How to Clean Up tools after Bondo.... Acetone? - Chevelle Tech
Body Shop Paint & Body Forum
post #1 of 28 (permalink) Old Jan 21st, 10, 6:21 PM Thread Starter
Chad
I am starting my body work and have a peice of aluminum to mix the bondo on. (Evercoat Rage) What do I use to clean up the aluminum mixing board? Acetone?
Will the acetone cause any problems if I clean the mixing board before starting a new batch. Or only clean up after I am done for the day.
chevychad is offline
post #2 of 28 (permalink) Old Jan 21st, 10, 6:57 PM
Matt
Re: How to Clean Up tools after Bondo.... Acetone?
Scrape all the putty off before it sets up. Use a metal edge putty knife or a squeege that is used up. When all else fails, put it in the bead blast cabinet.
oktunes is offline
post #3 of 28 (permalink) Old Jan 21st, 10, 7:18 PM
Kev
Acetone rots the liver. Try not to get it on your skin very often.
I've heard that a 12" square piece of plate glass is good for mixing mud. Might be able to get a scrap from a glass shop and slip them a few bucks to clean up the edges.
66sc is offline
post #4 of 28 (permalink) Old Jan 21st, 10, 7:43 PM
Kyle
Scrape it off with a razor blade before it fully sets up... Or
Try scrap pieces of cardboard, use both sides and toss it when your done. I've been doing it for years. Or get a real plastic mixing board from your local paint supply. They're flexible and when the filler cures you can snap it off the plastic board.
[OO] Malibu [OO]
70 Chevelle - Malibu
TC #4464
350_Malibu is offline
post #5 of 28 (permalink) Old Jan 21st, 10, 8:14 PM
Big Jim
glass works great. you can get a 12" square mirror from a home remodeling place that's adhesive backed & stick it on a piece of plywood. or glue a piece of regular glass on the ply. clean up with a razor, & you won't have to worry about breaking the glass like i did the first time.
almost forgot... acetone is absorbed through your skin, into your system. don't mess with it without gloves.
mryanduv is offline
post #6 of 28 (permalink) Old Jan 21st, 10, 9:30 PM
agrees with kyle flexable plastic or carboard is all you need
65ElCaminoMan is offline
post #7 of 28 (permalink) Old Jan 21st, 10, 9:49 PM
Herbie
Buddy of mine uses a piece of plywood.
Breaks off the unused and then takes a DA to it before using again.
http://www.chevelles.com/forums/pict...&pictureid=490
Herbie
'67 SS Chevelle 460"
XE284, 9.97:1, CK 2004R, 3.42 12bolt
Holley 770SA, RPM AirGap, 3200 stall
hpsherlin is offline
post #8 of 28 (permalink) Old Jan 21st, 10, 10:01 PM
Rudy
flexable plastic from your local supply shop I think I paid $1.50 and have been using it for a long time, just snap it and the bondo is gone
66 Convertible
66 coupe
66 El Camino
72 VW Convertible
83 GMC POW/MIA Drag Truck
http://www.cardomain.com/ride/3230084
http://www.cardomain.com/ride/3230123
http://www.cardomain.com/ride/3231524
oldtimeparts is offline
post #9 of 28 (permalink) Old Jan 22nd, 10, 12:26 AM
Greg
http://www.autobodytoolmart.com/quic...d-p-10975.aspx
fast,clean & can be used to mix adhesives also.
Cardboard and paper absorb what you don't want absorbed.
TechNova is offline
post #10 of 28 (permalink) Old Jan 22nd, 10, 10:09 AM
john
i have been liking the dixie paper plates...
'71 chevelle
'70 el camino
'03 DRZ 400s
'78 kawasaki KZ650sr
ACES #8681
propest is offline
post #11 of 28 (permalink) Old Jan 22nd, 10, 10:44 AM Thread Starter
Chad
I read online that wd40 works. I tried that with a razor blade and it worked pretty good. The flexible board sounds good to just snap it off.
post #12 of 28 (permalink) Old Jan 22nd, 10, 11:18 AM
I used to use a piece of glass and scrape it off with a putty knife, then a razor blade and wash it with lacquer thinner.
Now I use the tare off sheets which is much easier.
http://www.autobodytoolmart.com/popu...arge/10975.gif
post #13 of 28 (permalink) Old Jan 22nd, 10, 11:57 AM
I have to read this data you found. That's what I want in my filler, WD-40. Perfect for painting and zero contamination issues.
Raven1 is offline
post #14 of 28 (permalink) Old Jan 22nd, 10, 12:15 PM
X2 - Not a good idea.
LK
Alwhite00 is offline
post #15 of 28 (permalink) Old Jan 22nd, 10, 1:36 PM Thread Starter
Chad
DOH, your right.
This Thread is more than 2652 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
