ago. Maybe it's still straight. Block is at the machine shop currently, ... I'll have them check it for straightness. The heads going on it, have been surfaced, but not milled. What's the part number of the GMPP gasket you're referring to?
Work in progress:
1970 Chevelle
- 4L80E
brimac is offline
post #9 of 32 (permalink) Old Oct 24th, 11, 12:53 AM
George
my pal Greg bought some from the local Chevy dealer a year ago...
pretty sure it was this one
http://www.streetperformance.com/par...-10105117.html
George Kettler
kettbo is offline
post #10 of 32 (permalink) Old Oct 24th, 11, 1:17 AM
Scott Foxwell
Not sure wht the specs were, but the 300hp 327 cam worked pretty well in a mild 350.
FOXWELL MOTORSPORTS
STRAUB TECHNOLOGIES
Performance Cylinder Head Specialties
Custom Engines and Camshafts
Retail/Wholesale Parts Sales
New CANFIELD BB CHEVY cylinder heads now available.
http://www.chevelles.com/forums/members/46633-steelcomp.html
steelcomp is offline
post #11 of 32 (permalink) Old Oct 27th, 11, 4:31 PM Thread Starter
I still have not yet decided on a cam. Maybe a few more specifics would help. Given my combo, what would be the most duration allowable, ... that still produces good vacuum, and works with a stock converter? Think I'll end up at 9 to 1 after all. Thanks
Work in progress:
1970 Chevelle
- 4L80E
brimac is offline
post #12 of 32 (permalink) Old Oct 27th, 11, 4:52 PM
Jake
Voodoo 60102
Almost any of your "256", "262" or "268" cams.
1972 Malibu Sport Coupe - Victory Red on Black - 350/TH350
I do all my own stunts.
Highway Star is offline
post #13 of 32 (permalink) Old Oct 27th, 11, 6:19 PM
jimmyradford
My high school DD had a 350 w/specs like yours. I put a Crane Fireball 290 in it, had a great sound and lots of low end TQ. It was .454" lift I/E, 216*/216* duration and110 LSA.
It looks to have been replaced with the Energizer 272.
TC Member # 4431
'04 Ram Quad-That thing has a Hemi in it!
'68 El Camino-SB 350/TH400/???
'67 Hell Camino-BB 496/TH400/???
'55 BelAir 2 door post-427/TH-400/4.10
"Good people sleep peacefully in their beds at night only because rough men stand ready to do violence on their behalf."-Orsen Wells
badrad is offline
post #14 of 32 (permalink) Old Oct 27th, 11, 7:23 PM
Enrique
Send a message via AIM to Slowpoke70 Send a message via Yahoo to Slowpoke70
Major cam company, and specifically the same one you're using now, but may I've talked to have told me the Comp Cams 268AH-10 is a great street cam for a mild 350. Not to be confused with the standard single-pattern 268H.
http://www.summitracing.com/parts/CCA-12-318-4/
222/226 268/276 .464/.464 110LSA
There's also the 260AH-10 which is closer in size to your current cam, with a little more exhaust duration.
http://www.summitracing.com/parts/CCA-12-312-4/
212/218 260/268 .444/.444
Change the -10 to a -8 on either cam to get it on 108LSA for a little more lumpy idle and light-switch-like-response when it gets into its groove.
1970 Malibu
355/TH350/3.36
Isky z25/Sportsman2/300-36/Summit Headers
Slowpoke70 is offline
post #15 of 32 (permalink) Old Oct 28th, 11, 4:54 AM Thread Starter
This "budget" cam caught my eye. Lunati Bare Bones 10001lk. Description is: Good idle for daily usage or towing, Good low end and mid range. 1500-5000, .443/.465, 214/224, 280/290, 112/107 LSA. It appears that this combination of lifts, durations, and LSA's produce, a friendly cam. However, the longer durations, have me wondering. Any thoughts? Thanks
Work in progress:
1970 Chevelle
- 4L80E
brimac is offline
This Thread is more than 958 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
