Battery life - Chevelle Tech
post #1 of 17 (permalink) Old May 19th, 17, 1:42 PM Thread Starter
Battery life
How often are you guys replacing batteries on occasional-use vehicles? It occurred to me the other day that I am coming up on 8 years with the battery in my Nova. I'm wondering if I should start getting nervous about it failing at the worst possible time / place? The car is only driven ~2000 miles each year, and I keep it disconnected anytime the car is parked in the garage (even overnight). Not seeing any signs of impending failure, but I wonder if I should start thinking about proactive replacement?
novadude is offline
post #2 of 17 (permalink) Old May 19th, 17, 1:51 PM
Re: Battery life
When mine hit 7 years, I got that feeling as well and headed off any future problems by replacing it. Peace of mind while on the road. I used to do that with the rubber hoses as well on my daily drivers, but every 10 years. In the Navy they called that preventive maintenance. Maybe getting too paranoid the older I get.
USN-SSBN 645-G
boyd66k20 is offline
post #3 of 17 (permalink) Old May 19th, 17, 2:22 PM
Re: Battery life
after 7 years, even if it works fine, swap it out. You got your monies worth out of it. But another of the same to support whoever made a good one.
1967 El Camino Malibu Deepwater Blue
ZZ4 350 FiTech 600 (In Progress), 700R4, JGC Steering, 1990s serpentine.
Pioneer4x4 is offline
post #4 of 17 (permalink) Old May 19th, 17, 2:26 PM
Re: Battery life
Batteries are kind of hit and miss. My grandma drove a 1978 Impala that she bought brand new. Around 1997 the original battery had to be replaced. Other batteries last just past the warranty. The nice thing about batteries is they are a universal part that is easy to get anywhere. If it starts failing on a road trip you can get one at any parts store.
1969 Beaumont
1977 Bronco
The rest are boring responsible adult vehicles not worth mentioning.
Chris27 is offline
post #5 of 17 (permalink) Old May 19th, 17, 2:54 PM
Sheepster. BAH!
Re: Battery life
x2 on replacing, keep the old one & trickle charge it just in case you need one
(had to recharge my old optima last night saved a AAA call)
cuisinartvette is offline
post #6 of 17 (permalink) Old May 19th, 17, 3:14 PM
Re: Battery life
With a multi meter you can check the voltage. Make sure it is fully charged then check the voltage. A good strong battery should read in the 12.8v to 12.9 volt range. If you get a reading in the mid to low 12's it's getting weak. I keep a Battery Tender Jr on my batteries. It also helps longevity. Have been averaging around 8 years or better...
My Showroom
69' SS396 Chevelle L78 396/375hp M-21 Close Ratio Cortez Silver
10 year Resto
It's brand new again!
02' Harley FatBoy, Diamond Ice Pearl and lots of chrome!
ACES# 3466
fastss396man is offline
post #7 of 17 (permalink) Old May 19th, 17, 4:03 PM Thread Starter
Re: Battery life
Yeah... you are right. It bugs me though. I feel like I am always replacing tires and batteries on the "hobby" vehicle before they are "used up". I guess it beats getting stranded somewhere at 10 PM on a Sunday.
It was a Carquest battery made by Deka. Never had a need to put it on a charger, and it's never caused any problems. I disconnect the battery everytime I put the car in the garage, cause it helps me sleep better at night (50 year old wires in some places and no fusible links on these old cars).
novadude is offline
post #8 of 17 (permalink) Old May 19th, 17, 4:41 PM
Red
Re: Battery life
I'd replace it. The longest I've ever had a battery last is 7 years and a bit. An Interstate battery in my 78 C-20 P/U went from August of 1992 to Nov of 99.
Sometimes a man's got to do what a woman would never consider.
55Redneck is offline
post #9 of 17 (permalink) Old May 19th, 17, 4:48 PM
blm
Re: Battery life
Just replaced a red top Optima that I installed in March 2010. I think c what killed it was my car was being restored for the last 12 months that I had that battery. In that 12 months it was only started a couple times and run for 2-3 minutes. Prior to the restoration I kept it on a trickle charger.
I have gotten as little as two years with other batteries but don't think I had those on a trickle. So 7. Years is my longest.
blm is offline
post #10 of 17 (permalink) Old May 19th, 17, 4:52 PM
gary
Re: Battery life
Replaced my 8 yr old one.
post #11 of 17 (permalink) Old May 19th, 17, 4:52 PM
Re: Battery life
Get a Battery Brain, it hooks up in line with the positive cable and has a key fob remote to shut the power off at will. good for when parked overnight or when in storage. also good as an anti theft deterrent when out somewhere with the car.
it can be mounted several ways, on the top of the battery, the side of the battery, or even off the battery on the core support for example so it is out of sight.
https://www.summitracing.com/parts/sms-t3-12v
"Don't You Know It's All Ball Bearings These Days"
1970 Chevelle SS 454
More Chevelle
Fear This...
chrispicide35 is offline
post #12 of 17 (permalink) Old May 19th, 17, 5:27 PM
p40
butch
Re: Battery life
i would have it load tested, itcould show 12 volts and and still fail under load test
p40 is offline
post #13 of 17 (permalink) Old May 19th, 17, 6:54 PM Thread Starter
Re: Battery life
Battery Brain - YouTube
That's kinda neat. Never saw one of those before.
novadude is offline
post #14 of 17 (permalink) Old May 19th, 17, 9:47 PM
Re: Battery life
Anywhere from 3 -10 years has been my luck. That's usually on DD though, so they go through the -30 to -40 starts from time to time.
77 Monte
421 Profilers ported by Eric W. Straub HR 3200 conv. from Jake 200-4r w/ 3.73's
12.15 @ 112 & tuning
http://myweb.midco.net/77cruiser/
77 cruiser is offline
post #15 of 17 (permalink) Old May 20th, 17, 5:37 PM
Re: Battery life
I guess I'm going to be looking for a new Interstate Mega-Tron. The one in my '72 is dated 2004. It still starts very well though. I have no add-on equipment but, I was thinking it's time.
I sold my 1970 C/10 pick-up in 1988 with the original Delco battery in it. Still working well too.
Toppless72 is offline
