383 sbc...are small base circle cams always necessary? - Chevelle Tech
post #1 of 9 (permalink) Old May 8th, 04, 2:37 PM Thread Starter
Post
When building a 383 sbc stroker engine, is it always necessary to use a small base circle camshaft for clearence issues. I am using Scat 6.0 4340 pro I beam rods, designed for stroker engines, these have the ARP 7/16" cap screws. Scat says they are clearenced for stroker engines. Thanks!
fatmattbbc is offline
post #2 of 9 (permalink) Old May 8th, 04, 3:09 PM
Send a message via AIM to bowtie455
Post
i have those exact rods for my 385 stroker smallblock and am hoping for an answer also.i'm thinking only the block will need clearancing.lets keep our fingers crossed!
bowtie455 is offline
post #3 of 9 (permalink) Old May 8th, 04, 3:36 PM
Post
ive got a xe294h and i had to clearance my rods a bit. ive got the standard scat 5.7" i beam 4340's
Jinks is offline
post #4 of 9 (permalink) Old May 8th, 04, 3:48 PM
Send a message via AIM to Rad Racer
Post
My 383 did not require special cam clearancing. BUT I am using an old Crane 274H, results may vary. Scat 9000 crank, Eagle SIR 6.0" rods, Crane 274H "3/4 Race cam". My block had to be ground like crazy, but the cam was ok. I will be finding out how it fits with a Comp XE262 in a couple weeks. I hope I don't run into any problems.
Rad Racer is offline
post #5 of 9 (permalink) Old May 8th, 04, 4:23 PM
Post
stock block, comp 280H, scat 9000 crank, stock 5.7's with ARP bolts, I had to sell the comp 280H and order a small base cam......
Disclaimer: I can't spell.
bored&stroked is offline
post #6 of 9 (permalink) Old May 8th, 04, 5:04 PM
Post
scat 5.7 H rods. comp 294hr standard base circle cam. a few of the rod bolts had to have very minor relief work. Ive always thought about the trade offs between the 2 different size cams. theres got to be advantages and disadvantages to both. 2 very good thoughts come to mind. Dave
sheetmetal is offline
post #7 of 9 (permalink) Old May 8th, 04, 5:52 PM
Roger
Post
Originally posted by fatmattbbc:
When building a 383 sbc stroker engine, is it always necessary to use a small base circle camshaft for clearence issues. ...
In a word... NO!
We ran a 383 in a stock block with Summit Proline rods with a variety of hydraulic, solid flat tappet and roller cams (with up to .766" lift) and all of them were standard base circle. The key is the rods!
Roger Copeland
"Only a rich man can afford cheap parts, because he can afford to replace them."
R&R Racing
383Malibu is offline
post #8 of 9 (permalink) Old May 8th, 04, 7:43 PM
Post
ZZ4 block, Manley Sportsmaster 4340 Capscrew rods, GMPP HR Hot Cam. - no grinding to the block, very minor grind to a couple of the rods, to provide adequate cam clearance, although none were actually hitting.
BPOS is offline
post #9 of 9 (permalink) Old May 8th, 04, 7:44 PM
Post
even with a mild cam and stroker clearance rods you can have problems..it all depends on the core shift of that particular block...if you look at the front of the block, theres a flat spot where the cam bearing is...the cam is supposed to be centered in that pad...a lot of times you will find its moved down..this can cause clearance problems
bigjimzlll is offline
This Thread is more than 4798 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
