Aluminum Heads Problems - Chevelle Tech
post #1 of 23 (permalink) Old Sep 30th, 07, 6:30 PM Thread Starter
Since just about everyone is running aluminum heads these days, I am curious the types of problems, if any, people are having.
1966 Beaumont SD
hydraulic roller 468 12.22 at 109
1970 Nova
solid roller 461 11.49 at 119
Sandy is offline
post #2 of 23 (permalink) Old Sep 30th, 07, 8:28 PM
Re: Aluminum Heads Problems
The only problems that I've heard anyone ever having with aluminum heads is that with some of them (such as AFR, and World/Merlin ) the rocker arm stud holes break into the intake ports (as with some of the AFR's) and the header bolt holes break into the coolant passages (as with some of the World/Merlin aluminum heads).
This might not be a major problem, and should be easily remedied by the inclusion of some good thread sealant such as ARP sealant placed on the threads (as long as the customer/installer remembers to do that). However, it isn't any evidence of quality control on the manufacturer's part. I'm not a business owner myself, but I would like to think that if I did own a cylinder head biz, that I wouldn't want to ship heads to my customers that have coolant passages and/or intake ports in which the drill bit poked through during the machining process!
The only other things that I can think of that is specific to the aluminum heads, is that spring cups must be used underneath the valve springs when they're installed to protect the head from being damaged. But you probably already knew about that one. And that may or not be enough to effect the installed height of the springs.
And the other thing that you're likely already aware of is that during engine assembly it's best to keep the torque of the intake manifold bolts to 30 ft/lbs to avoid stripping the threaded holes in the heads. You might be able to get away with 35 ft/lbs if you're lucky, but ever since I stripped a couple holes in the AFR heads I once had, when bringing the intake manifold bolts to 36 ft/lbs, I routinely keep it at 30 ft/lbs. If you can get the head manufacture to deliver the heads with both the intake and exhaust manifold bolt holes heli-coiled, then that would be best. At the time, AFR was only doing that on the exhaust manifold bolt holes.
EDIT: I also keep the torque on the rocker arm studs at 50 ft/lbs on aluminum heads (which is what most installers do as far as I know).
BillyGman is offline
post #3 of 23 (permalink) Old Sep 30th, 07, 10:10 PM
wannabe
Billy, with all Rect. port BBC heads that I am aware of (iron or aluminum, GM or aftermarket) the rocker studs actually protrude into the intake ports. It's not a flaw, they are made that way. And yes, you have to use sealant on the rocker studs. It's standard procedure. I've not personally seen a header bolt hole go inot the water jacket, but I'm sure it's possible.
Sandy, one other thing that happens a lot is the rocker arm tips don't line up in the center of the valve tip. Pretty common with most aftermarket heads. It may actually be the guide plates that are the culprit. It can be fixed/helped by enlarging the holes in the guide plates and adjusting them to fit. Or cutting the guide plates and adjusting them individually then welding them back together. Older GM castings are very prone to breaking the rocker stud bosses, but most aftermarket heads have them beefed up so that is no longer a common problem.
Jay Campbell
Campbell Competition Motorsports
jbird is offline
post #4 of 23 (permalink) Old Sep 30th, 07, 11:49 PM Thread Starter
thanks guys, keep em coming!
1966 Beaumont SD
1970 Nova
Sandy is offline
post #5 of 23 (permalink) Old Oct 1st, 07, 12:02 AM
You are aware there are not many cars or trucks you can buy today that do not have aluminum heads right?
My opinion there are no issues running aluminum heads that you would not see in aftermarket iron heads too.
As far as the studs going into the intake runner go it has nothing to do with quality control or the machining process
It has to do with the size of the ports.
As Jay stated, every BB rectangle port head out there with any amount of volume is going to have the studs intrude into the intake port
AFR, Brodix, Dart, doesn't make any difference there is only so much room above the port in a conventional casting
BTW, Most SB heads with a port of over about 190 or so cc's also has a stud sticking into the intake port too.
This includes a number of GM heads.
I guess by the same logic GM messed up the machining on blocks because the head bolt holes go into water
And in all the years I have been messing with this stuff I have never stripped the threads in a new aluminum head or a used one assuming someone had not already hamburgered up the threads,,,
All you have to do is use a bit of common sense when installing things like don't go nuts tightening, use the correct length bolt,,
Mike (Wolfplace)
VISIT US AT
+4axis CNC block machining+
----John Wayne----
Wolfplace is offline
post #6 of 23 (permalink) Old Oct 1st, 07, 12:34 AM
If they are going to be used hard heli-coil the intake,ex and spark plug holes it will save you grief at the races some day.
Mike Feudo is offline
post #7 of 23 (permalink) Old Oct 1st, 07, 12:49 AM
Randy
And be sure to use Anti Sieze compound on ANY steel bolt, fitting, or spark plug that you thread into aluminum and expect to be able to remove later. Including the header bolts and intake bolts, etc.
Randy
'66 Chevelle SS396 L-78 M-20 4-speed 4.10 posi Black-on-Black numbers matching (SOLD!)
'67 Cutlass with a 540
'67 Camaro (SOLD)
'65 Biscayne 2-dr post (kind of a BIG Chevelle)
Vega S/G (For Sale with REAL nice 18 degree SB motor parts and a 9.40 350 in it.)
several Olds 442's (funny lookin' Chevelles) (2 sold)
ToyzRMe is offline
post #8 of 23 (permalink) Old Oct 1st, 07, 1:48 AM
Okay, thanks for the correction. I didn't realize they were all like that as far as the rocker arm studs go. But as far as the header bolt holes, yes, I have seen World BBC heads that the holes broke into the water jackets.
I stand corrected on the BBC rocker studs going into the intake ports. That just seemed kinda weird to me. But as far as the SBC heads go, I had a set of AFR aluminum heads with 195cc ports, and none of the rocker studs went into the intake ports.
As far as the intake manifold bolts, I used ARP bolts, along with ARP thread sealent, and stripped 2 of the threaded holes on my AFR heads with just 36 ft/lbs of torque. So that's why I alwys keep it to 30 ft/lbs for those bolts. I ended up having to heli-coil the bolt holes because of that.
post #9 of 23 (permalink) Old Oct 1st, 07, 9:24 AM
wannabe
Billy, I haven't used a torque wrench on intake bolts in many years(like almost 20). Just get tight by "feel". I doubt they are 35 ft lbs and I don't have problems with them sealing. The center two bolts on each side of an intake like a BBC Victor are not easy to get a tq wrench on. I just use a box end wrench and get them tight enough that way. I also use GM gasket sealer on them as some go into the water jackets. But that's just me.
Jay Campbell
jbird is offline
post #10 of 23 (permalink) Old Oct 1st, 07, 10:07 AM
I hear ya Jay. I do have a tendency to overtighten everything, which is precisely why I use a torque wrench. I often use a boxed extension (kind of like a crows foot, but boxed) on the center bolts to get at that them. As long as you keep it at a 90 degree angle to the torque wrench, your torque values won't change, and will be exactly what your torque wrench is reading. But I don't want to get too far off topic here. Maybe we should get back to Sandy's question.
post #11 of 23 (permalink) Old Oct 1st, 07, 10:31 AM
Actually, you're lengthening the arm and the torque value will change a bit.
69 RS camaro, 410, M22 Autogear, 4-speed , 8 pt rollbar - SOLD
68 camaro - SOLD
67 Bel Air - perfect floors, rockers, trunk. Here we go again!
Rick Dorion is offline
post #12 of 23 (permalink) Old Oct 1st, 07, 11:06 AM
You're only lengthening the arm if you keep the extension straight with the torque wrench. If you put it at a right angle ( 90 degrees) then you're not lenghtening it at all. That's the way I do it.
post #13 of 23 (permalink) Old Oct 1st, 07, 11:30 AM
Banned
Anthony
Thats the way I do it too. Straight out multiplies the torque where 90* keeps it the same length. In my job I use torque adaptors or "dogbones" alot and I have to admit that sometimes I do use them straight out where space is tight. In this case I would use the minimum recomended torque, Harleys always have a min. and a max. torque spec. The lower torque measurments don`t multiply it too much, only 1-3 ft.lbs.
sschevellefan is offline
post #14 of 23 (permalink) Old Oct 1st, 07, 2:04 PM
I gotta tell you I must be doing something wrong
I just don't seem to have all these problems & have been running aluminum heads for over 30 years,,,,,
In that time I think I may have stripped maybe one or two plugs & a couple of bolts
But I certainly have fixed a number of stripped holes so I guess the gorilla tightening system is used on occasion
Like Jay, I have not used a torque wrench on an intake or exhaust bolt in probably 20 of those years now & just do not have problems.
And you are all aware that even the best torque wrenches may have an error of about 3% right?
This is assuming they are calibrated once in a while,,,,
Add another 5 or so percent for "operator" error,,,
and another 5 or so for the different lubes folks use,,,,
Sandy,
Again, my opinion there are just not all these issues with aluminum heads if you use a modicum of common sense with them
There are of course a few "rules"
You don't use straight water
You change your coolant on occasion
You use anti-seize on the fasteners
You use the correct length fasteners
You do not use the "gorilla tightening system"
And,,,
When all else fails follow the instructions,,
Mike (Wolfplace)
VISIT US AT
----John Wayne----
post #15 of 23 (permalink) Old Oct 1st, 07, 2:18 PM
Banned
Anthony
I haven`t torqued a intake manifold or headers ever either and never had a problem. I was just adding my $.02 on the torque adaptor issue.
