how to adjust wing window outside gap 66. - Page 2 - Chevelle Tech
Body Shop Paint & Body Forum
post #16 of 19 (permalink) Old Feb 17th, 17, 2:04 AM Thread Starter
Re: how to adjust wing window outside gap 66.
Originally Posted by 1966_L78 View Post
Just checked my SS (original weaterstripping), and sure enough, the rubber sits down inside...
So water could get in there? As it ages and shrinks there could be a gap?
I just found out (above post) about the little screw that goes inside the vent frame and pulls it towards the outside of the door.
I've played around a bit and seems like there is a way to adjust these things.
KarlJay is offline
post #17 of 19 (permalink) Old Feb 17th, 17, 2:49 PM
Sounds like you are on the right track. Water is supposed to run down inside the door and out the bottom through all those openings in the bottom. If you look at the window felt, it is clear that they will not stop water from passing through. Now a days cars are sealed up much better.
LKN BCK likes this.
1967convert is online now
post #18 of 19 (permalink) Old Feb 17th, 17, 5:25 PM
Yep, that's why the bottom corners of the doors rusted on a lot of these cars.
Dirt and dust would build up in there the depending what part of the country the car was in road salt would mix with the dirt and take days to dry out while the salt sat there eating away on all the wetness.
LKN BCK is online now
post #19 of 19 (permalink) Old Feb 17th, 17, 5:30 PM
The screw does not really pull it out...maybe a bit.
It is more there to help stabilize the vent window frame to the door.
