1968 Chevelle generator light stays on - Chevelle Tech
1999 -- Tech Files - reference area
1000's of previous topics
post #1 of 2 (permalink) Old Jan 7th, 00, 6:23 PM Thread Starter
My generator light stays on when the key is in the off position. I have narrowed it down to between the coil ignition side and either the fuse box or the wiring to the ignition . I have changed the ignition switch and the coil, to no avail. I would appreciate any suggestions. I know its a feed back but from where.
1968 Chevy Malibu 2 door Chevelle 307 V-8
Anna68 is offline
post #2 of 2 (permalink) Old Jan 7th, 00, 6:37 PM
Todd
Is the dummy light bright like when the key is on, or is it a dimmer glow? If its dim, it could be the voltage regulator is stuck, or the diode is bad in your alternator. Ive had this prob with both.
BAD415 is offline
This Thread is more than 6378 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
You may not post new threads
You may not post replies
