Used rings in a sbc??? - Chevelle Tech
post #1 of 11 (permalink) Old Apr 9th, 07, 2:07 PM Thread Starter
Just curious if you were to pull a motor apart with say 2000miles, rehone the bore and put the pistons and rings back in do you think they will reseat again or not?
jester1 is offline
post #2 of 11 (permalink) Old Apr 9th, 07, 2:13 PM
Send a message via MSN to Whiskey
Re: Used rings in a sbc???
Just curious but if you put the pistons back in the same holes then all should be fine without honing. Unless you took it apart and found a prob with a cylinder.
68 Chevelle
427 w/Merlin heads
10.2 to 1 comp
Hooker headers
Art Carr 200R4 w/3500 stall
3:90 Posi
72 SS 454
Hooker Headers
400 turbo
3:31 gears
Whiskey is offline
post #3 of 11 (permalink) Old Apr 9th, 07, 2:16 PM
Sean
rings are cheap. why not just go to the small trouble of replacing them since you already have it apart?
Sean
'65SS, 385ci, AFR 195's, Comp XR 288HR, Forged bottom end, TKO600, 3.73/12 Bolt
Now in our new home in Tucson AZ
http://spotted.stripes.com/galleries....php?id=337573
"Aint no fun 'till somethin gets broke!"
troposcuba is offline
post #4 of 11 (permalink) Old Apr 9th, 07, 2:26 PM Thread Starter
I found two cylinders scored slightly. I didnt want to blow $130 on a new set of rings concidering it would be a temp. engine. However i dont want to rip it apart because the rings dont seat. Just a little anxious to put it together.
jester1 is offline
post #5 of 11 (permalink) Old Apr 9th, 07, 3:16 PM
Dennis
my current 468 i pulled the pistons out and cleaned the block ( cam died and left metal everywhere) and put my pistons and rings back in the same hole.
sealing fine so far.
http://s50.photobucket.com/albums/f320/ddeennis/
pics of projects and whatever.
ddeennis is offline
post #6 of 11 (permalink) Old Apr 9th, 07, 3:31 PM Thread Starter
thanks,
two 80 Z's me too
Whats the 468 run?
jester1 is offline
post #7 of 11 (permalink) Old Apr 9th, 07, 3:45 PM
Dennis
so far its running 12.50@ 111 mph w/ stock suspension and air shocks out back and 245/60-15 uniroyals, i just got this 468 combo together about 3 weeks ago and have two passes down the track with it.
11.8 to 1 motor on 91 octane fuel.
sure has been fun to drive.
heres a rear pic of it at the drags.
http://www.midamericadragway.net/inc...1?idx=4&p=1071
ddeennis is offline
post #8 of 11 (permalink) Old Apr 9th, 07, 4:28 PM Thread Starter
You should check out Nastyz28.com when you get a chance. great bunch of guys there. Lots of cool Zeds
jester1 is offline
post #9 of 11 (permalink) Old Apr 9th, 07, 5:35 PM
Dennis
ya i visit there often,under same name, but i sure like the bbc information here.
ddeennis is offline
post #10 of 11 (permalink) Old Apr 9th, 07, 9:28 PM
JIM
I can't even imagine putting them back in....especially if you found two scored cylinders. Don't you figure those rings ran up and down over all those scratch marks? What do you figured scored them in the first place?
Call Competition Products and get some cheap Howards rings (repackaged Mahle's). They work great.
JIM
540Hotrod is offline
post #11 of 11 (permalink) Old Apr 9th, 07, 11:48 PM
Ken
Use new rings!!!!!! At least you will have 6 cylinders running at their best.
I tried it once with a 327 made out of junk parts laying around the garage. Nasty crank, used inserts and rings, old 461's, knurled 11:1 pistons to fit a sloppy bore, don't remember the cam, but it was a Chevy solid, maybe 140. Did have Isky valve springs; couldn't skimp there. Eddy 4CB, 780 Holley. Had headers. 4 speed, 4.56. Ran 13.1, 104 in my old 68 Camaro. As much exhaust came out of the breather pipe as it did the headers. Had a VERY soggy bottom end; lots of blowby. To put this in perspective, a stock, tuned, '68 Z28, with headers, and 4.56 or 4.88 gears would run mid 12's.
kirkwoodken
406 SB, Original Bill Thomas '63 Rochester FI
AFR 210, Lunati 501C2LUN, 255/263@.050", .628"
10:1, TH400, 3.31's, 4400 SS
"Life is too short to not run a solid roller cam."
"Nothing is impossible; if you don't know what you're talking about."
Kirkwoodken
kirkwoodken is offline
This Thread is more than 3696 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
molly rings vs cast rings david_396 Engine 9 Jul 11th, 07 12:07 PM
Replacing rings in a SBC 400? Spoileddaddy Engine 4 Oct 7th, 06 2:50 AM
Extreme use 502 rings? 502fogger Performance 5 Mar 6th, 06 12:20 PM
Hastings piston rings installation help! 68ElCamino Engine 6 Feb 9th, 03 9:50 PM
Muncie help 69velle Transmission & Driveline 3 Dec 22nd, 02 10:28 PM
