496" BBC Build - Chevelle Tech
post #1 of 65 (permalink) Old Feb 15th, 11, 7:35 PM Thread Starter
496" BBC Build
I'm officially starting my build thread for my next BBC.
This will be an on going thread showing progression from beginning to end results on the engine dyno.
This is going to be a 496" pump gas BBC.
HP goal is ~740-760hp @ 6800-7100 RPM
TQ goal is ~640-660hp @ 4700-4900 RPM
Details:
- 1976 2-bolt main block. Yes, I'm going to test the strength of a studded 2-bolt block with this build.
- Forged 4340 internal balance 4.25" stroke crank
- Forged 4340 H-Beam 6.385" rods w/ ARP 2000 bolts
- Mahle 18cc small dome 4.310" coated pistons
- Rotating assy is balanced to 0.1 gram
- Mahle regular tension ring pack
- Clevite H Bearings on rods/mains
- Block is @ machine shop getting line honed, bored +.060", honed with tq. plates, parallel decked, setting deck height to 9.786" leaving the pistons .006" in the hole, running an .039" gasket gives a ~.045" quench.
- Dart Pro 1 335cc CNC heads. 2.30 Intake valve, 1.88 Exhaust valve. Stock 121cc chambers yields ~9.91:1 SCR
- I was thinking about having the heads milled to 114cc to get a 10.56:1 SCR but I don't see the HP/$ gains worth it. 0.5 point of compression which = ~10 hp not worth $250.
- Dart single plane intake
- Pro-Systems 4150 1000hp carb
- Preliminary billet solid roller cam specs are:
275*/285* @ 0.050"
.720"/.690" Gross Lift
109 LSA installed on a 106 ICL
- Isky Red Zone EZ roll lifters
- 1.8 stud mount Harland Sharp Rocker
- ARP fasteners throughout
A pretty basic deal really.
Pics:
Rods (chinese junk)
Mahle's Powerpak Coated Pistons
'90 454SS
'91 ZR-1
WVU454SS is offline
post #2 of 65 (permalink) Old Feb 15th, 11, 7:36 PM Thread Starter
Re: 496" BBC Build
Pro-Systems Carb
Block being cleaned and deburred prior to machining
Starting on the lifter valley
Also deburring the outside so it will look pretty with some black paint on it
Outside almost finished
Stay tuned for more!
'90 454SS
'91 ZR-1
WVU454SS is offline
post #3 of 65 (permalink) Old Feb 15th, 11, 7:45 PM
MARK
Re: 496" BBC Build
Details:
275*/285* @ 0.050"
Pics:
Rods (chinese junk)
Well you didnt ask for opinions, but I cant resist. You dont have enogh compression to make that cam work, spend the money and cut the heads. You would be wise to check the stroke on the crank, and rod lengths, and recalculate your deck clearence. Dont forget to knotch the deck of the block.
VORTECPRO is online now
post #4 of 65 (permalink) Old Feb 15th, 11, 7:54 PM Thread Starter
Re: 496" BBC Build
Woops! I meant to add thoughts, opinions at the end of the post.
Thank you for the advice. I guess I will reconsider having the heads milled.
Thoughts on recalculating my deck height? Am I not going about this correctly? How can I go about accurately measuring rod length and stroke?
I'm assuming you mean notching the block for intake valve clearance? Can you elaborate on this a little more?
I'm no engine builder but plan on building this one, and would like to do it as "correctly" as possible. Hence the reason I posted this, for people like you to respond with suggestions.
Thank you,
'90 454SS
'91 ZR-1
WVU454SS is offline
post #5 of 65 (permalink) Old Feb 15th, 11, 8:26 PM
MARK
Re: 496" BBC Build
Thank you,
The intake valve notch is correct. On these cranks the stroke varies quite a bit, as with the rod length. These are the tools I use to check this.
ID:	38955   Click image for larger version
post #6 of 65 (permalink) Old Feb 15th, 11, 8:30 PM Thread Starter
Re: 496" BBC Build
Ok. Thank you.
So I should have everything measured and then set my deck height to where I want based off of the longest stroke/rod combo?
How much does a machine shop typically get for measuring these pieces?
Thanks,
'90 454SS
'91 ZR-1
WVU454SS is offline
post #7 of 65 (permalink) Old Feb 15th, 11, 8:46 PM
MARK
Re: 496" BBC Build
Ok. Thank you.
Thanks,
I cant tell you what they charge. But mix and match rods to the crank throughs to help even them out, theres an "engine building secret"
post #8 of 65 (permalink) Old Feb 15th, 11, 8:46 PM
Re: 496" BBC Build
I think it would be money well spent to box that up and send over to Mark. This way it'll be done correctly and live. But that's just my opinion.
Joe G is offline
post #9 of 65 (permalink) Old Feb 15th, 11, 8:49 PM Thread Starter
Re: 496" BBC Build
Thank you sir!
'90 454SS
'91 ZR-1
WVU454SS is offline
post #10 of 65 (permalink) Old Feb 15th, 11, 8:52 PM
Remi
Re: 496" BBC Build
I`m following this one !
subscribe - check
65 Chevelle, ZZ502 with 11,2:1cr and 242/252 110 cam.
Th400. 3,73. 5200stall.
Best 1/8: 7,058 Best 1/4: 11,17 Best mph: 118,6 Best 60: 1,56
13.6mpg
http://www.youtube.com/watch?v=YD3tlarmKEQ
Bastard 65 project thread:
http://www.chevelles.com/forums/16-brakes-suspension-steering/230714-my-chevelle.html
Rokker is offline
post #11 of 65 (permalink) Old Feb 15th, 11, 8:59 PM
"Wild Bill"
Re: 496" BBC Build
275*/285* @ 0.050"
That cam is HUGE...bigger than any cam I ever ran in my 540 with over a point more compression.
And IMO, those heads are too big for those inches...unless you're planning on turning this to 8K.
Team Chevelle #613
ACES #3920
CAMI (Ireland) #14
CanAm Chevelles #136
Carolina Chevelles #185
Heart Of Dixie #231
Long Island Chevelles #113
BillsCamino is offline
post #12 of 65 (permalink) Old Feb 15th, 11, 9:08 PM
Re: 496" BBC Build
I have out of the box dart 325s on my 10:2 TO 1 496 and it loves rpm....If I short shift it kills the ET
I like anything fast enough to do something stupid with.
1972 El Camino
496 Dart Pro 1 325
Prosystems 1000 hp
TH350 ATI 8" treemaster MRT
14 year old Richmond 3.73 street gears
3" Jegs X-pipe 18" long Dynomax ultra flows
http://www.youtube.com/watch?v=CceOARPAIgk
Best so far 11/14/10 10.45 @ 126 with 1.43 60ft
o6r1man is offline
post #13 of 65 (permalink) Old Feb 15th, 11, 9:26 PM Thread Starter
Re: 496" BBC Build
These are just preliminary cam specs.
I understand the heads probably aren't optimal for the CID and RPM range I'm planning, but this is a budget build and those are the heads I have to work with.
If I could've started from scratch and bought everything new I would use some different parts, but this is what I have and I what I need to work with.
Just trying to get it done on a college kid's budget.
'90 454SS
'91 ZR-1
WVU454SS is offline
post #14 of 65 (permalink) Old Feb 15th, 11, 9:27 PM Thread Starter
Re: 496" BBC Build
How much cam are you running? Where does it make peak power?
'90 454SS
'91 ZR-1
WVU454SS is offline
post #15 of 65 (permalink) Old Feb 15th, 11, 9:27 PM
Re: 496" BBC Build
Nobody here has a 496 that runs worth crap.
I'm in for the follow along, my engine guy still teases that now that mine has gone 5 years, we ought to tweak it a bit. It made 700.
Interesting Dart intake, is that something new? World makes something similar. Since it has a 4500 flange, why not use a real dominator on it?
I used a Brodix HV2001 and a Quick Fuel 1050 custom dominator.
My setup runs pretty good in a 3600 lb. Nova, on pump gas.
Ron
69 Nova
LS Alum 5.3 single turbo, 9.21 @ 149 so far
2000 Corvette C5 Auto LS1 10.99@124
Dyno Operator/Tuner at Dings Racing
Ron454 is offline
