540 - Chevelle Tech
post #1 of 37 (permalink) Old Jan 14th, 10, 8:22 AM Thread Starter
Steven
540
Looking to change heads on my 540 will Brodix STS BB-2 Plus (CNC) work and what size cam? Looking to turn around 6800-7000
Streetcar looking to run low 10s Car is 3710 with me in it (chevelle)Turbo 400 3500 stall, 411 rear 2-1/8 headers 4150 carb with team G intake, 30 tall tires,
Car has flowed BB-1 heads with a 636-665 258 -266 @50 with 106 LC roller cam and 10.5 compression. Its running 10.78 with a 1.46 60 foot ( foot braking it) Thank
dirtykiddracing is offline
post #2 of 37 (permalink) Old Jan 14th, 10, 9:11 AM
Re: 540
2-Xtras are a lot better head for your cubes, IMHO. If you're open to an intake swap and want to stick with Brodix, the 3-xtras come in 3 sizes, take your pick based on intended revs.
However, you should have plenty of power to run in the low 10's with what you have. There are quite a few folks here running low 10's and high 9's with less cubes.
Suspension details will help folks here get you dialed in, but you should be running your current times with your current combo with a plug wire loose, IMHO.
Gary Adrian
The correct spelling is
HILLIARY
Busted Knuckles is offline
post #3 of 37 (permalink) Old Jan 14th, 10, 9:37 AM Thread Starter
Steven
Re: 540
With the bb-1s the motor drops off after 5700 rpm The BB-2 plus have a 320 cc runner. Do I need a 340 runner? It mostly a street car.
mph is 122. I have a rear dick miller suspension with H-R anti-roll bar
post #4 of 37 (permalink) Old Jan 14th, 10, 10:18 AM
Re: 540
I think you can get away with a 320 runner. I ran Dart 325's on my 540. I was able to shift it at 7500. I think being that it is a street car, you are a little limited. Mine was a lot more forgiving with more converter and gear. Plus your cam is really small for that size engine. The engine needs so much air, and the only way to do it, is either a small head and giant cam, or a big head and a smaller cam. Right now you have small heads and small cam. But without changing the short block, you have a baseline to get deep into the 10's.
Ray
http://s30.photobucket.com/albums/c3...t=DSC01615.jpg
Best pass so far 9.034 at 148.10, 1.242 60'
bracketchev1221 is offline
post #5 of 37 (permalink) Old Jan 14th, 10, 10:34 AM Thread Starter
Steven
Re: 540
With the 320cc heads how much cam do I need to turn 6900-7000 rpm and still run it on the street? And who much can I get out of the bb-1s with a cam swap?
post #6 of 37 (permalink) Old Jan 14th, 10, 11:11 AM
Re: 540
Try talking to Chris Straub. He can tell you based on all that info. He was the one telling me about how big of a cam I needed with a 325 port, compared to a 355 port.
Ray
post #7 of 37 (permalink) Old Jan 14th, 10, 12:19 PM Thread Starter
Steven
Re: 540
I didnt want to buy 320s and end up needing 340s. I know theres alot more there and still drive on the street. Thanks for the help!
post #8 of 37 (permalink) Old Jan 14th, 10, 2:02 PM
Re: 540
For what is sounds like you are doing I would suggest the 332 BB3X oval which is a newer design head with the 2 rolled intake
Although it could use more the duration of your cam is not terrible but the lift really sucks
BTW when you said 106lc I assume you are talking about the intake center line & not the lobe separation angle?
If you email or PM me I will be happy to see if I can help with these or any other head choice & may be able to save you a buck or two in the process
Mike (Wolfplace)
VISIT US AT
+4axis CNC block machining+
----John Wayne----
Wolfplace is offline
post #9 of 37 (permalink) Old Jan 14th, 10, 2:28 PM
Re: 540
How much power you looking to make? 320 head is going to take some cam to turn over 7000 with 540 cid, there goes the street side of your equation. Going to a larger head will reduce cam size needed but you would loose some of your "street" car snappyness.
Chris Straub
Mfg Performance Parts
www.straubtechnologies.com
www.distributorgears.com
cstraub is offline
post #10 of 37 (permalink) Old Jan 14th, 10, 4:06 PM
"Wild Bill"
Re: 540
Gee, and all these years I was running around with a set of AFR 335cc heads bolted to my "streetable" 540.
Silly me...I started out by using the Dart 325 Pro I's until the AFR's were available.
And to think I often wished I had bought the AFR 357 Magnum heads.
I believe we've had this discussion before...
Team Chevelle #613
ACES #3920
CAMI (Ireland) #14
CanAm Chevelles #136
Carolina Chevelles #185
Heart Of Dixie #231
Long Island Chevelles #113
BillsCamino is offline
post #11 of 37 (permalink) Old Jan 14th, 10, 5:43 PM Thread Starter
Steven
Re: 540
Bill,
How much cam do have in the 540 and hows it run at the track?
post #12 of 37 (permalink) Old Jan 14th, 10, 6:47 PM
Re: 540
I ran the 325's on mine, and that's why I bought the 355 CNC head instead of the 335. But mine is shifted at 7500 and crosses over 7600. My cam is 275/287 @.050, .788/.765.
Ray
post #13 of 37 (permalink) Old Jan 14th, 10, 7:55 PM Thread Starter
Steven
Re: 540
Thanks, for posting your specs, Im looking to see what works. $ucks buying same parts 2 or 3 times till its right.
post #14 of 37 (permalink) Old Jan 14th, 10, 8:04 PM
Re: 540
I think for what you are looking to do, the 325 or 335 size head will be fine. Mine with 325 heads made 840 hp and went 9.30's at 141 in a 3200 lbs car.
Ray
post #15 of 37 (permalink) Old Jan 14th, 10, 9:20 PM Thread Starter
Steven
Re: 540
Is AFR heads any better than Brodix?
This Thread is more than 2675 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
