shifter mount. - Chevelle Tech
post #1 of 12 (permalink) Old Mar 9th, 07, 9:48 PM Thread Starter
tony
shifter mount.
welded up a shifter mount for the velle, b&m mega shifter did not sit flat, welded up two pieces of angle to fit floor. welded bolts up through bottom for mounting shifter and welded mount to floor. also welded up holes from old shifters in floor, still have to weld up hole that someone hacked in floor for old shifter cable.
malibu356 is offline
post #2 of 12 (permalink) Old Mar 10th, 07, 8:44 AM
Rob
Re: shifter mount.
Looking good Bro!!
And I must say,,,,those are some cherry looking floor pans
66rat is offline
post #3 of 12 (permalink) Old Mar 10th, 07, 9:02 AM
Re: shifter mount.
Was this an original auto floor shift car. I have original auto staple shifter and am considering swapping over to ratchet type...I was wondering if the B & M will bolt to the original brackets or do they have to be modified ?
FOSS
FOSS is offline
post #4 of 12 (permalink) Old Mar 10th, 07, 9:58 AM Thread Starter
tony
Re: shifter mount.
no it is a colunm shift origanaly, do not know if your brackets will work.
post #5 of 12 (permalink) Old Aug 9th, 07, 5:18 PM
David
Send a message via AIM to turbopowered68 Send a message via Yahoo to turbopowered68
Re: shifter mount.
where did you drill the hole for the cable.
1968 Chevelle Twin Turbo, LQ4, 4L80 coming soon
1987 Buick GN Bone stock
1986 GN T-Top - 200-4R Transmission built by David Husek AKA http://turbobuickperformance.com/ 1-516-285-1103
1968 Convertible chevelle work in progress
1963 Impala 350 Throttle Body injection.
2001 Ninja ZX-7R
turbopowered68 is offline
post #6 of 12 (permalink) Old Aug 16th, 07, 9:54 PM
David
Re: shifter mount.
2001 Ninja ZX-7R
post #7 of 12 (permalink) Old Aug 17th, 07, 1:11 AM
Re: shifter mount.
I believe he is trying to say where did you drill the hole for the cable?
Raupleminze454 is offline
post #8 of 12 (permalink) Old Aug 17th, 07, 11:46 AM
Gary
Re: shifter mount.
Cable? what cable?
Smittie is offline
post #9 of 12 (permalink) Old Aug 17th, 07, 11:08 PM
Re: shifter mount.
The original brackets from the staple shifter will not work. I did something similar to what he did except I used two pieces of 3" channel clamshelled together until i got the height right. I then welded them together at that height. I tapped the top channel so i could bolt the shifter to it without nuts. The bottom channel has some cut off 1/4" bolts in it so I could level the hole thing to the hump and then when it sat nice I ran some self tapping screws through it to fasten it down.
I made a trim panel to lay in the console where the old staple shifte bezel was. The hurst shifter cover now bolts to the panel and it looks damn close to a factory install. I have had quite a few guys ask me how I went about it after seeing it. Wish I had taken some pictures of the mount but I didn't...
Somewhere I have some pictures of the finished product if you're interested, I'll try to find them.
Troy.
1970 454 SS
460ci Big Block,
Brodix Race-Rite Ovals (115 CNC chamber)
10.2:1 compression
Lunati/UD 276/284 Solid
Performer RPM Intake, Mighty Demon 850
TH400, 4.10's - BTE 10" 3200 conv.
Mostly show but can go!
Best ET 11.72 MPH 115.1
Troy70SS is offline
post #10 of 12 (permalink) Old Mar 18th, 14, 1:27 PM Thread Starter
tony
Re: shifter mount.
Sorry for not being around in a few years, had a battle with cancer shortly after my last post working on the chevelle. boat racing took over after that for a few years and then we were hit by sandy, i lost a lot of the chevelle parts in the storm.
I have started back on the chevelle project and i am also still rebuilding from sandy..
Tony...
post #11 of 12 (permalink) Old Mar 18th, 14, 7:36 PM
Vegas TC Ambassador
Re: shifter mount.
Wow, seven years between posts.
Rowdy
'66 Malibu
540cid 753.8hp 673.4tq
COAN Extreme Street Th400/10"
3.55 12 bolt Auburn posi
DAILY DRIVER
BEST: 60' 1.59 / 1/4 10.591 / MPH 129.70
3770 lbs, 91 Octane, M/T ET Street Radials
http://www.youtube.com/watch?v=88c6MLbQvEI
http://www.youtube.com/watch?v=rTd2O5fZ2lU&NR=1
Rowdy is offline
post #12 of 12 (permalink) Old Mar 18th, 14, 9:44 PM
Re: shifter mount.
Welcome back. It sounds like you beat the cancer, congratulations.
Steve R
Steve R is online now
Vintage Hurst Automatic Shifter??? vlevick Transmission & Driveline 9 Feb 12th, 07 11:55 PM
Factory shifter handle on a Hurst shifter?? 2th farmer Chevelle Tech 4 Feb 7th, 07 12:31 AM
Anyone using the 19.5" shifter location on tremec scottie Transmission & Driveline 4 Jan 10th, 07 8:27 PM
Transmission and Shifter Question (Dimensions) Wwalstrom Transmission & Driveline 1 Oct 28th, 04 5:03 PM
TREMEC 5sp custom shifter available! mjpell Transmission & Driveline 0 Feb 10th, 03 8:03 PM
