headers in way of spark plug - Chevelle Tech
post #1 of 24 (permalink) Old Jan 21st, 08, 3:09 PM Thread Starter
I've got tube headers on my 350 in my 66 Malibu. Can't seem to get #6 plug out, headers don't allow room to get a plug socket on the plug, and can't seem to get an open end wrench in there, either. Anyone else have this problem.......and a solution?
busterwivell is offline
post #2 of 24 (permalink) Old Jan 21st, 08, 3:28 PM
Re: headers in way of spark plug
Snap-on and Comp tools have shorty sp sockets with notches taken out of the side wall to get the socket over the plug and hexed for an open end or box end wrench to get it out for right now you will have to take out the header bolts unless you can get the socket to fit. My BB has raised exhaust ports and have similar problems I made a spacer flange out of flat aluminum stock to get more room(used a gasket for a template)
Mike Lewis street 572
http://www.lewisracingengines.com/
Holley HP EFI
Marcella Manifolds
Heads by Darin Morgan
Wires from Rick@Firecore
www.firecore50.com/
Cam by UDHarold
.456 X 1.8/1.7
Menscer Motorsports
http://menscerms.com/
R2C Filters
www.r2cperformance.com
Ultra Carbon
www.ultra-carbon.com/
GF-5R,
http://trzmotorsports.com/wp2/
TRZ FAB 9" 4.56 REM, Cryo Treated
4000 lb street car
My Showroom
aukai is offline
post #3 of 24 (permalink) Old Jan 21st, 08, 3:49 PM
I had to take a new Craftsman boxed end wrench, the ones that taper 90* and offset, then I ground down the boxed end till it was about 1/8 of an inch thick. You must grind the entire boxed end to get it to slip over the end of the spark plug. I had to do this with my 882's and my AFR'S.
1966 Chevelle 300 Deluxe Post, 327cu AFR180CC Street Eliminator, Voodoo, Harland Sharp 1.6 RR, Weiand Stealth Airstrike, 650cfm avs, MSD 4spd 355 posi
http://i183.photobucket.com/albums/x...2/P1010428.jpg
http://i183.photobucket.com/albums/x...2/P1010429.jpg
66 BRONZE is offline
post #4 of 24 (permalink) Old Jan 21st, 08, 4:06 PM
i have taken a plug socket, cut about an inch off the end that goes on the plug, and welded a bar on it-takes me 3 diff tools to get plugs out of all 8
when your credit cards are maxed, have the limits raised
forcd ind is offline
post #5 of 24 (permalink) Old Jan 21st, 08, 4:19 PM
Holley HP EFI
Marcella Manifolds
www.firecore50.com/
Cam by UDHarold
.456 X 1.8/1.7
Menscer Motorsports
R2C Filters
Ultra Carbon
GF-5R,
4000 lb street car
My Showroom
aukai is offline
post #6 of 24 (permalink) Old Jan 22nd, 08, 1:11 PM
Doug
what all these guys said
it sucks but you dont have any other choice.....thats hot rodding for ya
dgrobels is offline
post #7 of 24 (permalink) Old Jan 22nd, 08, 2:33 PM Thread Starter
looks like I've got some grinding to do this weekend............thanks all.
post #8 of 24 (permalink) Old Jan 22nd, 08, 2:44 PM
chris
I custom ground a socket as well.
Shaved it almost paper thin around the mouth of the socket to fit. Would hate to lose it.
Not just a header issue but combined with too small a slot for the plugs in my AFR's.
1969 ls7 ls resto...re-creation.
Chris Stanwyck is offline
post #9 of 24 (permalink) Old Jan 22nd, 08, 2:47 PM
LXS
aLeXiS
Send a message via AIM to LXS Send a message via MSN to LXS Send a message via Yahoo to LXS
Sorry, not sure if it was mentioned, but, you could try using shorty style spark plugs to help with the space issue
http://myspace.com/lxs14
'71 Chevelle 388ci (Untuned best of 8.373@83.05mph 1/8th mile on tires and 8.236@84.40mph on slicks)
'95 Burban 6" lift on 36s (for sale)
'02 Mustang Vert, CAI and SLP Loud Mouth cat back (Gone )
'61 VeeDub Bug Ragtop (Sold)
'03 Mach 1
LXS is offline
post #10 of 24 (permalink) Old Jan 22nd, 08, 2:59 PM
This is true. My NGK VR4's are 1/4 inch shorter than a standard AC plug. I thought about buying that socket you see in Hot Rod, you know the one with that hot babe in the blue jean cut-off's. But I found if you get the #6 plug loose with the ground down boxed end wrench, then just remove the wrench and unscrew it by hand.
post #11 of 24 (permalink) Old Jan 22nd, 08, 3:32 PM
Ken
The solution to this is to call the header companies and tell them we want headers redesigned for modern heads with raised ports and angle plugs, instead of giving us headers for 40 year old heads. If we stop buying the bad stuff, they will start making something that fits.
kirkwoodken
406 SB, Original Bill Thomas '63 Rochester FI
AFR 210, Lunati 501C2LUN, 255/263@.050", .628"
10:1, TH400, 3.31's, 4400 SS
"Life is too short to not run a solid roller cam."
"Nothing is impossible; if you don't know what you're talking about."
Kirkwoodken
kirkwoodken is offline
post #12 of 24 (permalink) Old Jan 22nd, 08, 4:02 PM
Send a message via MSN to Whiskey
I took a spark plug socket, and cut it off so that I had about 3/4 inch of the socket left. Then I took a slotted scrwdriver and welded it to the outside of it. I then bent this at about a 30 degree angle. This slides right on any and all plugs I have found to date and works great.
68 Chevelle
427 w/Merlin heads
10.2 to 1 comp
Hooker headers
Art Carr 200R4 w/3500 stall
3:90 Posi
72 SS 454
Hooker Headers
400 turbo
3:31 gears
Whiskey is offline
post #13 of 24 (permalink) Old Jan 22nd, 08, 5:40 PM
Kevin
Send a message via Yahoo to dirtrocker
Back when I was about 12................was riding my bike and found a whole toolbox full of tools in the trash!!! Can still remember carrying it home
One thing in that box was a double box end offset wrench. It's been belt sanded a bit and is a lifesaver when changing header plugs
1971 chevelle SS conv. dark rosewood metallic w/ black top/stripes/int. 402/4sp bench. Under resto.
1965 Chevelle Malibu 4dr Wagon, 283, pg, ps, air.
1984 Buick GN
http://imageshack.us/photo/my-images...kle142hs1.jpg/
dirtrocker is offline
post #14 of 24 (permalink) Old Jan 22nd, 08, 6:32 PM
I know, I know this very well.
post #15 of 24 (permalink) Old Jan 22nd, 08, 6:36 PM
You can catch a Snap on, matco, mac guy or go to this website.
http://www.headersockets.com/
Best tool I ever bought for spark plugs. Got mine from my brother in law who is a matco tools dealer.
http://www.cardomain.com/ride/2923126/11970 Chevelle SS replica ( Its what I can afford )
Shooting for 10's on pump gas. Most likely will run 11's
Dont lift till you see God.
Chevelle505cid is offline
This Thread is more than 3384 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
