Single plane vs. dual plain - Chevelle Tech
post #1 of 20 (permalink) Old Feb 20th, 08, 12:22 AM Thread Starter
Roland
Send a message via AIM to forever young
Basic questions need to be answered for me. Help. I am building my 402 right now and it will be for the street. I am using a voodoo hydralic roller cam and running 10:1 comp. on a 331 rear - 4 speed. ok what will serve me better and fit under a cowl hood on my 70 SS, A quadrajet, holley, carter? what about high rise, single plane / dual plane, aluminum / cast iron? what are the best in performance 1500 - 5500 rpm range?
Thanks for the help.....Roland in NY
"some people spend their entire life trying to make a difference, US MARINES don't have that problem". Ronald Reagan Semper Fi
forever young is offline
post #2 of 20 (permalink) Old Feb 20th, 08, 12:38 AM
Green Weenie
Send a message via Yahoo to Bob West
Re: Single plane vs. dual plain
Edelbrock Performer.
Bob West is offline
post #3 of 20 (permalink) Old Feb 20th, 08, 12:48 AM
Walter
Holley 750 3310, or Holley SA 770, Performer intake. But you will get the power bug, so you might as well get the Performer RPM.
69 Chevelle SS
10.5-1 496/AFR 305's/Voodoo 60234 Solid Roller/TH400 4000 Stall/4.11 12 Bolt
wildman926 is offline
post #4 of 20 (permalink) Old Feb 20th, 08, 2:08 AM
Daniel
I agree
sledgehammer67 is offline
post #5 of 20 (permalink) Old Feb 20th, 08, 2:47 AM
I found in the past on my 355 SBC powered Vette, that the Edelbrock Performer RPM (not the air gap one) as well as the low-rise single plane Weiand "Team G" manifolds performed the best out of the ones I tried on the car. However, since I didn't use a choke on my Holley carb, I also found that the Performer RPM manifold was a bit more street friendly because it had an exhaust crossover duct through the middle that served to warm up the intake quicker than the single plane Team G manifold did, since the Team G did not have the exhaust cross over. So with the Team G single plane manifold, the engine would run lousey during the first 15 minutes after start-up. And on the nights when the temps would drop into the 50's and sometimes even in the 40's, it was very noticeable. With the Performer RPM intake, it was only a bit shakey in the way that it ran for the first 5 minutes.The Performer RPM was also decent for throttle response beginning at 1,500 RPM,whereas the single plane low rise Team G didn't begin to offer throttle response until 2,000 RPM.
BillyGman is offline
post #6 of 20 (permalink) Old Feb 20th, 08, 6:57 AM
Darren
IMO, for a fairly mild street 402, I think a q-jet would make a real nice carb. When setup properly, they are very reliable, great throttle response and mpg's and still rival a Holley in the power department. Sean at SMI can taylor a carb to your specific engine/drivetrain combo. Very reasonable prices. I think a Stage 2 carb would best suit your needs.
http://www.smicarburetor.com/products/?sfID1=28&sfID2=9
As far as intakes, a Performer would work well, but I would be more apt to look at the Performer RPM Q-Jet manifold. Same as the regular Performer RPM but setup up to accept a spreadbore carb.
http://store.summitracing.com/partde...4&autoview=sku
Darren
1971 Chevelle
496
10.5 scr
CFM Ported Victor Jr / Pro Systems HP1000
T-56 Magnum 6 Speed, DFX
12 Bolt TrueTrac, 4.56 gear 33 spline Mosier axles
30x12.5 ET Street Radial
525++ rwhp
http://www.chevelles.com/showroom/da...0930-00149.jpg
http://www.chevelles.com/showroom/da...m/Vic_Jr_1.JPG
71454Chevelle is offline
post #7 of 20 (permalink) Old Feb 20th, 08, 7:29 AM
I would look into a Q-jet. Sean at SMI did one me a about 4 years ago and it was a great running carb. Replaced a 750 Eddy and there was absolutely no comparison between the two. Throttle response was very good and was very reliable. This was on a 383 with a HR cam 219/227 @.050 lift was .510 on a 110lsa performer rpm, and sportsman heads. It was a 4000 lb car with a 700r4 and 3.42 gear. Best time was a 13.70 @ 101 mph. Great carb.
1972 Nova
496/T56 Magnum/3.73
1964 Corvair Spyder coupe
1975 C20 Camper Special 454/TH400
72BB Nova is offline
post #8 of 20 (permalink) Old Feb 20th, 08, 8:36 AM
There was no difference in ET or MPH at the dragstrip when I swapped from a Performer 2-0 to an RPM on my 454
mr 4 speed is offline
post #9 of 20 (permalink) Old Feb 20th, 08, 8:42 PM
What about running edelbrock Air Gap on the street? I just bought one to replace my current performer RPM.
Dart Little-M SBC 400
Scat 4340 Int. Bal. Crank, Wiseco Tru-Pro Pistons, Eagle H-Beams 6" Rods, AFR 195 Eliminators Comp. Pkg, Bullet Solid Cam 275/279, 247/251@.050, 565/577 lift w1.6, 108 LSA, Pro-System XC Carb, Hooker 1- 3/4 Headers, Pro-Built 700R4, P.T.C. 3000 Stall, Strange 12-bolt W/3:73 Gears
DEEBOO is offline
post #10 of 20 (permalink) Old Feb 20th, 08, 8:51 PM
IMO, and based on my own experience, with the air gap, I would highly recommend running a choke on the carb since there isn't a heat crossover in that manifold, unless you're only gonna drive the car when the air temps outside are 80+ degrees even at night time. If there's any chance that some nights that you drive home, the air temps will be in the 60's or 50's, then the air gap w/out a choke on the carb will cause the motor to stumble and hesitate for the first 15 minutes of operation. If that wouldn't bother you, then it's no big deal, but that's the way it was on my 73 Vette that had a 350 engine. I tried 5 different manifolds to test out which was best.
Just keep in mind that it wouldn't matter if you happen to have aftermarket cylinder heads that do NOT have ports in them for the heat crossover. Because if they do not, then even if you had a manifold with the heat crossover, it wouldn't be any different anyway since there wouldn't be any exhaust heat going through the crossover anyway.
post #11 of 20 (permalink) Old Feb 20th, 08, 8:53 PM
Don't use a BB Performer on anything besides a motor home. With 3.31s you will be better off with a Q-jet and a dual plane that has runners the size of the intake ports.
Mike Feudo is offline
post #12 of 20 (permalink) Old Feb 20th, 08, 11:49 PM
Walter
What did you end up going with?
69 Chevelle SS
post #13 of 20 (permalink) Old Feb 21st, 08, 1:22 AM
Single Plane for racing
Dual Plane for street
racecar100 is offline
post #14 of 20 (permalink) Old Feb 21st, 08, 7:32 AM
Paul
I was just going to mention Weiand's old 8005 dual plane as being a dandy for a Q-Jet, imho.
pdq67
pdq67 is offline
post #15 of 20 (permalink) Old Feb 21st, 08, 7:54 AM
Green Weenie
I would argue that point!! Ede Performer RPM on 505 pumpgas cubes, running low 10's
Bob West is offline
