fuel log vs line to each bowl - Chevelle Tech
post #1 of 21 (permalink) Old Dec 7th, 10, 10:24 PM Thread Starter
Guest
given the choice of a fuel log or a fuel line from the regulator to each bowl, is there any difference or advantage over one setup or the other?
curley8788 is offline
post #2 of 21 (permalink) Old Dec 7th, 10, 10:52 PM
Banned
Butch
Re: fuel log vs line to each bowl
I like to run a fuel line to each bowl but just my opinion
trmnatr is offline
post #3 of 21 (permalink) Old Dec 7th, 10, 11:19 PM
Fuel line to each bowl for sure!
If you ever tune you can take the bowls off individually with separate lines -- you don't even have to disconnect the fuel line from the bowl.
Fuel logs do look cool though.
E85 racer and E85 carb builder
www.horsepowerinnovations.com
68 Camaro 427" E85 burning small block. 9.90 @ 135 mph through the mufflers on motor. Best 60' 1.319 on motor. 5.92 @ 116 1/8th mile on spray with 1.425 sixty on the back tires.
http://i29.photobucket.com/albums/c2...tational00.jpg
Eric68 is offline
post #4 of 21 (permalink) Old Dec 8th, 10, 1:11 AM
Banned
Butch
Also is he talking about a fuel log dual feed unit OR a "REGULATOR MANIFOLD"
Some people call a Regulator Manifold a fuel log
trmnatr is offline
post #5 of 21 (permalink) Old Dec 8th, 10, 2:32 AM Thread Starter
Guest
i mean this:
https://www.circletracksupply.com/im...fuellog-01.jpg
post #6 of 21 (permalink) Old Dec 8th, 10, 3:46 AM
Banned
Butch
That appears to be a "dual feed line" and not a log but the pic is so small
This is what I consider a fuel log
http://www.jegs.com/i/Barry+Grant/132/170031/10002/-1
trmnatr is offline
post #7 of 21 (permalink) Old Dec 8th, 10, 7:20 AM
Originally Posted by curley8788 View Post
too many 90* angles
TC#3095
dreis454 is offline
post #8 of 21 (permalink) Old Dec 8th, 10, 11:42 AM
Davey
I'm using this one Mike...works fine....you can change jets without unhooking anything,,,,
http://www.summitracing.com/parts/SU...04-N/?rtype=10
Chevelle
http://www.firstgenmc.com/photopost/...um/david_4.jpg
SloMo...
https://www.youtube.com/watch?v=Fa13syTsA0E
'67 Chevelle 516 hyd roller
4.11's
9.11 best mph 146.19
5.74 best mph 118.90
3520 lbs to 3570 depending on fuel
1.27 60 ft
Straub/Foxwell
Motor by Mark Jones
E-Store at
crazydaveyracing.com
Davey..
TC Gold Level Know it All
crazydavey is offline
post #9 of 21 (permalink) Old Dec 8th, 10, 10:43 PM
wannabe
Main reason to run a log (not really what you have pictured), is if you run a return line and bypass regulator. This way the regulator is completely out of the fuels path to the carb. The regulator is on the outlet side of the log.
Jay Campbell
Campbell Competition Motorsports
jbird is offline
post #10 of 21 (permalink) Old Dec 8th, 10, 11:11 PM
Do you have a link to that one? I like it.
Sinister is offline
post #11 of 21 (permalink) Old Dec 8th, 10, 11:24 PM
wannabe
Summit racing. Do a search.
Jay Campbell
jbird is offline
post #12 of 21 (permalink) Old Dec 8th, 10, 11:29 PM
Wow! That thing is pricey...
Sinister is offline
post #13 of 21 (permalink) Old Dec 8th, 10, 11:46 PM
As long it's not the "double flying trapezes" strung out & over from the fenderwell, it's worth a million.
Bud Crayne is offline
post #14 of 21 (permalink) Old Dec 9th, 10, 2:41 AM
.... This way the regulator is completely out of the fuels path to the carb. The regulator is on the outlet side of the log.
Is that so important? And if so, then why?What is the benefit? And how can the regulator actually keep the fuel pressure that's entering the bowls under 8 PSI if the regulator is not in path leading to the bowls?
BillyGman is offline
post #15 of 21 (permalink) Old Dec 9th, 10, 5:26 AM
^^^^ it's a bypass regulator on the end of a log.
Bypass regulators control pressure by varying the amount of fuel going back to the tank. On a regular bypass regulator the fuel is technically going to the carbs prior to going to (actually through) the regulator.
Here on my setup it's the same thing as a fuel log. Fuel goes in the side under the "A" symbol, goes to each bowl unrestricted, once 8 psi is reached going to each bowl the pressure pushes up on the diaphram and there is a check ball on the bottom that unseats to allow fuel to return to the tank.
i prefer the above instead of a log so you can make jet changes easier. I can leave the lines going to the bowl attached.
Calculated Risk is offline
