781 BBC heads - Chevelle Tech
post #1 of 15 (permalink) Old Jun 13th, 09, 11:59 PM Thread Starter
JOHN
781 BBC heads
I aquired a 454 this weekend that has 781 heads on it. I'm looking to build a 450 HP bigblock and was wondering if these heads could possibly get me there? Thanks
TRANNY SMOKE is offline
post #2 of 15 (permalink) Old Jun 14th, 09, 12:14 AM
Re: 781 BBC heads
yep no problem just gonna need the right cam and other related parts.
78 Malibu
69 VW baja 1600cc.
2016 honda civic coup
Jebchevelle is online now
post #3 of 15 (permalink) Old Jun 14th, 09, 12:30 AM
Re: 781 BBC heads
It would be hard NOT to make 450 HP.
The car doesn't have an engine . . . the engine has a car.
68454SS is offline
post #4 of 15 (permalink) Old Jun 14th, 09, 1:02 AM
Re: 781 BBC heads
Absolutely, good find.
Twins Fan is offline
post #5 of 15 (permalink) Old Jun 14th, 09, 1:27 AM
Re: 781 BBC heads
They are a great street head, and will work pretty well on everything from a mild cruiser to a hot street car. They respond well to bigger valves and basic head work. But you should be able to get to the 450hp level with them being pretty much stock. Just pick the right cam and intake.
70 chevelle
420 sb combo - 10.93@120.76mph
405 sb combo - 11.87 @112.5
307 combo - 12.91@105.33
68 chevelle 533 almost there
68chevelle533 is offline
post #6 of 15 (permalink) Old Jun 14th, 09, 2:58 AM
George
Re: 781 BBC heads
John,
Use SEARCH
thousands of posts on BBC builds, 049 and 781 heads
George Kettler
http://public.fotki.com/kettbo/gearhead/
o 68 Camaro Vert 327 project, painted, assembly stage http://www.camaros.net/forums/showth...183654&page=55
kettbo is offline
post #7 of 15 (permalink) Old Jun 14th, 09, 8:50 AM
Re: 781 BBC heads
Vortec Pro uses these almost exclusively. I just finished putting a coat of POR orange enamel on a set in my garage. Next is ss screen in the oil drainback and off to the Serdi machine for some seat opening.
post #8 of 15 (permalink) Old Jun 14th, 09, 8:59 AM Thread Starter
JOHN
Re: 781 BBC heads
We were talking about the 215's I have, but I'm not sure they are useable. A couple of exhaust ports are extremely rusty to the point of losing material. I picked up a 76 3+3 truck with a 454/400 that has the 781's on it. I only gave $200 for the whole truck and it was advertised for the world to see on the internet. Couldn't believe the add when I seen it.
post #9 of 15 (permalink) Old Jun 14th, 09, 10:21 AM
Rod
Re: 781 BBC heads
Good score! Craigslist?
Rmchevelle is offline
post #10 of 15 (permalink) Old Jun 14th, 09, 3:43 PM Thread Starter
JOHN
Re: 781 BBC heads
No. http://www.hoosiertopics.com/
Here is a link to the specific add.http://www.hoosiertopics.com/cgi-bin...req=26w6a0749a
post #11 of 15 (permalink) Old Jun 14th, 09, 4:14 PM
pdq67
Guest
Posts: n/a
Smile Re: 781 BBC heads
Great heads, but remember that you will need to cc them b/c they can vary from 113 up to 119 cc's or so! -049 heads can go above 122 cc's here....
I'd use stock type GM .020" thick steel shims to set the quench at .035" to .045" and then order a set of forged pistons to get the CR up to at least 9.75 to 1 CR, if not right at 10 to 1 WITH the cc of your -781 heads!!
Please don't try to run the cheaper hyper pistons, only b/c you are starting to be up in the forged piston power range and I figure that once you get her going, the dreaded, "More power, Scottie" bug will bite you just like it did me!! This way, your new pistons will be FINE!!
pdq67
post #12 of 15 (permalink) Old Jun 20th, 09, 1:51 AM
Jacen
Re: 781 BBC heads
What Cam and Intake would you all recommend. I am in the process of cleaning up my 454 but was just planning to put a Cam and Intake in myself to beef it up a little. What about changing the Valve Springs as well? Also would a Holley 750 work on this engine for daily driving?
Jacen
jacen33606 is offline
post #13 of 15 (permalink) Old Jun 20th, 09, 4:31 AM
pdq67
Guest
Posts: n/a
Re: 781 BBC heads
Imho, no more than CC's old 282s solid flat tappet lifter cam will do you fine,.
pdq67
post #14 of 15 (permalink) Old Jun 20th, 09, 11:31 AM
Paul
Re: 781 BBC heads
Get them cut for 2.19/1.88 valves and some port work done. Probe -18cc dome top forged pistons are cheap and will bring up you compression to 9.6-9.8 but cc your heads....my 781's were 116
You should be able to get 500/550hp with a good matching combo
454/T400/9" in a 67 Beaumont
Paul-ish is offline
post #15 of 15 (permalink) Old Jun 20th, 09, 2:32 PM
pdq67
Guest
Posts: n/a
Re: 781 BBC heads
Right, use the springs recommended for your cam here, not the low lift stock type.
pdq67
