Anyone else with a noisy hydraulic voodoo cam? - Chevelle Tech
post #1 of 22 (permalink) Old Aug 18th, 06, 9:06 PM Thread Starter
Send a message via AIM to JCs70
A few trips after my initial breakin with my hydraulic voodoo cam, and magnum roller tipped rockers, i started to hear some valvetrain noise, i would get a small tick. Anyone else have a noisy voodoo cam, or am i looking at a bigger problem here? Thanks Josh
p.s. its not a roller cam...
JCs70 is offline
post #2 of 22 (permalink) Old Aug 20th, 06, 6:48 PM Thread Starter
Re: Anyone else with a noisy hydraulic voodoo cam?
Just incase most of you just assume, that i need to adjust my vavles again, i have done it about 4 times now, and i still get the tick back...I didnt have it during the break in, or ide say, the first two trips out, after that...it has been a sound that i dont like to hear, unless its no big deal!!
JCs70 is offline
post #3 of 22 (permalink) Old Aug 20th, 06, 7:10 PM
"Wild Bill"
Which Voodoo cam?
We've used 4 different Voodoo SB hyd flat tappet ones to date with zero noise out of any...very much unlike the XE Comp line which are noisy as he!!.
Team Chevelle #613
ACES #3920
CAMI (Ireland) #14
CanAm Chevelles #136
Carolina Chevelles #185
Heart Of Dixie #231
Long Island Chevelles #113
BillsCamino is offline
post #4 of 22 (permalink) Old Aug 20th, 06, 7:15 PM Thread Starter
bill, its lunatis 60104 and the lifters are correct, i bought the kit.
JCs70 is offline
post #5 of 22 (permalink) Old Aug 20th, 06, 7:26 PM
If the noise goes away when you adjust them and then comes back repeatedly, then yes. I'd be worried...
zwede is offline
post #6 of 22 (permalink) Old Aug 20th, 06, 7:38 PM Thread Starter
it doesnt go away n come back, it is there always, even after adjusting the vavles. Im just saying, i dont remember hearing it during breakin.(but again, that was with open headers) It doest get better or worse either, its just there.
JCs70 is offline
post #7 of 22 (permalink) Old Aug 20th, 06, 7:51 PM
If you are eating a lifter, it should get worse. The voodoo cams I have installed have been pretty quiet though. Could be your rockers or even the valves themselves making the noise as they make contact with the seat. Could also be a small leak around your header flange.
Again if your are getting the noise soon after breakin and it doesn't get worse I don't think it's the cam. They go pretty quickly once they start to fail. Can you take the tick out at all during the adjustment if you do it while running?
1970 454 SS
460ci Big Block,
Brodix Race-Rite Ovals (115 CNC chamber)
10.2:1 compression
Lunati/UD 276/284 Solid
Performer RPM Intake, Mighty Demon 850
TH400, 4.10's - BTE 10" 3200 conv.
Mostly show but can go!
Best ET 11.72 MPH 115.1
Troy70SS is offline
post #8 of 22 (permalink) Old Aug 20th, 06, 8:18 PM
"Wild Bill"
Same cam kit we put in my bro-in-law's 383 '69 Malibu back in May.
I believe I put on a set of Trick Flow 1.5 rockers at the same time.
No valve train noise.
And I know "noise"...we replaced a XE268 with the Voodoo.
BTW...nice cam!! His Chevelle runs mid 12s, very streetable and PBrakes work fine.
Team Chevelle #613
ACES #3920
CAMI (Ireland) #14
Heart Of Dixie #231
post #9 of 22 (permalink) Old Aug 20th, 06, 9:03 PM Thread Starter
Bill, i like the came as well, however i do not produce enough vaccume for power brakes. Im running them off of manifold vaccume, but its a Team G Hi-Rise intake.
I havent tried to adjust the vavles, with the engine running, i guess thats the next step. Thanks for the help bill.
JCs70 is offline
post #10 of 22 (permalink) Old Aug 20th, 06, 9:33 PM
I put a set of magnum roller tip rockers of my 90 Chevrolet P-U many years ago and it was noisy from then on. Not the cams fault, I'm sure it was the rockers. Try a set of full rollers or even long slot stamped rockers and see what it sounds like.
Jeff Evans
65 Chevelle 498 ci/TH350/12 Bolt 3.42
Best Performance 11.56 @117.80 mph(9/12)
Best 60' 1.62 (M/T Drag Radials)
http://www.chevelles.com/showroom/da.../bbcengine.jpg
Jeff65SS is offline
post #11 of 22 (permalink) Old Aug 20th, 06, 9:47 PM
I' installed a Voodoo 262 and a 268 in the same 454 . Believe it or not, the 262 had an almost solid sound to it. Both were kits from Summit. I did notice that the lifters in the 262 kit had a shallow spiral groove around part of the body. Haven't called Lunati yet,but it's on the list!
nitrofox is offline
post #12 of 22 (permalink) Old Oct 6th, 06, 9:28 AM
I have a noisey Voodoo 268 in my 460 BBC. I installed their lifters. The noise is present mostly on deceleration or light load. When the engine is pulling hard ther is no noticeable valve noise. The engine will not pull to 6000 RPM. I think I have valve float. I used the correct springs though. I have one lifter that seems to lose its prime if the car sits for a few days. Overall I have been a disappointed with the cam/ lifter noise.Any help or advise would be appreciated. ---- Thanks
Phil68chevelle is offline
post #13 of 22 (permalink) Old Oct 6th, 06, 10:48 AM
Remember the BBC has a greater rocker ratio than the SBC, so the valve velocities (valve action - opening, seating, etc) will be faster. The SBC will have slower action at the valve since the rocker ratio is less. The noise may be coming from the valve seating.
70GS455 is offline
post #14 of 22 (permalink) Old Oct 6th, 06, 11:37 AM
Not sure what engine you have but especially on the small blocks with cast aluminum valve covers watch for contact between the pushrod end of the rocker arm and the side of the valve cover. You can usually see little scrub marks if they touch on the inside of the valve cover. Minor clearance work on the rockers will solve the problem.
I chased a noise caused by this for a while and sometimes when I checked/adjusted lash it would go away. Turns out it was going away because I set the valve cover down a little differently when putting her all back together.
E85 racer and E85 carb builder
www.horsepowerinnovations.com
68 Camaro 427" E85 burning small block. 9.90 @ 135 mph through the mufflers on motor. Best 60' 1.319 on motor. 5.92 @ 116 1/8th mile on spray with 1.425 sixty on the back tires.
http://i29.photobucket.com/albums/c2...tational00.jpg
Eric68 is offline
post #15 of 22 (permalink) Old Oct 6th, 06, 11:41 AM
I have a similar problem.
I have a SBC 406 with the Voodoo 60111 Hyd Roller cam, Lunati lifters PN 72430 (made by Morel) and Comp's Pro Magnum full roller rockers. I adjusted the rockers a couple of times only to see that they were adjusted correctly already. I've inspected the springs, pushrods, and rockers for any abnormal contact but havent found anything. The engine runs GREAT! with lots of power. BUT IT SOUNDS LIKE A DIESEL at idle. At higher engine speeds other noises become loud enough to drown it out.
I'm at my wits end. I'm thinking that the roller tips on the rockers have a lot of side to side play and maybe thats causing the noise. I'm going to try some stamped rockers to see if the noise goes away.
Clark
Clark is offline
This Thread is more than 3853 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Help Lifter niose Lunati voodoo cam AlsChevelle Engine 8 Aug 11th, 06 9:59 PM
New to the site, and Voodoo Cam selection HarrisonTX Performance 6 Nov 4th, 05 9:01 PM
How to install Voodoo 60201 Cam Chevyboy Performance 5 Aug 21st, 05 10:12 PM
Voodoo BBC 268 cam cut with a 112 LSA Caplin Performance 6 Jul 28th, 05 8:33 AM
UDHarold update on voodoo cam in 396 Kevs68 Performance 3 Jul 11th, 05 8:13 AM
