sbc 355 camshaft suggestion! - Chevelle Tech
post #1 of 16 (permalink) Old Nov 12th, 08, 1:58 PM Thread Starter
Brian Lawson
hi i am looking for suggestions for a camshaft, i'll tell you what i got so far! i am looking for the "best bang for the buck" i'm open to all CAM suggestions, this is mainly going to be a street/strip car, i ALREADY HAVE THE PARTS LISTED so thats not going to change !
1985 trans am 3200lb car give or take a few lbs
3.42 gear ratio
(dont have much of an option for gears, 9 blot gta rear end)
turbo 350
3000 stall
26x10.5x15 m/t et streets
i have a 350 .30 over 4 bolt main
.125 dome trw pistons
stock crank and rods
750 holley mechanical secondary
professional products hurricane intake
11.1 compression
procomp aluminum heads 2.02/1.60 link to the heads specs,
http://www.procompelectronics.com/in...oduct_id=37060
and 1.5 roller rockers
i would like to go hydraulic roller or solid roller but i'm on a budget so let me know what you think!
thanks Brian
dioismyhero is offline
post #2 of 16 (permalink) Old Nov 12th, 08, 2:41 PM
Dave 383 now
Re: sbc 355 camshaft suggestion!
Your gears suck thats true.
Since your cubes are small too , I would go with the XR274R
Duration @ 050 is 236-242
Lift 564 570
Next cam is one bigger XR280R
Duration @ 050 242-248
Lift 570-576
I would go with the smaller one since your gearing is only 3.42
Dave427 is offline
post #3 of 16 (permalink) Old Nov 12th, 08, 2:58 PM
Guest
if you are on a budget, go solid flat tappet and use the money left over to change your gears.
curley8788 is offline
post #4 of 16 (permalink) Old Nov 12th, 08, 3:18 PM Thread Starter
Brian Lawson
i have a "GTA" 9 bolt rear end and the gears are VERY HIGH IN PRICE, and the only avalible from what i read are 3.70's that are notoriuos for being noisey.... so i'm stuck with 3.42's with out doing a rear end swap,
post #5 of 16 (permalink) Old Nov 12th, 08, 3:21 PM
Walter
X2
69 Chevelle SS
10.5-1 496/AFR 305's/Voodoo 60234 Solid Roller/TH400 4000 Stall/4.11 12 Bolt
wildman926 is offline
post #6 of 16 (permalink) Old Nov 12th, 08, 4:16 PM
Guest
i cant see how any gear set would be more than the 600+ dollar savings you'd have if you went with a solid flat tappet over a hydraulic roller. any rear that's noisy isnt set up corectly.
post #7 of 16 (permalink) Old Nov 12th, 08, 4:35 PM
you can still move using those gears. Your car is light so that helps.
fabio is offline
post #8 of 16 (permalink) Old Nov 12th, 08, 4:46 PM
Dave 383 now
The gears aren't that bad , just wish they were 3.70 or 4.10's. He is using a shorter tire so it should go. Thats why I recommended the smaller cam.
Dave427 is offline
post #9 of 16 (permalink) Old Nov 12th, 08, 5:04 PM Thread Starter
Brian Lawson
i stand corrected, i just found a motive gear ring and pinion for an australian 9 bolt 3.70 gear, part number gm9-370 motive gear, but i dont know anyone who would touch it around my area, and i'm not letting someone who has never heard of a 9 bolt set up gears,
but with all that said, i am using what i have so gears are out of the question.
post #10 of 16 (permalink) Old Nov 12th, 08, 5:06 PM Thread Starter
Brian Lawson
thank you dave, what would you suggest on a hydraulic cam or hydraulic roller?
post #11 of 16 (permalink) Old Nov 12th, 08, 5:13 PM
Walter
Motive Gear, they are a very good. If you don't know anyone "who would touch it" around your area, then it may be time to learn how to do it yourself. That is what most do.
Your gears are going to be your limiting factor. If your compression is true 11-1, than you are going to have a hard time finding a cam that will run with that compression, and be happy with those gears. Just go through the catalog of Lunati, Comp, etc., and you will see what their suggestion would be for each cam according to compression and gears.
The old saying that it is all about the combo...you build EVERYTHING towards the combo to make it work.
69 Chevelle SS
post #12 of 16 (permalink) Old Nov 12th, 08, 5:30 PM Thread Starter
Brian Lawson
i knew this was going to happen with the combo, thats why i added "ALREADY HAVE THE PARTS LISTED so thats not going to change !" in the inital thread, going with what i have without spending extra money on GEARS. and a dual plane intake, what is the best camshaft for the combo, thanks
post #13 of 16 (permalink) Old Nov 12th, 08, 6:11 PM
Ron
Originally Posted by dave427 View Post
your gears suck thats true.
Since your cubes are small too , i would go with the xr274r
duration @ 050 is 236-242
lift 564 570
next cam is one bigger xr280r
duration @ 050 242-248
lift 570-576
i would go with the smaller one since your gearing is only 3.42
x2..xr274r
69 Camaro
491/AFR 315/Straub hyd roller
TH400/GV OD/9" 3.50
dirtlips408 is offline
post #14 of 16 (permalink) Old Nov 12th, 08, 6:24 PM
Dave 383 now
XR288R with 3.40's
XR294R with 3.70's
Dave427 is offline
post #15 of 16 (permalink) Old Nov 12th, 08, 6:29 PM Thread Starter
Brian Lawson
XR288R with 3.40's
XR294R with 3.70's
thanks alot
