patch panel needed - Chevelle Tech
Auto Metal Direct Auto Metal Direct
post #1 of 3 (permalink) Old Nov 17th, 12, 6:54 PM Thread Starter
Question patch panel needed
I have a 1965 Chevelle 2dr post sedan. I and alot of others need the panel that is the lower part of the rear window and it goes to the trunk. I forget what it is called. The hardtop part is too long and will not fit. It would be fairly simple for AMD to shorten this up so those of us with 2dr post sedans would be able to repair this area which is often in poor shape. Thanks Jim
PLEASE LET ME KNOW!
jxnslotcar is offline
post #2 of 3 (permalink) Old May 18th, 13, 10:49 AM Thread Starter
Re: patch panel needed
Have you thought about making this panel yet? Whomever makes this replacement panel will be surprised by the demand for it. It is basically the same part as the 2dr hardtop but 3in shorter. It is difficult to take the coupe part and shorten it because of the curves, ect. I suppose it could be done but it would be hard to match up the curve and keep it from warping.
Come on AMD-help us out with this common rust area on our 2 dr post cars. It may even be the same part on the 4dr cars.
post #3 of 3 (permalink) Old May 20th, 13, 1:09 PM
Send a message via Skype™ to Auto Metal Direct
Hello -
Just to clarify, you're looking for the piece that goes between the back glass and the trunk? If that is correct, it would be the deck filler panel. Currently, we do not offer the deck filler for a 65 model and we don't have plans to produce that part in the future.
Sorry I can't be more help.
Auto Metal Direct is offline
This Thread is more than 1466 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
You may not post new threads
You may not post replies
