66 Quarter Window Installation - Chevelle Tech
Body Shop Paint & Body Forum
post #1 of 3 (permalink) Old Jun 21st, 06, 10:02 AM Thread Starter
Question 66 Quarter Window Installation
Does anyone have any tips [or can you point me toward where I could find info] on installing the rear quarter windows in a 66 chevelle coupe? I am starting re-assembly and heard this can be a bear to do so I wanna arm myself before I begin.
Thanks in Advance
Joel
Blueshwk is offline
post #2 of 3 (permalink) Old Jun 21st, 06, 2:59 PM
Re: 66 Quarter Window Installation
Would recommend the Fisher body manual & the 66 Chassis-Service Manual. Good expenations that I used to remove/install my rear quarter windows this winter.
jrlars is offline
post #3 of 3 (permalink) Old Jun 22nd, 06, 9:50 AM
Roger
Clean and lube the large channel and install. Hopefully you didn't mess with the adjustment screws much because you want to leave them where they were when the factory worker adjusted them. Channel is in, now drop the glass in and get those rollers (which are all in perfect shape right?) in the channels. I slip the window regulator in next and get it's roller on the right track. Finally, engage and install the rear track. Tighten the regulator, then the tracks putting the nuts in the same spot as before. There is usually a little indention where they originally were. You see that you have to hold the screw with a screw driver and tighten the nut with a wrench or you'll screw up your adjusting screws posisitions. Now give it a try. Hopefully it fits. If not it is a bugger to figure out. As mentioned before, a manual helps allot. If you don't have one start trying to adjust it yourself or find someone smarter than yourself 8^).
67shovel is offline
Quarter Window mbj359 Interiors 3 Jan 23rd, 06 10:21 AM
`72 quarter window help... SouthpawJG Interiors 1 Sep 12th, 05 2:58 PM
Q about quarter window seals bhawk Body Shop 2 Mar 31st, 05 1:15 PM
How to keep quarter window from coming out of top of track? northern 396 Convertibles 5 Feb 8th, 05 10:59 AM
Help with quarter window installation. sportster Body Shop 3 Jul 17th, 03 12:48 PM
