brake cleaner warning - Page 2 - Chevelle Tech
Body Shop Paint & Body Forum
post #16 of 24 (permalink) Old Jul 26th, 09, 9:12 PM
Bart
Re: brake cleaner warning
I will be sharing this with people at work and people I know outside of work.
Bart Pinson 1970 Chevelle SS454
Bart42 is offline
post #17 of 24 (permalink) Old Jul 27th, 09, 4:32 AM
Send a message via AIM to Hot66ss
Going to leave this as a sticky for a while so everyone gets a chance to read it!
21st Century Performance
(310) 425-8700
67 Velle- AFR headed 509/4L80 Pro-Touring.
70 Chevelle- Latest project
03 Mustang Cobra Terminator 512RWHP/498RWTQ
68 Vette, Documented 427/435hp Tri Power, 4 speed- Sold
70 SS LS6/M22 Documented, black/white stripes- Sold
Hot66ss is offline
post #18 of 24 (permalink) Old Aug 6th, 09, 10:37 AM
chris
Pretty scary stuff. I know I don't protect myself enough, but I will start being more aware of it. I hope that guy in the story makes a good recovery.
sleeper67 is offline
post #19 of 24 (permalink) Old Aug 6th, 09, 11:11 AM
Kris
Yes that brake clean is harsh stuff. I have seen guys clean their hands with it.
It can also be used to kill insects pretty quickly. Sometimes, I have some moths flying around my garage and a quick spray of brake clean kills them in 30 seconds...I know now brake clean&welding/flame doesn't mix.
1970 Monte Carlo 468 BBC full manual TH-400, Freak show 5000 stall 4.10 gears
engine currently being rebuilt with mostly recycled GM performance parts-- now shooting for 11's!
-12.5:1 TRW 7040 pa pistons, GM forged 7416 crank 4 inch, dimple rods, ported 781 heads 2.199 & 1.88, mech flat tappet COMP Cams#249-11-608-5 ,.635"/.637", 262/270 @.050 , 108 LSA, Crower EDM lifters, Weiand Team G single plane 4500 flange intake, Holley model # 0-9380 850 cfm, 2 inch primary Hooker super comp headers with 12 inch collector extensions
Launch video http://www.youtube.com/watch?v=h2qQX4TDTVU
IN-CAR dragstrip run Sept 17 2011@Napierville
http://www.youtube.com/watch?v=HzQXrm6jvdU
MonteMan454 is offline
post #20 of 24 (permalink) Old Aug 13th, 09, 11:11 AM
Originally Posted by rwin1592 View Post
Here's some interesting facts: Fosgene gas is what they called "mustard gas" used by the Japanese in WW2. It caused many soldiers permanent lung damage. A friend of mine's father never could work due to lung damage from it. Also, freon (R-22) if burned becomes fosgene. That's why refrigeration and HVAC guys are taught never to smoke when working with freon and to work in a well ventilated area or with outside air masks when brazing around freon. WE all take this stuff too lightly until something happens! Be careful!!
Phosgene Gas is NOT Mustard Gas. Mustard Gas is a Blister Agent, while Phosgene is a lung irritant (and toxic). Phosgene was first and largely used during WWI. Although many gases were stockpiled during WWII, very little was ever used. The Japanese used Phosgene and Lewisite in China in a very limited capacity in the late 1930's and into 1941.
TC# 4437
SixActual is offline
post #21 of 24 (permalink) Old Aug 17th, 09, 6:48 AM
paul
make sure that the air suply doesnot have an oiler on it ,for some tools,needs good filter, caused a man at work to have a stroke,when he hook up to wrong air line.......
hog1 is offline
post #22 of 24 (permalink) Old Aug 30th, 09, 8:58 AM
Paul
I work for a municipality and was doing a brake job on a sander truck. It had a leaking wheel seal and I used non-flammable brake cleaner to clean the oil from the brake drum. I was being impatient and couldn't wait for the brake cleaner to dry up. I lit the welding torch and warmed the brake drum to speed up the drying time. WELL I felt like I was suffocating, just like there was no air to breath! I quickly put out the torch and went outside. I didn't suffer any damage and was fine a few minutes later. It was a scary episode and now I read the labels when using any chemicals, even spray paint.
Paul
prefectca is offline
post #23 of 24 (permalink) Old Sep 23rd, 09, 4:20 PM
Send a message via AIM to psi3000
Would a normal $20 respirator prevent the gas from entering into the lungs or no? Just wondering if we need to be cautious about things even with a respirator on.
psi3000 is offline
post #24 of 24 (permalink) Old Oct 8th, 09, 9:07 AM
M.S.D.S. MATERIAL SAFETY DATA SHEETS!!! anytime you have any suspision of a chemical or considering hiring a contractor to do work around house (wood renew, landscaping,etc) ask the contractor or contact the company where chemical is made and ask for M.S.D.S. sheets by Law the company must provide them. With the internet its even easier because you can go directly to companys web site and get info. The M.S.D.S. contains all chemicals in product , the safety warnings, what harmful side effects that could effect you and how to treat immediate exposure. The guy in article posted about brake kleen should have gone directly to hospital and told ER staff what he was exposed to.Another warning about brake kleen ALLWAYS wear safety glass's and a mask. It only takes a minute to get hurt but it also only takes you a minute to be safe.
urleycay is offline
This Thread is more than 2754 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
