in
this forum
in
the entire site
Cancel
Login / Join
What's New
Forum Listing
Products
Marketplace
Showcase
Gallery
Members
FAQ
Dark Mode
Light Mode
menu
Log in
Sign up
Home
Forums
General Chevelle Tech Area
Performance
Follow Forum
Create Thread
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
EFI
Caution: Beyond here be monsters...
19K
7.6M
4d ago
19K
7.6M
4d ago
Filters
Show:
Loading…
1
1 of 982
Go to page
Go
982
B
Sticky
1 EZ step for more clearance of aftermarket oil pans, HEI dist caps, header collectors & fan blades
BillyGman
Jun 12, 2023
Locked
3K
Jun 12, 2023
by
LevonH
U
Sticky
Cam Advice From UD Harold (may he R.I.P.)
UDHarold
Oct 2, 2006
Locked
0
29K
Oct 2, 2006
by
UDHarold
R
396 CBB BUILD NEED ADVICE
Roscho04
3d ago
951
48m ago
by
Roscho04
598 BBC 4.600 x 4.500 , 6.700 rod , rectec flatop forged compression 11.0 to 11.3 compression ration nut sure yet
Jesse 496
18h ago
9
250
50m ago
by
71malibuu
J
Finally made it to the track!
jburns
2d ago
33
771
3h ago
by
GRN69CHV
Are we having fun yet? YES! Nickels 320 Cylinder heads 18cc 10:1 compression piston Hot Street 489 Big Block!
Ripper/Wrench
Feb 23, 2024
4
5
6
326
11K
11h ago
by
Jesse 496
S
Track ET and MPH
Steve69SS396
Jun 21, 2023
5
220
15K
13h ago
by
carpoor
Chevrolet Performance BBC aluminum heads
novaX522
2d ago
14
458
14h ago
by
VORTECPRO
S
Comparison of High Powered SBC and LS Engines
Steve69SS396
3d ago
15
616
16h ago
by
68Chevele
V
Low Buck 350 Dyno / Drag Test Build
VORTECPRO
Nov 5, 2023
156
11K
17h ago
by
Jesse 496
R
1971 Chevelle - What Spark Plugs for Pro Comp Heads
RMBillings
19h ago
0
73
19h ago
by
RMBillings
6
3/8 fuel line tubing bender?
66dream
3d ago
11
366
1d ago
by
rpol78
8
Howards Hyd. Lifter question. 91171
81ls1camaro
May 6, 2014
18
15K
2d ago
by
benheinz61
A
weiand street warrior 8123 intake with my cam - any users?
als427
Feb 5, 2024
23
1K
2d ago
by
LaVelle
6
496 roller cam recommendations
69SSpost
Feb 1, 2023
33
6K
2d ago
by
Germjoe2000
Where to start?
Myanmar1
4d ago
13
419
3d ago
by
mrpaticular
1
427 Wiseco Pro Tru Street Piston Set & edelbrock RPM heads
1badbigblock
3d ago
6
285
3d ago
by
B433
D
Which way would you go....
Darren Trudeau
7d ago
25
864
3d ago
by
70SSOBSESSION
Fuel Line Size
FootSoldier
6d ago
38
854
3d ago
by
bracketchev1221
It’s BB Time.
Dads 72
Mar 4, 2024
14
974
4d ago
by
Dads 72
Chokless carb hard starts , procedure ?
70ssclone
Mar 5, 2024
1K
4d ago
by
RifRaf
king XP bearings ?
Jesse 496
Feb 4, 2024
23
1K
4d ago
by
mrpaticular
D
Procharger, big block, stock hood in a '66?
Darren Trudeau
Mar 7, 2024
5d ago
by
Steve69SS396
.060 over 454 LS5 engine build
-SS454-
Nov 3, 2023
7K
5d ago
by
bracketchev1221
Finally, 385" Dyno Time
jjjaffo
Feb 24, 2024
17
978
5d ago
by
jjjaffo
G
66 chevelle fuel tank
GM man
Mar 10, 2024
49
835
6d ago
by
rpol78
6
6AN to .395 dia. hard line?
66dream
Mar 9, 2024
11
339
6d ago
by
66dream
B
1.645 vs. 1.27 Compression Height
BBCChris
Mar 8, 2024
24
708
6d ago
by
BBCChris
E
Help With Motor
Emir
7d ago
6
371
7d ago
by
70SSOBSESSION
P
Dyno sheet question
PH2024
Mar 10, 2024
2K
Mar 12, 2024
by
VORTECPRO
Cold air intake for my 1969 Chevelle
rostcha
Mar 10, 2024
17
565
Mar 11, 2024
by
DZAUTO
467 to 540
mrpaticular
Feb 15, 2024
38
2K
Mar 11, 2024
by
bracketchev1221
Valve train setup...How important is it to get to .100" from coil bind at max lift?
JIM
Feb 12, 2024
1K
Mar 10, 2024
by
JIM
Install 1.6 rockers on intake only sbc
richiecat4223
Mar 8, 2024
11
435
Mar 10, 2024
by
68Chevele
6
Ptfe Fuel Line (Evil Energy?? Good , Bad???)
66dream
Mar 7, 2024
21
763
Mar 10, 2024
by
Kopfjaeger
What SBC intake would get the job done best
68Chevele
Mar 8, 2024
18
767
Mar 9, 2024
by
TAG55
SB rebuild tips and advise wanted
72soft-top
Mar 8, 2024
20
535
Mar 9, 2024
by
70SSOBSESSION
1
1 of 982
Go to page
Go
982
Performance
609.3K
posts
168.2M
views
Our High Performance area
Show Less
Join Community
Grow Your Business
Forum Staff
View All
Bob Tiley
Super Moderator
Top Contributors this Month
View All
V
VORTECPRO
Ripper/Wrench
mrpaticular
Recommended Communities
AVS Forum
1M+ members
SkyscraperCity
880K+ members
Deals Forum
40+ members
Home
Forums
