1973 monte carlo - Chevelle Tech
post #1 of 3 (permalink) Old Nov 2nd, 09, 10:17 PM Thread Starter
1973 monte carlo
I am replacing the 454 turbo jet with a 598 BBC and a tremec 6 speed manual trans. I would like to get 1.5-2hp per cylinder.
I will be using a tunnel ram with dual 750's. What heads would you recommend? I was thinking about using the Patriot Performance heads with 750 lift or something similar under $1,800. I have the part number for my cam of choice back home. It is a comp cams solid cam design. I do not remember the specs off hand. What other recommendations can you offer me?
Any help is greatly appreciated.
Bill USMC
madman960 is offline
post #2 of 3 (permalink) Old Nov 3rd, 09, 12:15 PM
Re: 1973 monte carlo
Try to get in touch with Tony Mamo from Airflow research. That is similar to the build he had in the early 90's. I think he had a 557 and a Jerico 4 speed in his Monte.
Ray
http://s30.photobucket.com/albums/c3...t=DSC01615.jpg
Best pass so far 9.034 at 148.10, 1.242 60'
bracketchev1221 is offline
post #3 of 3 (permalink) Old Nov 3rd, 09, 6:50 PM Thread Starter
Thanks, bracket.
Bill Sobers USMC
