110 lsa vs. 112 lsa - Chevelle Tech
post #1 of 3 (permalink) Old Mar 29th, 06, 4:16 AM Thread Starter
110 lsa vs. 112 lsa
Just out of curiosity can someone please enlighten me on the differences?
From what I have gathered so far the 110 has more of a lope and the 112 is smoother but other than that what else is the difference between the two? Is the 112 more suited for street cruising and the 110 more for strip and street combined?
'71 Malibu 402 big block/TH350 trans - Sold 2 Jan '08
How to tell if your car is a true SS or not:http://www.chevelles.com/shop/ss_ident.html
Junkyard Dawg is offline
post #2 of 3 (permalink) Old Mar 29th, 06, 11:58 AM
Royce
Re: 110 lsa vs. 112 lsa
Reall basic: The wider lobe seperation the wider the powerband. meaning the 112 LSA will have a wider powerband than the 110. BUT, (there's always a but), the 110 will make more PEAK power than the 112. This is assuming all things are kept equal. Is one better than the other? NO. It's all about what your combination needs. The narrower you get the LSA the more peaky the engine becomes, in some cases that is what you want, in others it's not.
Royce (NO XQSSS) Bradley
www.facebook.com/driveyourjunk
Short Video w/sound Blown SBC 1961 Skylark, Borla mufflers and 3 1/2" exhaust.
http://www.youtube.com/watch?v=DSLsGgDjFXE
camaroman7d is offline
post #3 of 3 (permalink) Old Mar 29th, 06, 1:07 PM
JTW
The 112 will likely produce more vacuum than the 110 also, which may be necessary for power brakes. I had my hyd. roller cam ground with a 111 LSA.
JTW is offline
This Thread is more than 4107 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
