180* Fan temp switch..Anyone know where to find one? - Chevelle Tech
post #1 of 36 (permalink) Old Oct 4th, 10, 11:18 PM Thread Starter
Alan
I ordered a Spal 185* on/165* off temp switch that screws into the radiator...WELL, the POS activates at 190* and off at 175* so its not what I am looking for...
Anyone have any idea where to get a GOOD 180* on / 170*ish off temp switch that is the standard 3/8" NPT...?
I'm searching the usual places(jegs/summit etc) and not finding much...only some no name cheapies...
I want this thing to run no warmer then 180*.... This lincoln MK8 fan will cool it down to the 160* stat no problem but it needs to be activated correctly.
I found this switch but I am leary about it since its a no name...maybe its worth a try but....
http://www.partzfinder.com/180_degre.../thg-zfswf.htm
1971 Corvette
496" 657hp/675tq, pump gas
T400, Tight 10" converter
3.36 gears, 3600lb raceweight
10.59@127.51, 1.51 60'
STOCK APPEARING
ShouldntBeHere is offline
post #2 of 36 (permalink) Old Oct 4th, 10, 11:29 PM
Re: 180* Fan temp switch..Anyone know where to find one?
http://www.jegs.com/i/Derale/259/167...oductId=758411
72 Camaro 383 w/Dart pro 1's squishy lifters 3.73 gear.
11.58 @ 114 with a 1.60 60' in a full weight street car.
Southern72 is offline
post #3 of 36 (permalink) Old Oct 4th, 10, 11:36 PM Thread Starter
Alan
Originally Posted by Southern72 View Post
Thanks for the quick work! I did see that one also while searching. I actually need a single pole/spade switch that is self grounding...Not one that is either dual fan(although that would probably work) or just a continuity switch(2 spades that complete a circuit when hot enough)....
I need one that just goes to ground once the target temp is reached. The Spal switches do this but they are too hot to start with and even then activate 5* higher then rated...
Im still looking...
1971 Corvette
STOCK APPEARING
post #4 of 36 (permalink) Old Oct 4th, 10, 11:46 PM
Seems for a 180 stat most kits use a 185 on 170 off. here is a single spade self grounding but as i mentioned 185 on.
http://www.jegs.com/webapp/wcs/store...Term=555-10562
post #5 of 36 (permalink) Old Oct 4th, 10, 11:49 PM
I would buy one of the 30 dllr adjustable jobbies and dial it in to turn on and off wherever you want.
http://www.jegs.com/i/Flex-a-lite/400/31147/10002/-1
post #6 of 36 (permalink) Old Oct 5th, 10, 12:02 AM Thread Starter
Alan
Looks like the Derale switch you linked first may work...I looked it up on their website and it is self grounding, it just has 2 spades for dual fans. Its the only one I have found with a 180* on temp..... I may give it a shot.... I really want to keep this thing at 180* or less...
Thanks for your efforts!! I will hunt around some more in the morning and if I don't find anything I will try out the Derale switch....I just hate to keep dumping $30 each on these switches until I find one that works....
1971 Corvette
STOCK APPEARING
post #7 of 36 (permalink) Old Oct 5th, 10, 12:09 AM
MARK
You will find the switch your looking for, is an on and off switch.
VORTECPRO is offline
post #8 of 36 (permalink) Old Oct 5th, 10, 1:01 AM
chris
Is your switch on the inlet or outlet tank? If it's on the outlet side, I would expect the temp range to shift up and narrow like you're seeing.
68malibubbc is offline
post #9 of 36 (permalink) Old Oct 5th, 10, 8:57 AM Thread Starter
Alan
The switch is on the left(driver side) tank...just under the upper radiator hose inlet. I didn't think about the sensor location varying the temps....hmmmm
I would still think since it's on the inlet (hot side) of the radiator would work accurately.
1971 Corvette
STOCK APPEARING
post #10 of 36 (permalink) Old Oct 5th, 10, 9:30 AM
Let us know how it works out.
myraceplace.net (buy-sell-trade)
badss540 is offline
post #11 of 36 (permalink) Old Oct 5th, 10, 10:29 AM
Have you checked Zirgo?
http://www.thehoffmangroup.com/zirgo...c=tempswitches
1st project 67 chev sedan, long gone.
2nd project 64 malibu SS 327 4spd major regret in selling for next project
3rd 56 chevy, my to be drag car sold for current.
Current 65 impala ss, bbc 427 with auto gear m22 4spd
65 Imp SS is offline
post #12 of 36 (permalink) Old Oct 5th, 10, 11:09 AM Thread Starter
Alan
You know I DID see the Zirgo 180* switch...I kind of questioned it's quality as I have never heard of that brand of anything but....Summit sells them, it may be the best bet. I wouldn't mind one of those adjustable dealies I could set if right where I want it but those all have the probe thing...I want to use the type that puts the sensor in the coolant, not the fins.
I may just roll the dice on the zirgo. I will let this thread run until this afternoon and see if anyone else posts up ideas, if not then I'll try the Zirgo and hope it's accurate..
Thanks bro..
1971 Corvette
STOCK APPEARING
post #13 of 36 (permalink) Old Oct 5th, 10, 4:11 PM
I have heard of Zirgo but never actually used them. Could google and see what others think. I myself have a maradyne which is a 185 deg one. Had thought about trying something lower like the zirgo but really have not had any issues for me to try it.
post #14 of 36 (permalink) Old Oct 5th, 10, 4:22 PM
How about an adjustable switch, so you can put it where you want it?
I got mine from Flex-A-Lite- works great!
See my Pro Touring '67 Chevelle Wagon at:
http://www.flickr.com/photos/1192966...7594110671642/
Winner- 2011 Car Craft "Real Street Eliminator" competition
Scotch is offline
post #15 of 36 (permalink) Old Oct 5th, 10, 4:24 PM
CHRIS
CARUEST or Standard ignition parts seller TS87 screws into any edlebrock etc. intake.
69XF is offline
