body panel thickness - Chevelle Tech
Body Shop Paint & Body Forum
post #1 of 10 (permalink) Old Oct 16th, 08, 9:13 AM Thread Starter
db
can anyone tell me what gauge thickness the body panels (quarters,front fenders)on a 1970 Chevelle are?thank you.
db is offline
post #2 of 10 (permalink) Old Oct 16th, 08, 9:19 AM
JimB
Re: body panel thickness
Well, I am going to answer just to get sombody to resond, i know it isn't 18 gage so i am GUESS it is either 14 or 16
Being free isn't cheap, You have to earn it . 68 Chevelle SS. Cherry Black 454 BB, tripleflow- JimB
JimB is offline
post #3 of 10 (permalink) Old Oct 16th, 08, 9:54 AM
The Fat Stig
check out Rubadub's signature link, he has something on his site about panel thickness.
Originally Posted by jpete, Dean, Derek69SS, hoffbug, rubadub, Grandsport, Thomas Jefferson, 1badss396, MEJ1990TM, and mrdjc99
As usual, Andy is right
If it doesn't fit, force it. If it breaks, it needed to be replaced anyway.
SuperAndy's Garage
Automotive Archaeology
Andy69 is offline
post #4 of 10 (permalink) Old Oct 16th, 08, 1:36 PM
With all due respect, there's nothing thicker than 18 gauge on the car (as far as sheet metal), and even that's a stretch. The closest commercial gauge thickness to what's on our body panels is 19 gauge (.042" thick), but since it's not as readily available I used 18 gauge (.048" thick) to patch my door skin this past weekend. Use magnets to keep the outside surface flush and the extra thickness won't hurt anything inside. If you try to form it to make any patches, 18 gauge is about as heavy as you'll want to fight with. 16 gauge (.059" thick) is quite thick and 14 (.074") isn't even a consideration.
I do precision sheet metal fabrication for a living, so I have the advantage of literally tons of these sheets on the shelves at any given time.
___________________________________
'71 Chevelle; stout 355/TH350 (full manual)/12 bolt posi, 4.11
dpvoiceguy is offline
post #5 of 10 (permalink) Old Oct 16th, 08, 3:01 PM
Rob
http://www.1969supersport.com/smthoughts.html
Rob
"There are questions to be answered, and answers to be questioned"
Jigs, sandblasting, shop, paintroom, rotisserie, pictures, little bit of everything.
rubadub is offline
post #6 of 10 (permalink) Old Oct 16th, 08, 9:19 PM Thread Starter
db
Thanks all for the quick replys and thanks Rubadub for the link it`s in my favorites....so I contacted a replacement panel supplier (NPD) and they told me thier panels (need to repair my 70`s wheel openings)are 22 gauge is this to thin or is it the normal for replacement panels?Again Thank You all for your time.
db is offline
post #7 of 10 (permalink) Old Oct 17th, 08, 5:56 AM
Though I've never purchased any repro panels, I have read many posts saying that they are thinner than stock. 22 ga is .030" and you just need to use caution welding it. Will you be doing that yourself? The preferred method of joining panels is butt welding them with a good MIG welder. Doing so with 22 ga will be a little more tricky; you need to be very attentive to controlling your heat or it can warp more easily than a thicker panel. Also, when striking the arc initially, you want your electrode (tip of the wire) to be favoring the thicker metal ever so slightly, then drift toward the thinner piece after hitting the trigger. Otherwise you can end up blowing a hole through the edge of the thinner panel.
post #8 of 10 (permalink) Old Oct 17th, 08, 7:21 AM
JimB
Humm , I guess My guessing was wrong but I would have thought the older cars would have been thicker than the newer tin cars.
JimB is offline
post #9 of 10 (permalink) Old Oct 17th, 08, 8:08 AM
I actually measured the hood and quarter panels on a 70 Chevelle and Goodmark replacements. Stock .034" and Goodmark .032"
Racing is offline
post #10 of 10 (permalink) Old Oct 19th, 08, 1:02 AM
Mike K.
Send a message via AIM to MakMetalFab
I always use 20ga on the exterior panels, 18ga for inner rockers and other Thicker parts of the car.
Owner of Mak Metal Fabrications
Specializing in restoring the Unrestorable
http://s230.photobucket.com/albums/ee83/MakMetalFab/
MakMetalFab is offline
