Car dies after 20 mins. - Chevelle Tech
post #1 of 21 (permalink) Old May 30th, 07, 9:50 PM Thread Starter
Well now that my whole distrubitor is changed its HEI, due to my lack of spark when the car got hot, now the car just dies when i put it in gear after it warms up. And im gettin spark now even when it dies.
Never happened before, And to get it to start again, i have to put my foot basically all the way into it and play with the gas for a few second to get it to idle again. then dies immediatley and backfires through the carb when put in gear....what is my problem>? PS the car never runs hotter then 170, its a 355 sbc.
When it gets cold again, im gunna start it and see if it will run in gear while still not fully warm. Ill let everyone know if it runs like that or not.
Thanks guys
jcchevelle is offline
post #2 of 21 (permalink) Old May 30th, 07, 10:00 PM
Gary
Re: Car dies after 20 mins.
If your sure the timimg is right it sounds like its to lean at idle. check for vacuum leaks and anything you disturbed while working on it. I assume it has a choke and thats why it will idle cold.
gnicholson is online now
post #3 of 21 (permalink) Old May 30th, 07, 10:09 PM Thread Starter
Why, and how would it change all of a sudden? And does that explain the backfiring? Thanks Again
post #4 of 21 (permalink) Old May 30th, 07, 10:30 PM
Patrick
I had that happen to me once. car would start fine but after a while it would die. Occasionally I would notice a very strong fuel scent. Ended up that one of my main jets was clogged with clear wrap after I rebuilt it. Even a small amount of debris in the carb can cause all kinds of problems.
Patrick
bb489 is offline
post #5 of 21 (permalink) Old May 30th, 07, 10:56 PM Thread Starter
hey guys, just to make sure, about my timing, heres what i got running, maybe someone can give me some input on what they reccomend for timing.
355 sbc
Sportsman II heads
vodoo cam-- Advertised duration 276/284
Duration @ .050 233/241
valve lift .504/.525
LSA/ICL 110/106
Magnum roller tips
10:1 comp.
i also have a high output mechanical fuel pump, with a regulator set to about 5 psi. ( it always varys..i think from the heat)
i have my intial at about 16-18 with my vaccume plugged at idle, Its and a brand new Proform HEI high performance distributor. sound about right for this engine?
post #6 of 21 (permalink) Old May 30th, 07, 11:13 PM
That sounds like a lot of initial. Use whatever works best, don't stick to a certain number. Kinda does sound like a vacuum leak though. Is your vacuum advance hooked up to full or ported? Does it die with the vacuum advance disconnected and plugged?
Fried_Guy is offline
post #7 of 21 (permalink) Old May 31st, 07, 10:46 AM
Bryan
If the HEI is using existing wiring---that could be the culprit.
Cannot use the existing ballast or resistor wire, need a good 12ga or bigger wire run frrom the ign sw to the dizzy.
Also could be a FUBARed module or coil.
my 59 was doing that (shutting down---no start) and I changed the coil and the module, not a problem since.
Still not sure what the culprit was---have not bothered to check the coil.
Modules can check okay----but when they heat up, can fail.
Bryan
Bryan's toyz
66 ElCamino 3oh7/TKO 5spd (mousey) Almost done On the street now!!!
Bryan59EC is offline
post #8 of 21 (permalink) Old May 31st, 07, 5:55 PM Thread Starter
Bryan
Bryan, the module and coil are both new, and it was hei to begin with, this is not a swap from points, and the coil is 10 or 12 guage, not a small 16 guage wire or anything like that.
post #9 of 21 (permalink) Old May 31st, 07, 7:18 PM
Patrick
Again, make sure your carb is clean inside without debris. I don't think a vacuum leak would only cause it to die when it is warm and timing is timing. Once it is set right, it is not going to change when your car warms up. My bet is either you got a tooth or two off with the rotor when you put the dizzy back in, or your carb is dirty inside and may be holding a needle and seat open causing it to flood and die. The next time it happens, hop out real quick and see if your carburetor inlet and venturi are all wet with fuel. I had the EXACT same symptoms as you and as I said earlier it turned out to be a piece of debris in one of my main jets.
Patrick
bb489 is offline
post #10 of 21 (permalink) Old May 31st, 07, 9:15 PM
eric
don't consider a part good beause it is new!!!!I work in a dealership and replace "good new parts" all too often.in todays age of everything made in mexico or china I take no chances. good luck
eric
flpackerbacker is offline
post #11 of 21 (permalink) Old May 31st, 07, 11:33 PM
Bryan
eric
My 59 Elky had less than 400 miles on a BRAND NEW mallory HEI
yep new parts can be bad
9 mo and a bit over 2000 more miles----no issues (whole car only has 2550mi on it)
Bryan
Bryan's toyz
post #12 of 21 (permalink) Old May 31st, 07, 11:54 PM
Antonio
Just make sure when your checking for the "wet spots" its not just about ready to blow your head off... I've had a carb spit fire on a buddy while he was being curious and he lost his eyebrows and bangs... all in one puff!..
Where safety glasses if your going in head first. :-)
1969 Chevelle Malibu
383 Stroker 425HP/700r4
In Progress:
Springs and shocks
...and everything else
Ando is offline
post #13 of 21 (permalink) Old Jun 1st, 07, 11:04 AM
Bryan
Also no nylon or rayon type clothing!!!!!!!!!!!!!!
My father was burned on about 30% of his body when his shirt caught a
carb burp, and only took an instant for his clothes to melt to his body.
3 weeks in a burn unit---and then had to stay out of the sun for the next 5 yrs.
Had to sell his new boat (27' Scarab), cause he could not take it out anymore to enjoy it.
100% cotton won't melt to you
Bryan's toyz
post #14 of 21 (permalink) Old Jun 1st, 07, 1:54 PM
Ken
All of what Bryan59EC says: I would still replace the module. I had to buy 4 thermostats before I got one that worked right. Modules are much more complicated. And cantankerous.
Make sure you dist cap is spotless inside; that there is no oil or dirt that could be carbon tracking. Always wear some kind of clean gloves when working on ignition parts to keep finger prints off high voltage parts.
kirkwoodken
406 SB, Original Bill Thomas '63 Rochester FI
AFR 210, Lunati 501C2LUN, 255/263@.050", .628"
10:1, TH400, 3.31's, 4400 SS
"Life is too short to not run a solid roller cam."
"Nothing is impossible; if you don't know what you're talking about."
Kirkwoodken
kirkwoodken is offline
post #15 of 21 (permalink) Old Jun 1st, 07, 2:01 PM
You say your getting spark when it dies, is getting fuel when it dies? Could be fuel system issues (ie: heat soak, debris, clogged filter)
71 Chevelle SS: 396+.06 10:1, t-56, 4:10, Lunati 00024, merlin ovals<br />72 Chevelle ss: 350+.030 10.5:1, 150 n20, ST-10, 4:56. 1.76 60', 11.81@115
71rat408 is offline
