Suspension suggestions - Chevelle Tech
post #1 of 100 (permalink) Old Aug 17th, 11, 6:49 PM Thread Starter
Vinny Vince
I cant blame the track anymore.
I have stock springs, sway bars, and replacement HD shocks. I do have SSM/Jegs bars and Eddy adjust uppers. I have tried ET Streets (bias), ET DR's, and the Hoosier DR's. Just blows the tires off.
What can I do here to get the thing to hook, but still remain 100% streetable? I'm keeping the Hooiser DR's - I like the way these track straight.
Stick car dont forget!!!
*11 C6, 6.2, 6spd
69-CHVL is offline
post #2 of 100 (permalink) Old Aug 17th, 11, 7:30 PM
Re: Suspension suggestions
I'd try the Edelbrock hop stops. you might need to put stock type lowers though.
do you get rear body lift at launch? any vids from the side?
post #3 of 100 (permalink) Old Aug 17th, 11, 7:36 PM
Right with you Vince. I had tried the UMI Relocate brackets. Didn't really see the improvement I was looking for. I am strongly considering the Art Morrison No-Hops. Don't need a lot of lift in the rear, but do think some would help. But, I kinda wonder if something like a relocated upper is better for an automatic car where you apply power and keep it there as opposed to a stick where the power will be an on/off kinda deal.
GRN69CHV is offline
post #4 of 100 (permalink) Old Aug 17th, 11, 7:37 PM
Rich
I think Vince has already tried no hops....
I would try ladder bars and tube axle in the front....j/k
Vince I think may some drag springs and soft front shocks but it would probably affect drivability.
I still have some NIB eddy no hops if you want to try them.
1969 Chevelle Malibu
496 /th400/ford 9", 3.70 gears.
Best Time: TBD
Old Best:
408 big block / th350 / 4.11 powertrax 10 bolt
11.988@113.39 on BFG drag radials
1.782 60'
A.C.E.S. # 7037
http://www.chevelles.com/showroom/da...dium/MCC01.jpg http://www.chevelles.com/showroom/da...C_Show_015.jpg
69bu is offline
post #5 of 100 (permalink) Old Aug 17th, 11, 7:54 PM Thread Starter
Vinny Vince
I had the Eddy no-hops and replaced them with the SSM's. The Eddy's were too violent if that makes sense - they hit the rear to hard, and caused alot of body separation during each gear change.
No vids yet.
*11 C6, 6.2, 6spd
69-CHVL is offline
post #6 of 100 (permalink) Old Aug 17th, 11, 8:14 PM
I realize the drag shocks and trick springs say not to use them on the street, but I have done so for years - carefully.
I don't drive like a kid in a honda on the streets... I drive knowing my car doesn't handle as good as the car in front of me; cautiously.
Aside from that, you said sway bars... have you considered removing the end links on the front sway bar when you take the car to the track?
100% streetable means something different to everyone. Often sacrifices have to be made to make the car better at the drag strip. Best of luck.
_____________________________________
68 Chevelle
flat top 406, AFR 195's, XR286R, RPM AirGap
750 Holley DP,TH400 w/brake, 4000 stall FTI
3.31 gear, 12 bolt
... for now.
Yellomalibu is offline
post #7 of 100 (permalink) Old Aug 17th, 11, 8:57 PM
Wilson
Vince, I have gotten quite a few 1.54 60's. I run stock rear springs, adjustable uppers and boxed lowers and the SS style reinforcement bar all by Edelbrock. QA1's single adjustable shock set at 8 at the track. Back to zero for the street. H&R bar. Up front 289 springs and Koni Classic's set on soft. No front sway bar. Stock control arm bushings and torqued to factory spec's. M/T Drag Radial's @16lbs. Car drives really smooth on the street. Handling would be really good if I put the front sway bar on.
NAPA PARTS GUY
1970 SS396 Build Sheet Documented
496 10.5 UD Harold 243/249 650 Net SR, AFR/290's, Victor Jr. PS/1000HP, Pump Fuel
3000 Stall TH400 3.55 MT DR's 3980 w/Driver
Best ET 1.54 7.04/96.21 11.17/118.51 @ Musclepalooza Etown 2010
wilmaya is online now
post #8 of 100 (permalink) Old Aug 17th, 11, 9:08 PM
cut 3/4" out of the hop stops and try them again.
jeez, is there enough room to do that?
What a guy really needs is hop stops with adjustable height for the upper bushing.
post #9 of 100 (permalink) Old Aug 17th, 11, 9:37 PM
I agree adjustable good adjustable shocks front and rear Singles should be fine make sure they have as much travel as your suspension ........disconnect sway bar on track day
Stik car right ? Your correct dont need/ want alot of anti squat ( separation) but you can move your IC back some you dont want rear to squat depending on your tires some separation may help, tune that with shocks to allow some extension on launch,fyi with bias slicks mine works best with no separation/ shocks on 80% stiff get car as low as possible in rear ........level with front is great if possible I would reinstall the stock type lower control arms .......rear upper control arms check to see if you can redrill the factory front mounting holes lower ( 66/67 cars you can redrill down 3/4 inch ) that will move you IC back but not as dramatic as no hops none of this will effect street use .......... FWIW
Have you ever tried bias stiff sidewall slicks ??
Was 439ci Straub Solid Roller Brodix RR,
SOLD
,Tremec by Liberty
10.97/ 124.31 1.41 60ft
New Foxwell 475ci Power ready to go back in
Crusin / Track video http://www.youtube.com/watch?v=fhvDGOO4JAI
Engine
CDN SS is offline
post #10 of 100 (permalink) Old Aug 17th, 11, 10:00 PM
good idea, redrill the front mount points of the upper arms.
post #11 of 100 (permalink) Old Aug 17th, 11, 10:33 PM Thread Starter
Vinny Vince
Car sits pretty level. Rather not get rid of the ssm bars/adjust uppers right now. So shocks make a big difference? Do I need to spend the money for those adjustable shocks? The QA1's are like 150.00 a piece! But if they make a difference, I'll consider them. My front springs are very stiff, but I kinda need them so the car doesnt bottom out driving around.
*11 C6, 6.2, 6spd
69-CHVL is offline
post #12 of 100 (permalink) Old Aug 17th, 11, 10:44 PM
If you want to get your car to hook and then still have a good street handler then yes decent adjustable shocks should be considered ... allow you to tune for both situations QA1 would not be my 1 st choice ( Like alot here I had them got rid of them ......... you want to keep adj uppers especially if you redrill the mount location .. are those SSM control arms close to parallel with the ground when car a rest ??
SOLD
,Tremec by Liberty
Engine
CDN SS is offline
post #13 of 100 (permalink) Old Aug 18th, 11, 1:09 AM
the SSM are lowered in the back, not level at all. That's their main claim to fame, what alters the geometry.
post #14 of 100 (permalink) Old Aug 18th, 11, 1:34 AM
George
I tried the UMI re-lo kit early this year. Maybe right for someone with a different combo, not right for me. Violent hit, destroyed the traction.
I have boxed factory type LCAs, Konis set on stiff, generic rear springs, passenger air bag. Nothin fancy
best of 1.620 using the BFG DRs 275/60 (28 dia), lots of 11.7s
runs 1.63s all day
with a bad track, early FRI, runs 1.7s and 12.0-11.9 so I have mounted up some bigger 295/55 (29 dia) so hope to launch from the get go so as to have performance tuning enhancements rather than suspension tweak every week
betting the taller rubber will get the lca level to the pavement
George Kettler
http://public.fotki.com/kettbo/gearhead/
o 68 Camaro Vert 327 project, painted, assembly stage http://www.camaros.net/forums/showth...183654&page=55
kettbo is offline
post #15 of 100 (permalink) Old Aug 18th, 11, 5:14 AM Thread Starter
Vinny Vince
Yeah, the SSM bars are lower boxed control arms with the arms tilted downwards. I installed them based on a few folk's recommendation here on how good they work, and the fact that they cured my severe wheel hop problem.
Pretty sure I have just about no front end rise as it is. I'm ok w/disconnecting the front sway bar. Shocks - sounds like this should be done regardless. Can you guys recommend some shocks? Even if I have to change them out for race day, so be it - that doesnt take so long to do.
*11 C6, 6.2, 6spd
69-CHVL is offline
This Thread is more than 2106 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
