Epoxy Primer over Self Etching Primer (laquer based) - Chevelle Tech
Body Shop Paint & Body Forum
post #1 of 18 (permalink) Old Feb 3rd, 10, 4:14 PM Thread Starter
Chad
I stripped most of my chevelle to metal, put on a coat of self etching primer (laquer based). Thought I was putting on epoxy primer. (rookie mistake) After I started on some body work to smooth out the weld spots. I realized it was not epoxy primer, by looking at the paint can more carefully.
Can I epoxy primer over the self etching primer? Or do I need to keep going with the self etching primer? or strip and restart.
I hope I didn't mess up the process.
chevychad is offline
post #2 of 18 (permalink) Old Feb 3rd, 10, 4:20 PM
Greg
Re: Epoxy Primer over Self Etching Primer (laquer based)
You are not supposed to put epoxy directly over etch.
You should also not be putting filler over etch, not sure if that's what you meant by "bodywork"
71 Malibu
Asst Novas
TechNova is offline
post #3 of 18 (permalink) Old Feb 3rd, 10, 4:54 PM Thread Starter
Chad
yes I put rage gold filler over etching primered panels. Do I need to strip it back down to metal, then epoxy prime, then filler?
post #4 of 18 (permalink) Old Feb 3rd, 10, 5:45 PM
That's what I've always done. There really is no need for etching primer over sanded bare metal when epoxy is available.
1970 SS Best ET: 12.31@108 MPH
1969 Malibu
1969 Dodge Charger
1970 Chevelle Convertible
Maryland Chevelle Club
BlueSS454 is offline
post #5 of 18 (permalink) Old Feb 3rd, 10, 8:17 PM Thread Starter
Chad
The can says, over bare metal, over primer, under primer or paint. Is that stuff just old technology that is not recommended anymore? I don't understand why filler should not be over it?
At the same time I want to make sure I don't cause future problems with the paint.
post #6 of 18 (permalink) Old Feb 3rd, 10, 8:57 PM
patton
Sure---etching primer can go under paint...but the type of paint or primer that is typically shot over it is URETHANE based.
As already mentioned...no epoxy and no polyester fillers on top of etch primer....take the stuff off. You said you want to avoid the possibility of future problems, right???---the only way to eliminate the chance of a reaction is to GET THE STUFF OFF OF THERE!
or---roll the dice and leave it on there.
Hmmmm....which odds sound better???
Patton Glade
64-72 A-Body Gas Tank Pads
http://www.chevelles.com/classifieds...ct=15602&cat=7
70post Restorations
Austin, TX
pglade is offline
post #7 of 18 (permalink) Old Feb 3rd, 10, 9:09 PM
The reason why you don't want to put filler over etch primer is the acid in the etch will soften the filler causing it to lift=failure and redo.Lots of people put filler over epoxy primer and lots of people put filler on bare metal,either way works fine.The funny thing is all filler manufacturers recommend putting filler onto properly prepared bare metal(I have done it this way for 25 years with no problems) but only paint companies recommend to epoxy your panel before filler.(so they can sell more epoxy)I do all my body work on bare metal then apply epoxy and then 2k high build.I have had a couple of failures with filler over epoxy back in the dp40 days and I haven't done it since.
crazy canuck is offline
post #8 of 18 (permalink) Old Feb 3rd, 10, 9:18 PM
So what the heck is self etch primer invented for?
john5469 is offline
post #9 of 18 (permalink) Old Feb 3rd, 10, 10:00 PM
patton
speed...collision work, etc.
Patton Glade
70post Restorations
Austin, TX
pglade is offline
post #10 of 18 (permalink) Old Feb 3rd, 10, 11:06 PM Thread Starter
Chad
I am glad I found this out, from everyones advise, before I went any further with the body work. I am going to strip it back down, then epoxy primer.
In all reality, I am not very far yet so it is better to start over. Thank you for straightening me out.
You guys are the best!!
post #11 of 18 (permalink) Old Feb 4th, 10, 8:11 PM
Hugh
There is very good reason to use epoxy directly on bare metal and then use filler over it (per the specifications). It is not just so the paint companies can sell more epoxy, but I am sure they do like selling stuff too.
Rucumn is offline
post #12 of 18 (permalink) Old Feb 4th, 10, 9:08 PM
Greg
Self etch has excellant corrosion resistance, you just can't use filler over it. While it is much faster for collision work, it does not mean it is a poor product. I have used it thousands of times, in fact, part of my car has etch (wash actually) and part has epoxy. The epoxy was used because I stripped some areas and wanted to get it in primer so I could finish fill a few minor imperfections a few months later, not a good idea with etch.
The areas where I was stripping, filling and priming an individual panel all at once I used wash.
71 Malibu
Asst Novas
TechNova is offline
post #13 of 18 (permalink) Old Feb 4th, 10, 9:20 PM
JOHNNIE
etching primer is and was invented to go over bare metal, so the urethane primers would stick. epoxy has etch built into it. and has a 98% moisture
i need motivation
BIGBLOCK70Z is offline
post #14 of 18 (permalink) Old Feb 5th, 10, 12:00 PM
I use etching primer on parts like engine pullies and brackets where no filler will be applied.
Team Chevelle Member (16 years and counting...)
'72 Chevelle Convertible (Mohave Gold) (all SS options, no SS badging) 454 Big Block now installed , getting closer
1975 Corvette Convertible (Steel Blue)
2005 Mustang GT convertible (Sonic Blue)
72soft-top is offline
post #15 of 18 (permalink) Old Feb 5th, 10, 12:49 PM
Vince
Send a message via AIM to Badboyvince69 Send a message via Yahoo to Badboyvince69
Is self etching the right one to use to cover bare metal until i can get the car to someone to paint? I have been taking off the rust, and body filler,then covering the bare metal with it for protection. I know epoxy is the best to use, but i wanted the body work done then covered with it.
Badboyvince69 is offline
