1978 Chevelle weight - Chevelle Tech
post #1 of 22 (permalink) Old Sep 19th, 05, 8:32 PM Thread Starter
Anyone out there got a big block in a 78 chevelle malibu ??
Is it easy to get the weight down around 3000 pounds ??
1966 Beaumont SD
hydraulic roller 468 12.22 at 109
1970 Nova
solid roller 461 11.49 at 119
Sandy is offline
post #2 of 22 (permalink) Old Sep 19th, 05, 8:39 PM
Green Weenie
Send a message via Yahoo to Bob West
Re: 1978 Chevelle weight
no such animal,,,quit making Chevelles (A body) in 77 I believe, then it was just a Malibu,G-body, whole new deal. Todd races his at 3500+ I believe w/driver, correct me if I'm wrong.
Bob West is offline
post #3 of 22 (permalink) Old Sep 19th, 05, 8:46 PM Thread Starter
Yes, it is one of the small ones........looking at one that has been back halved with a 9 inch ford and room for 12.5 X 31 tires.
Could be a good "beater" race car if the weight can be gotten down a bit.
3500 seems heavy
1966 Beaumont SD
1970 Nova
Sandy is offline
post #4 of 22 (permalink) Old Sep 19th, 05, 9:06 PM
Bob's right. My malibu is a 79 and is all steel except for the fiberglass hinged hood and a fiberglass front bumper. I have all the undercoating removed, no sound deadener, no heater or A/C, no back seat, crash bars removed from the doors. The car has a 12 gallon cell in place of the stock tank, aluminum radiator, aluminum intake and water pump, 10 point mild steel cage, two plastic racing seats, stock dash & steering column. The weight as it sits is 3515 lbs with the iron headed bbc/th400.
IMO, the only way to get a bbc in a Malibu down to 300 lbs is with a fiberglass front end, doors, trunk lid, lexan window, aluminum heads, light weight brakes front and rear, likely R&P steering in place of the cast iron manual steering box, etc.
A back half car will weigh less than a small tire car like mine, but your removing weight in the wrong place. I was speaking with a friend at US13 who races a back halved Malibu and his has 60% of the weight on the nose compared to 55% on mine. If your gonna take weight out, it needs to come out of the front, not the rear.
So while you may think 3500 lbs sounds heavy, it's what a full steel bodied Malibu weighs with an all iron bbc under the hood.
10secBu is offline
post #5 of 22 (permalink) Old Sep 19th, 05, 9:47 PM
that's counting you too though isn't Todd?
71malibu406 is offline
post #6 of 22 (permalink) Old Sep 19th, 05, 9:49 PM
Yes, that's race weight with me (200 lbs) and a 12 gallon cell full. I only tend to discuss race weight as the classes I run require us to drive across the scales after every pass which is a race weight with driver & fuel.
10secBu is offline
post #7 of 22 (permalink) Old Sep 19th, 05, 9:51 PM
BTW, for anyone who is interested in the 78-81+ Malibu's as well as other A/G-bodies, an excellent online resource is my friend Phillip Patterson's site.
http://www.maliburacing.com
BTW, Bob, just for reference, the 78-81 Malibu is labeled an A-body by GM. The G-body name started in 1982 and continued to 1988 when they were stopped. The 78-81 was the only years the 2 door coupes were produced. After that you could only get the 4 doors and wagons.
10secBu is offline
post #8 of 22 (permalink) Old Sep 19th, 05, 11:37 PM Thread Starter
Thanks for all the great info. Looks like I can save at least 250 pounds over my 66 Beaumont.
I wanted to get a car that was more of a race car that I could beat on a lot and not worry about it.
Just wondering what kind of engine combo and converter you got to run the kind of ET's in your signature. Awesome fast. Are you using a tranny brake as well ?
1966 Beaumont SD
1970 Nova
Sandy is offline
post #9 of 22 (permalink) Old Sep 19th, 05, 11:51 PM
Basic 13 to 1 compression oval port 454. Trans is a th400 with an 8" ATI Treemaster converter. Footbrake launched from anywhere from 1800 to 3000 rpm.
10secBu is offline
post #10 of 22 (permalink) Old Sep 20th, 05, 1:20 AM Thread Starter
Don't think there is such a thing as a "basic 13:1 engine".
How many rpms through the gears and traps ?
1966 Beaumont SD
1970 Nova
Sandy is offline
post #11 of 22 (permalink) Old Sep 20th, 05, 1:26 AM
GM 454 4 bolt block bored .030" over (461 ci), GM 454 steel crank, Eagle H-beam rods, JE pistons, Bullet solid roller cam, 262/272 @ .050, .697 lift, GM 781 large oval iron heads, 2.25/1.88 valves, bowl blend, Edelbrock Vic jr intake, 1000HP carb. Very basic combination.
The engine is shifted at 6500 rpm, sees 7200 at the finish line.
4.10 gears, little 275/60 M/T ET Street Radial tires.
10secBu is offline
post #12 of 22 (permalink) Old Sep 20th, 05, 3:34 AM Thread Starter
Thanks for the explanation.
An awesome combination, very stout.
Fantastic picture of the car launching with the wheels high in the air.
1966 Beaumont SD
1970 Nova
Sandy is offline
post #13 of 22 (permalink) Old Sep 20th, 05, 7:41 AM
Darren
Todd,
Your car STILL just amazes me on how good it runs!
Nothing exotic. Nothing fancy. Just awsome.
Darren
1971 Chevelle
496
10.5 scr
CFM Ported Victor Jr / Pro Systems HP1000
T-56 Magnum 6 Speed, DFX
12 Bolt TrueTrac, 4.56 gear 33 spline Mosier axles
30x12.5 ET Street Radial
525++ rwhp
http://www.chevelles.com/showroom/da...0930-00149.jpg
http://www.chevelles.com/showroom/da...m/Vic_Jr_1.JPG
71454Chevelle is offline
post #14 of 22 (permalink) Old Sep 20th, 05, 8:06 AM
it's almost what you'd call perfection of a combo. although there's nothing exotic about it, the suspension, the convertor, and the tune-up are all much better matched than most people ever take the time to get to.
post #15 of 22 (permalink) Old Sep 20th, 05, 3:29 PM
I looked at one of these Malibus recently and noticed that the frame is much narrower than the older Noves and Camaros in the engine compartment. It seems that getting good headers to fit in there would be difficult. I still like the body style of the 78-80 Malibus though.
Harold Sutton is offline
65 chevelle weight? vegadan Performance 16 Jan 27th, 05 1:58 PM
Chevelle Pros and Cons stc37 Performance 4 Dec 2nd, 04 8:41 PM
chevelle sort of question mod malibu Performance 0 Oct 12th, 04 12:01 AM
66 Chevelle Weight Bobalos Performance 10 Sep 15th, 04 3:28 AM
