When is too much oil pressure, too much? - Chevelle Tech
post #1 of 11 (permalink) Old May 23rd, 07, 12:31 AM Thread Starter
P evaD
So, now that I'm really starting to put the miles on the motor, I'm noticing that I think the oil pressure is too much. Even when it's up to temp, cruising down the freeway at 70MPH, I've still got 75#'s oil pressure. Heck, just idling at temp it's still around 40#'s.
I originally had a Melling HV 55, but my builder said it was too much, and used a stock type pump. I think the pump/oil pressure is to blame for my leaky motor.
I don't know, is it too much pressure?
Dave P.
1971 Chevelle
11.44 @ 118.43
Leading by example.
Curing cancer, one body panel at a time.
My Chevelle
now
Before
Motorvation
Resurection home page
Dave is offline
post #2 of 11 (permalink) Old May 23rd, 07, 3:34 AM
Re: When is too much oil pressure, too much?
If you don't ever see over 100, I think it's ok. I know a few racers that see a bit over a 100 with no problems. 70 at idle would be too much though. Cold idle, I have 40, 30 at hot idle. Mine is a HV pump though. Didn't really make a difference when I switched from the Z28 pump. I think the number was M55A or something like that.
Jay Nakamura
Race Cause You Love It
Amsoil Authorized Dealer
Check out my website: http://www.synthetic-oil-tech.com/1483414
1970 Chevelle "Green Bean"
Http://www.nakamuraracingsports.com
nakamura_racing_sports is offline
post #3 of 11 (permalink) Old May 23rd, 07, 8:04 AM
Frank
Our small block can run up to 80+ psi cold and 60psi to 70 running at speed, 30 psi hot idle. We do use the HP4 Filter to avoid leakage at the filter gasket during cold starts. The pump is the Melling HV. No other leaks for the past 8 years.
My question is where is the engne leaking from? VC gaskets? Pan? Intake? You may want to look at the pcv system and see if you are building crankcase pressure. Excess crankcase pressure will cause some leaks.
Is it a fresh engine? If so, some of the bolts may need to be re-tightened from heat cycling.
Just some thoughts, Hope this helps.
Frank G.
FTG53
"Many of life's failures are people who did not realize how close they were to success when they gave up." Thomas A. Edison
ACES 3995 TC3031
'67 Malibu
http://www.chevelles.com/showroom/da...3_Chevelle.JPG
'70 Malibu - Finally Painted
http://www.chevelles.com/showroom/da...chevelle_1.JPG
'73 Malibu - Next Project
FTG53 is offline
post #4 of 11 (permalink) Old May 23rd, 07, 1:05 PM
Anything over #100 is BAD for "babbitted" bearings. (That grey stuff on the bearings that you can scratch with a finger nail.) If you really have to have that much pressure you should run aluminum faced bearings.
That said, its been my experience over the years that any SBC will live nicely at unreal RPM with oil pressure at #40 lbs for drag racing purposes especially if you have a baffled pan to control oil movement. Likewise when on circle tracks oil pan baffling is critical.
The issue with "babbitted" bearings is that ultra high oil pressure will "shear" the babbit off and increase your bearing/crankshaft clearance. Not desirable.
charbilly2001 is offline
post #5 of 11 (permalink) Old May 23rd, 07, 1:55 PM
sounds like the builder forget to get rid of the HV pump to me.
post #6 of 11 (permalink) Old May 23rd, 07, 2:00 PM
My understanding is a high volume pump just moves the oil faster? A high pressure pump is what is causing your higher than normal readings. I've got High volume pumps in mine, but the "pressure" seems to read normal.
busterwivell is offline
post #7 of 11 (permalink) Old May 23rd, 07, 7:54 PM Thread Starter
P evaD
The leaks are actually minimal, just a small drip out of the main seal, and a little seepage on the oil filter. I just don't like oil leaks.
The Builder didn't forget to leave the pump out, I brought the Melling, and He didn't want it, so I sent it back to Summit. He got one to install, if I remember correctly, it's a stock type unit. I'm gonna have to try and get ahold of him to find out.
I'm just curious as to if that much pressure is a bad thing? I know that if I was trying to wring every last pony outta her, it wouldn't be, but as it stand's, I shouldn't have to worry about getting oil to the motor.
I guess one thing I wonder about is, with the hydraulic lifter issue that I had, switching from the Crane anti-pump ups, to the Comp 812's (Stanadyne,I believe) made a huge difference in the noise of the valvetrain. Now, I'm wondering if the excessive oil pressure is not allowing my lifter's to have a little give? Hence, some of the sewing machine sound.
Dave P.
1971 Chevelle
11.44 @ 118.43
Leading by example.
My Chevelle
now
Before
Motorvation
Dave is offline
post #8 of 11 (permalink) Old May 23rd, 07, 8:35 PM
anti-pumpup lifters are expected to be noisy as the have a looser fit on the internal piston. These lifters don't actually prevent pump-up, but allow it to bleed off much faster resulting in quicker recovery from the pump-up situation.
excessive oil pressure is not somehow "better" than normal oil pressure in any way and can cause issues not found in engines with normal oil pressure.
any chance you've got an electric gauge with the wrong sender? there's senders for 60lb and senders for 80lb gauges, they're not interchangeable.
post #9 of 11 (permalink) Old May 23rd, 07, 9:02 PM Thread Starter
P evaD
Mechanical gauge. I'm pretty sure it's correct, as when I adjusted the lifter's while running, it had alotta pressure.
Dave P.
1971 Chevelle
11.44 @ 118.43
Leading by example.
My Chevelle
now
Before
Motorvation
Dave is offline
post #10 of 11 (permalink) Old May 24th, 07, 7:46 PM Thread Starter
P evaD
So, Anybody got any solid opinion's on this? I'm kinda thinking bout pulling the motor, bumping the cam, and maybe changing the oil pump?
Dave P.
1971 Chevelle
11.44 @ 118.43
Leading by example.
My Chevelle
now
Before
Motorvation
Dave is offline
post #11 of 11 (permalink) Old May 24th, 07, 8:56 PM
Keith
From my experience the L78 and L72 engines work fine with the stock setup. Most died from dropped valves, not from lubrication problems. Our L72 had close to 200K miles on it and saw 7200 on occasion. No problems. We've put abut 30K on our L78 car and about 15K on a previous L78 car. No problems either. With Chevies, more is not better for the most part. Excessive oil pressure just eats up horsepower that we try so hard to gain in the first place. Advertising does sell a lot of aftermarket stuff though.
Keith Tedford is offline
This Thread is more than 3629 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
