Glass Holley Sight Plugs? - Chevelle Tech
post #1 of 21 (permalink) Old May 13th, 11, 4:00 PM Thread Starter
Question Glass Holley Sight Plugs?
Does someone make actual glass fuel bowl sight plugs for 4150 Holley carbs?
The Holley plastic sight plugs, e.g., Street Avenger series, seem to start dissolving instantly.
It'd be great if there was a nice non-leaking, non-frosting, non-dissolving glass sight plug that you could leave installed 24/7.
Hope there is a source for such.
Thanks!
Euell Florett is offline
post #2 of 21 (permalink) Old May 13th, 11, 4:09 PM
Davey
Re: Glass Holley Sight Plugs?
you might see if you can get some from Prosystems, mine don't leak at all.....
Chevelle
http://www.firstgenmc.com/photopost/...um/david_4.jpg
SloMo...
https://www.youtube.com/watch?v=Fa13syTsA0E
'67 Chevelle 516 hyd roller
4.11's
9.06 best mph 147.75
5.73 best mph 119.98
3520 lbs to 3570 depending on fuel
1.26 60 ft
Straub/Foxwell
Motor by Mark Jones
E-Store at
crazydaveyracing.com
Davey..
TC Gold Level Know it All
crazydavey is offline
post #3 of 21 (permalink) Old May 13th, 11, 4:13 PM
Dal
Proform sells the bowls with the glass inserts. There aren't any screw in that I know of.
70 Chevelle - 3300#
NA 517, 1.26-60' so far, more to come.....
Straub, Foxwell, HBR
Killerrons
NA 511, 1.29, 5.83@118.42, (9.24/25 @ 144+)
______
CrazyDaveyRacing.com
dtrubey is online now
post #4 of 21 (permalink) Old May 13th, 11, 4:16 PM
Louis
Thanks!
Good old fashon brass plug will work fine. Unless you are taking drugs and look at the sight plug and watching gas slouching around like a tumbling washing machine and look at the window and saying "Hey man... that looks groovy.... wow!!"
Louis
Original owner
http://www.youtube.com/watch?v=wCG7lnacgGg
https://www.youtube.com/watch?v=53OG2K2P9vQ
lg1969 is offline
post #5 of 21 (permalink) Old May 13th, 11, 4:18 PM
Davey
where the hell is Bohemia??
Chevelle
SloMo...
4.11's
1.26 60 ft
Straub/Foxwell
Motor by Mark Jones
E-Store at
Davey..
post #6 of 21 (permalink) Old May 13th, 11, 4:20 PM
Louis
Right smack dab in the middle of Long Island.
Louis
Original owner
lg1969 is offline
post #7 of 21 (permalink) Old May 13th, 11, 4:44 PM
Davey
that's a name I just wouldn't think of for NY.....of course Yucaipa......never mind.....
Chevelle
SloMo...
4.11's
1.26 60 ft
Straub/Foxwell
Motor by Mark Jones
E-Store at
Davey..
post #8 of 21 (permalink) Old May 13th, 11, 4:49 PM
Louis
Yeah, I can't even pronounce Yuca.... What???
Louis
Original owner
lg1969 is offline
post #9 of 21 (permalink) Old May 13th, 11, 4:53 PM
Keith
I set the float levels when I first put the present carb on our L78 and that was 7-8 years ago. I've never seen much reason to be checking float levels very often. They never changed. I just use the stock Holley stuff.
Keith Tedford is offline
post #10 of 21 (permalink) Old May 13th, 11, 5:18 PM
Louis
Davey, If you care to come to long Island you can go to a cruise night, We got plenty over here. We have it on Tuesday, Thrusday, Friday, Saturday, Sunday Morning. 100 to 500 Cars or more a night. 200 Sunday morning. All 120 miles on the Island. (Only 15 miles wide... Who cares anyway). http://www.hotrodders.com/gallery/sh...0&ppuser=63792
Louis
Original owner
lg1969 is offline
post #11 of 21 (permalink) Old May 13th, 11, 6:39 PM Thread Starter
Thanks, Davey & Dal!
Thanks for your helpful replies!
Any other responses as to potential sources for:
glass replacements for the plastic Holley fuel bowl sight plugs?
post #12 of 21 (permalink) Old May 13th, 11, 9:05 PM
The Holley that's on my 57 Chevy truck, I set the floats 9 years ago when I built the carb. Never adjusted them again, never had the brass sight plugs out.
I don't screw around with it and it doesn't screw around with me.
Ever notice that guys don't constantly screw around with the floats on Q-jets, Carters, Edelbrocks, Webers, etc, etc? If the floats on those carbs were externally adjustable guys would be screwing around with them all the time, installing glass sight plugs, getting into debates on technique, frequency of adjustment, minute differences of fuel pressure and its' effects, etc, etc. The float/needle&seat assembly is not substantially different on the externally adjustable Holleys than those other carbs. Set it, forget about it.
Heresy, I know.
Know what else? I've never owned or spent even one dime of my money on one of those MSD red brick things you see on so many firewalls. Never will. Guess I must be just a total hot rod failure......
I think I'll change the air in my tires this weekend. Get some overpriced double throwdown super trick air and install it.
post #13 of 21 (permalink) Old May 13th, 11, 9:19 PM
& Administrator
If you go for the aftermarket glass or plastic sight plug buy a good fire extinguisher.
Mike is offline
post #14 of 21 (permalink) Old May 13th, 11, 9:19 PM
/\/\ikey
Send a message via MSN to Mikeys69
Thanks!
Got no idea what your talking about. Mine has never leaked, frosted or dissolved. But then again I use gas in my carb.
2012 GMC Terrain
2011 Chev Silverado
2004 Chev Silverado
1969 Chevelle Malibu 406 SB
http://www.chevelles.com/forums/142-projects-builds/386745-mikeys69-chevelle.html
Some day I will own a 1967 Chevelle, again.
Mikeys69 is offline
post #15 of 21 (permalink) Old May 14th, 11, 6:59 AM
IS there ETHANOL in the gas in Canada? That is what is eating the sight plugs.
TC#3095
dreis454 is offline
This Thread is more than 2174 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
