Cam help 540 BBC - Chevelle Tech
post #1 of 9 (permalink) Old Aug 2nd, 08, 9:47 PM Thread Starter
Cam help 540 BBC
540 BBC Dart 320 heads , 1050 dominator , 11.5 to 1 compression
4.56 gear , 4000 stall ..looking for a street strip recomendation ...pulled the intake today and found lobes going south...any help would be appreciated .
chevelledave is offline
post #2 of 9 (permalink) Old Aug 2nd, 08, 10:14 PM
Levon
Re: Cam help 540 BBC
Talk to Chris Straub or Mike Lewis or UD Harold
They will do you right and they are available through this web site.
Levon Hovagimian
Team Chevelle #279
70 Chevelle SS 454 LS5 4 speed.
1966 427 Corvette SOLD
Priddis, Ab. Canada
My Showroom
Last edited by LevonH; Aug 2nd, 08 at 10:28 PM. Reason: Spelling and added UD Harold :-)
LevonH is online now
post #3 of 9 (permalink) Old Aug 2nd, 08, 10:23 PM
In Memory of Harold
With the 4000SS converter and the 4.56 gear, are you looking for a roller cam, street-n-strip type, or a hydraulic roller, or a solid lifter, etc?
Also, what sort of lift? I make cams at .668", .680", and .725" that are very streetable, capapble of 2000+ miles in 24 hours. These are steel billet roller cams.
UDHarold
My typical 540 street-n-strip cams are 288/296 at .020, 257/265 at .050, .725"/.725" gross valve lift, and 112 LSA, and 302/310 at .020, 271/279 at .050, .725"/.725" gross valve lift, and 110 LSA.
Both htese two cams have the same opening and closing ramps on them.
UDHarold is offline
post #4 of 9 (permalink) Old Aug 2nd, 08, 10:48 PM Thread Starter
looking for solid roller ...car is not mine ...but it is in my garagea as we found the cam damage today during a intake swap..what type of lifter would you recomend as well ...car will see street duty ..and track time ...this is also a GM gen 6 block if that makes a difference ...
thanks Dave.
post #5 of 9 (permalink) Old Aug 2nd, 08, 11:02 PM Thread Starter
A few other details this is a shaffirof street engine from around 1998 the intake is a dart as well ...and it looks as thought the tops of the lifter bores have been machined to accept a standard length lifter ...
post #6 of 9 (permalink) Old Aug 2nd, 08, 11:14 PM
Matt
My 540 had 10.5 compression, Dart intake, AFR 335cc heads and made 775HP (at 6300 and 6400 RPM) and 698ft/lb of torque (at 4800 RPM) on the dyno. Solid roller. Great for street/strip. No too radical. Specs were (from memory) :
Duration at .050: 256/262
Lift: .650/.650
Lobe Separation: 114 degrees.
1966 Chevelle, mild 423 sbc. Consistent 11.80's at 116 mph. Factory 10 bolt, 3.08 gears, column shift. 1987 Buick Grand National, runs low 10's @ 132+ with working A/C and cruise control.
toomanymodz is online now
post #7 of 9 (permalink) Old Aug 3rd, 08, 2:42 AM
Sounds like you got a couple good suggestions from UDHAROLD in post #3. With an 11.5:1 CR I'd go with the bigger of the two cams he mentioned if the car is to be run on pump gas. Furthermore, I don't think that you'll find a more knowledgeable cam guy than Harold.
BillyGman is offline
post #8 of 9 (permalink) Old Aug 3rd, 08, 2:55 PM Thread Starter
cool thanks ...Harold how do I order from you ?? alos what lifter do you guys recomend for street duty ??
post #9 of 9 (permalink) Old Aug 3rd, 08, 3:07 PM
That depends what type of cam you'll be using. For a solid roller cam, I would go with the Isky Red Zone lifters with the "EZ Roll" option if I were you, simply because they don't have needle bearings like the conventional roller lifters do. But if you'll be using a hydraulic roller cam, then I think there are a number of good lifters out there for those, and your choice wouldn't be as critical.
This Thread is more than 3220 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
