406 SBC cam recommendation - Chevelle Tech
post #1 of 18 (permalink) Old Mar 23rd, 10, 8:38 PM Thread Starter
Question 406 SBC cam recommendation
A friend of mine with 406 small block in a 65 Chevelle needs a cam recommendation from the "real pros" It's a weekend cruiser with appox. 10:1 CR. Turbo 400 with a 2400 stall converter and 3:55 gears. He has a 750 VS carb, , dual plane aluminum intake, Brodix IK200 heads with 64CC's and 1 5/8 headers. He needs enough vacuum for power brakes.
He wants to run a hydraulic flat tappet cam (I know ) So far Comp Cams tech said to run a XE284 (240/246 507/510) Thier own website recommends a 2800+ stall for the XE284, so I don't know why they would recommend it The next smaller cam XE274 is 230/236 duration, 490/490 lift which I thought would be a better fit if using a Comp XE.
I prefer Lunati, so my suggestion would be the Vodoo 60103 which is 227/233,
.489/.504
What do you guys think of these choices in this 406?
Any suggestions?
Mike72ss is offline
post #2 of 18 (permalink) Old Mar 23rd, 10, 8:44 PM
Dave 383 now
Re: 406 SBC cam recommendation
They recommended that cam because thats how it is rated in a 350. In a 406 minus 500 rpms so they are pretty close to the right shaft.
Dave427 is offline
post #3 of 18 (permalink) Old Mar 23rd, 10, 11:58 PM
Tim
In 383 and 400 small blocks I have best results with single pattern cams.
Here's the magic hydraulic flat tappet 400 SBC cam.
Lunati pn 30106 - 234/234/488/488/110/106
It's listed as an oval track cam for two barrel 350 engines but it's a great 400 street cam. I tried a lot of flat tappet hydraulic cams and this one is it.
Timmy is offline
post #4 of 18 (permalink) Old Mar 24th, 10, 12:09 AM
Ron
Im running a VERY VERY combo similar in my car. Im running a Comp XS274S solid flat tappet. I would go for the XE274 if you want the hyd. This cam has great street manners and still runs great at the track. Has gone 11.89 at 115 untuned. I think the XE284 is a bit to much cam for the 2400 converter. I would want at the very least a 2800 with that cam.
69 Camaro
491/AFR 315/Straub hyd roller
TH400/GV OD/9" 3.50
dirtlips408 is offline
post #5 of 18 (permalink) Old Mar 24th, 10, 12:23 AM
This is my example , a 68 elcamino 406 ,10.2 c0mpression , dual plane , 780 holley , topline 220 heads , hyd flatt tappet crane 284h06 , its 226 @ .050 ,and .470 lift on a 106lsa ,single pattern , i ran a th350 ,2400 converter ,3.73 gears and 28x10.5 slicks . it ran good 12.50 @ 110mph . NOTHING special . i would guess in alot lighter car very low 12s.
Another killer grind is isky 284mega , its 236@ .050 and .510 lift on a 106lsa .
Jason Snyder is offline
post #6 of 18 (permalink) Old Mar 24th, 10, 5:59 AM
kevin
.489/.504
Any suggestions?
I have a 67 with A very similar combo I have a lunati bracket master 480lift 230@50 292adv. 109lsa it drives nice and makes pretty good power . the car ran 12.80 with no tuning on regular radials.
67 chevelle 406 10-1 200cc dart iron heads lunati hyd flatt tappet 480 230 cam perf rpm 750 holley vac sec. 3200 edge stall 3.73 gears 12.23@109 1.74 60ft ***SOLD***
1968 Camaro in progress stock 5.3 with a 75mm turbo for the wifes driver.
1972 Nova 427 BBC ,TH400,3500 stall,9"rear 3.55s track times soon to come.
67chevelle406 is offline
post #7 of 18 (permalink) Old Mar 24th, 10, 4:53 PM Thread Starter
Thanks for all the real world recommendations guys. I will have him take a look at those Lunati's and that Isky Mega 280.
Mike72ss is offline
post #8 of 18 (permalink) Old Mar 24th, 10, 5:20 PM
joe
X2
or a isky 280mega I ran low 12, high 11, in a 408sbc 71 Nova, TH350/2500 stall & 4.10 gear.
tonkas69 is offline
post #9 of 18 (permalink) Old Mar 24th, 10, 6:05 PM
Team Camaro
280H Comp cam (.480 lift,230* I/E,110 LSA)
406ci SBC
200cc heads
VicJr intake
stock crank
5.7" rods
2200 stall
3.73's
3450# w/ driver
12.3's @ 110
68 Camaro~406ci
RedЯum <-Pics
11.304 @ 119.05 ~1320' NEW (3/19/11)
http://youtu.be/48OfD_C4JWU <-11.36 Vid.
Some days all you can do is just smile
DOUG G is offline
post #10 of 18 (permalink) Old Mar 24th, 10, 6:12 PM
.489/.504
Any suggestions?
VOODOO 60103= weekend cruiser needs torque. You can not beat that cam with it's fast ramps in a HFT cam unless you go custom roller. dual pattern cam is best with aftermarket heads on the STREET ..IMHO
1966 Chevelle 300 Deluxe Post, 327cu AFR180CC Street Eliminator, Voodoo, Harland Sharp 1.6 RR, Weiand Stealth Airstrike, 650cfm avs, MSD 4spd 355 posi
http://i183.photobucket.com/albums/x...2/P1010428.jpg
http://i183.photobucket.com/albums/x...2/P1010429.jpg
66 BRONZE is offline
post #11 of 18 (permalink) Old Mar 26th, 10, 10:32 PM Thread Starter
Ok, After going back and forth on this, we have it narrowed down to a Comp Magnum 286 (236/236 @.050 490/490 lift) or the Comp Magnum 280 (230/230 480/480) I ran the DCR calculator on these and the 286 came in at 8.24 and the 280 was 8.44 Static CR is 10.6 For a weekend street car with power brakes, which cam would you choose between the two? Would the 286 have enough vacuum in a 406? Would it have enough torque down low? Is the 280 too small for a 406?
Man it's even tougher picking a cam when it's not for yourself.
Thanks for the help.
Mike72ss is offline
post #12 of 18 (permalink) Old Mar 26th, 10, 10:56 PM
Brian Gooding
The 280magnum runs well in a 406. Older lazier lobes, but runs damn hard.
66 Chevelle SS
496ci, Pump gas, no dominator, no spool, no electric fuel pump, no electric water pump, no big tires, full interior. N/A.
1.37
6.21 @ 109.7
9.82 @ 134.9
9.87 pass/grudge match http://youtu.be/Au6Lq7rH9Ak
"Keep your hopes up and your pedal down"....Rowdy
blue66 is offline
post #13 of 18 (permalink) Old Mar 26th, 10, 11:08 PM
Jake
Heck, a cam as small as a 268 runs good in a 406, and, in some applications, smooth, easy lobes are more desirable than aggressive ones. Go no further than 110 lsa, ideally 108. Isky or Howard's.
1972 Malibu Sport Coupe - Victory Red on Black - 350/TH350
I do all my own stunts.
Highway Star is offline
post #14 of 18 (permalink) Old Mar 26th, 10, 11:13 PM
Tim
Those cams are right in there and I have tried them. Check out the Lunati pn 30106 - 234/234/488/488/110/106 I mentioned earlier.
Timmy is offline
post #15 of 18 (permalink) Old Mar 27th, 10, 12:05 AM
Zach
.489/.504
I'd go with the Voodoo 60104 (233/241, .504/.525) with that combo as it's very similar to my 408.
Chevelle Page
-Sb 408, 10:1, AFR 195/65cc Eliminators, Voodoo 276.
-Turbo 400, 2500 Hughes, 12 bolt, 3.55s.
Chevelle408 is offline
This Thread is more than 2620 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
