Who runs a 427 BBC? Enough or go to 454? - Chevelle Tech
post #1 of 46 (permalink) Old Oct 10th, 03, 9:20 PM Thread Starter
Post
My nephew wants to go Rat in his "71". Needs a crank. He is mystified by the "427" legend and history. I told him to go with a 4.0 stroke crank, just because of more cubes, and better piston selection. I feel the seat of pants feel he will like better. The car is for 90% street and 10% strip. He has a M-21, and factory Rect. port heads, and 4.11 rear. He also wants a Hyd. roller. Other than more revs from the 427 I can not see why he would want less cubes. Maybe if he reads opinions from other people he can make up his mind. Thanks.
fatmattbbc is offline
post #2 of 46 (permalink) Old Oct 10th, 03, 9:39 PM
Post
Go as big as you can. In a 2 ton car you need all the torque you can get especially with a 2.20 low trans.
Mike Feudo is offline
post #3 of 46 (permalink) Old Oct 10th, 03, 9:43 PM
Post
I'd go with a 4" stroke crank.
Although my 427 based BBC works well for what it is, I still wish it was a 454.
10secBu is offline
post #4 of 46 (permalink) Old Oct 10th, 03, 9:56 PM
Post
If you need to buy a crank go with the 4.25 stroke and really have some fun. Tell him to put the "427" badges on everything and only he will know why it rus so good.... Heck I went with the "396" badges all over my car.
I want to die in my sleep like my grandfather...
January 2004 Feature Chevelle
69 SS Chevelle, Pro-Touring, 600+ HP/TQ; A/C, P/S, P/B
1300 Watts of stereo and 11.90 at 118.46 MPH on Goodyear Eagles.
My Showroom
Not screaming and yelling like the passengers in his car.
Redrum is offline
post #5 of 46 (permalink) Old Oct 10th, 03, 11:05 PM
Post
i have always run 454s but the next engine i build IS going to be a 427. the hot trend now is big bore short stroke, you get alot more for your money that way and a much more efficient combination. you put that 3.75 crank in there and bore it+.060 or +.100 and you have everything if not more than a 454 would be.and on top of it the car has a stick, maybe with an auto. you could go 454 that might make some sense.
john [img]graemlins/thumbsup.gif[/img]
1957 Bel Air street/strip 12.90@107.00 retired 1987
1969 chev. SS strip 10.07@132.80 retired 1998
current project 69'chev.SS L78,M21
My Showroom
Well i'm older now and still runnin'... Against The Wind
TriplblackL78 is offline
post #6 of 46 (permalink) Old Oct 10th, 03, 11:12 PM
Post
The big bore short stroke is for power adder cars that need to kill some low end and rev high. NOt a heavy car.
Darracq is offline
post #7 of 46 (permalink) Old Oct 10th, 03, 11:23 PM
JIM
Jim/834
Post
sniff, sniff, I feel so all alone here
My 70 Chevelle
The 454
Keisler/LGT SS700 5-speed
Best ET 11.37 @ 121 Mph
JIM is offline
post #8 of 46 (permalink) Old Oct 10th, 03, 11:24 PM
Post
well isn't that what you want with a 2 ton car running on a 9 inch tire, kill the low end?
post #9 of 46 (permalink) Old Oct 10th, 03, 11:24 PM
Dennis
Post
i would say that there is not alot of different performance wise between the two motors in stock to mild form......i dont think any one here would be able to tell the difference if they was told to drive this car and guess which is it....is it a 427 or 454....just by the feel of the pants mind you.....some of you will get lucky and others would be off.... build according to your budget and what you have to work with......
i know alot of you would argue the point of more cubes but who is really going to know difference......im sure alot of you would drive my race car and would believe it to be a 454 at least because how fast it is....but what would you say if i told you it was a 396 and truely was....like i said many of you would not know the difference build what makes YOU happy not what others think you should build....besides who going to be driving it more.........
http://s50.photobucket.com/albums/f320/ddeennis/
pics of projects and whatever.
ddeennis is offline
post #10 of 46 (permalink) Old Oct 10th, 03, 11:35 PM
Post
...when you ask an opinion...multiple answers you will get.
If he wants to build a 427 there will be no harm done, so let him do it. Too bad he wants a hydraulic roller - he'll miss out on the solid flat tappet/solid roller rpm capability of the 427. A 427 at 7,000+ rpm has a song of its own. Have him sell the rectangular port heads and get ovals instead. I cannot think of any sub 6,500 rpm 427 that would need the port volume of the rectangular port heads.
Thomas
El Caminos a pair: '67 Bomber, '65 496
Avanti, Corvette and more
Bomber '67 is offline
post #11 of 46 (permalink) Old Oct 10th, 03, 11:36 PM
Post
kinda the point i was trying to make,my friends 68 camaro with a 447 (100 over427) and my car 69 chevelle with a 468, both weighing the same, his went 10.16 and mine went 10.17 on the same day, but he probably had only 2500.00 in his motor and i had around 4grand in mine. and who is driving more? the nephew who is mystified with the 427s, right?
[img]graemlins/beers.gif[/img]
post #12 of 46 (permalink) Old Oct 11th, 03, 12:26 AM Thread Starter
Post
That is two things I tried to explain to him, 1.) He be better off with 049 or 781 large oval ports for the street and 2.) That a solid flat tappet would be a better choice than a hyd. roller, a solid roller even better. He reads that GM put the Rect. heads on 396's, 427's, and the 454, and thinks that is what is needed for a fast car. But I told him that in the long run it is his money and car and having fun is the most important thing.
post #13 of 46 (permalink) Old Oct 11th, 03, 1:14 AM
Post
Years ago I had a 396 with basicly the same parts as my friends 454, both in 70 chevelles. I saw alot of his tail lights. The seat of the pants difference was even more dramatic. A 427 is a great engine and people go fast with them, its just hard to argue with cubic inches.
70 chevelle
420 sb combo - 10.93@120.76mph
405 sb combo - 11.87 @112.5
307 combo - 12.91@105.33
68 chevelle 533 almost there
68chevelle533 is offline
post #14 of 46 (permalink) Old Oct 11th, 03, 1:22 AM
Send a message via Yahoo to smittyocat
Post
I have run a .060 over 396 for years with great success the motor is a 10.5:1 closed chamber oval port engine with an 850 DP,HEI, Isky 292/590 cam, steel roller tip rockers,torker intake manifold. with a TH400 and 3500 conv. In my 69 Malibu full body 3,600 lb car with 4:56 gears it has run consistent 11.60's not bad for a "baby rat"
1969 SS396 4spd 12 bolt Lemans Blue
1966 ElCamino custom 396 4 spd
My Homepage
smittyocat is offline
post #15 of 46 (permalink) Old Oct 11th, 03, 1:46 AM
Post
Open mouth insert foot [img]graemlins/clonk.gif[/img] Didn't mean to step on any toes. I grew up in the 396 era of the early 70s. They were very popular back then. Had to build one, and I beat my share of 454s with it. But didn't beat too many with similiar setups.
70 chevelle
