496 build but tall valve covers wont fit - Chevelle Tech
post #1 of 8 (permalink) Old Sep 24th, 09, 1:38 AM Thread Starter
Hey guys
back to getting my 496 planned
currently running stock height valve covers with stamped rockers
want to run roller rockers
no way tall covers will fit beneath A/C compressor bracket and brake booster on driver side
and questionable if they will fit next to the A/C airbox on the passenger side firewall
what covers do you guys run to clear these problem areas yet be high enough to clear pro magnum or simliar roller rockers and studs?
anyone know where/brand of low polished cast aluminum covers (stock height unless there is another solution to problem above)
is there such a thing as intermediate height covers?
Rich Baratta
Cocoa Beach, Fla
Team Chevelle #380
May 2001 Feature Car My Showroom
Mike Lewis 496 .... "revs like a chainsaw"
GM Block, AFR 290 Heads, Callies Crank and H beam rods
Chris Straub HR
Pro Systems HP1000
658Hp /630 Tq
TKO 600
3.31 12 Bolt
Pypes 3" SGA14R36
Hooker 2455 road levelers
4240 lbs w/driver
38* Factory A/C
70 SS 454 is offline
post #2 of 8 (permalink) Old Sep 24th, 09, 2:24 AM
Paul
Re: 496 build but tall valve covers wont fit
I ended up running a 5/16" tall fel pro valve cover gasket with the stock gasket (glued together) with stock stamped steel covers to clear the aluminum roller rockers on my 496. The main clearance issue was with the exhaust adjuster hitting the v/c. If I had machined them down along with the rocker stud the 5/16" gasket by itself may have been enough. But as it is i have about 200 miles on it and no leaks or interference. This is in a '56 bel air with no air (lol) but might help you some.
highdesert56 is offline
post #3 of 8 (permalink) Old Sep 24th, 09, 3:16 AM
Ken
This can be a problem on SB's too.
kirkwoodken
406 SB, Original Bill Thomas '63 Rochester FI
AFR 210, Lunati 501C2LUN, 255/263@.050", .628"
10:1, TH400, 3.31's, 4400 SS
"Life is too short to not run a solid roller cam."
"Nothing is impossible; if you don't know what you're talking about."
Kirkwoodken
kirkwoodken is offline
post #4 of 8 (permalink) Old Sep 24th, 09, 6:18 AM
Wilson
Crower has .250 shorter locks available, I have them with their roller rockers and use a stock V/C.
NAPA PARTS GUY
1970 SS396 Build Sheet Documented
496 10.5 UD Harold 243/249 650 Net SR, AFR/290's, Victor Jr. PS/1000HP, Pump Fuel
3000 Stall TH400 3.55 MT DR's 3980 w/Driver
Best ET 1.54 7.04/96.21 11.17/118.51 @ Musclepalooza Etown 2010
wilmaya is offline
post #5 of 8 (permalink) Old Sep 24th, 09, 8:56 AM
454 in my boat has Pro Magnum rockers hiding under stock OEM stamped sheetmetal valve covers. I needed two valve cover gaskets on each side for clearance with the tall rocker nuts.
Tall covers are for clearance with stud girdles, not roller rockers.
Schurkey is offline
post #6 of 8 (permalink) Old Sep 24th, 09, 11:04 AM
I don't have AC, but I did not find the brake booster to be a problem at all. These are stock covers with a 1.15" aluminum spacer from Stef's...still plenty of room between cover and booster...
Georgia69 is offline
post #7 of 8 (permalink) Old Sep 24th, 09, 12:00 PM
Alan
Comps Pro Magnums will fit I believe and Roller Tips will definetly fit as I have a set under stock BBC valve covers....ofcourse those are not full rollers though.
1971 Corvette
496" 657hp/675tq, pump gas
T400, Tight 10" converter
3.36 gears, 3600lb raceweight
10.59@127.51, 1.51 60'
STOCK APPEARING
ShouldntBeHere is offline
post #8 of 8 (permalink) Old Sep 24th, 09, 12:05 PM
Wilson
Rich, I built my Eng. using the shorter Sure-Locks with the A/C bracket in mind. But found a donner car to eliminate the A/C all together. Here's a picture of the eng. and it has Crower stainless roller's with their shorter locks. I'm using 1 std. gasket per cover.
NAPA PARTS GUY
wilmaya is offline
